Question about Hoover UH70105 WindTunnel TSeries Bagless Upright Vacuum
Where is the motor on hoover uh70105 - Hoover UH70105 WindTunnel TSeries Bagless Upright Vacuum
Fuse replacement
it is a thermal over load unit not a fuse and operates because the motor is either running with out an air flow ( kinked hose or blocked filter bag) or is failing and requiring excessive current to run
Jun 19, 2016 | Hoover UH70105 WindTunnel TSeries Bagless...
Why is the motor roaring ? is it rubing on housing or a bearing ?
It may not be you motor, but the sound of some item caught in the impellar, which is the part that causes suction. It is usually located in the upper housing, and can be accessed fairly easily. Unscrew any visible screws,(usually phillips type) and carefully lift housing off. This should expose the impellar. If debris is present, remove it.
But also check for possibly broken fins on the impellar itself. Sometimes items like coins, or nails etc, will get picked up accidentally, then spin around in the impellar housing, only to break a fin or two trying to move on. If this has happened, replace the impellar.
Dec 22, 2015 | Hoover UH70105 WindTunnel TSeries Bagless...
How to open Hoover S3825
Hi there! We recommend taking your cleaner in to a Hoover authorized service center to have the motor replaced or repaired. I have included a link to the service center locator if needed. Hope this helps!
Service Center Locator
Oct 05, 2014 | Hoover Elite Cyclonic Canister Vacuum with...
I have a Hoover windtunnel T series. Model #UH70105. The system check indicator was almost red so I cleaned the filter. There are no clogs and it vacuums fine without the hose, but when I go to use the...
You likely have a hole in the hose causing a loss of suction/vacuum in the system. Mine cracked right around the bottom nozzle. There are no electrical wires in it, so I just taped it up with black electrical tape and it worked like new for many more years.
Sep 28, 2017 | Hoover Vacuums
Burning smell and loud noise from hoover steamvac f5897-900
Perform general maintenance - cleaning filters,etc. If it still exists, take it apart and check the motor... If the motor is sooty on the copper coils inside, then it's had it's day. You could try and buy a replacement motor, but typically, its cheaper just to get a new hoover.
Jan 12, 2011 | Hoover F5897-900 SteamVac Upright Vacuum
Hoover steamvac shooting sparks from motor
the motors shot some times i have fixed them if it hasn't been ran to long let me know im sure i have a motor
Dec 14, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Hoover floormate 500 making super loud noise when
You have a bad motor in the unit. It time for a new machine
May 07, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover U5106-900 Parts///I need motor brushers
http://www.kleansweep.com/hoover8.htm
try this site,they have a complete list of common hoover motor brushes(with pictures)hope this helps
Nov 27, 2008 | Hoover U5106-900 Breathe Easy Bagged...
I need to switch on my thermal protector on my hoover
FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Normally there are either screws, clips or levers that would remove the bottom plate or lid that does not work then the top cover will come off and that will expose the belt of the hoover from there u can continue further by opening the locks with proper screwdriver.and then the motor can be seen.
Nov 17, 2008 | Hoover Vacuums
Hoover UH70105 WindTunnel TSeries Bagless Upright Vacuum Logo
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
