Question about RCA DRC69705 7"" DUAL SCREEN PORTABLE DVD PLAYER-RCADRC69705: Electronics"
Dvd player keeps rewinding dvd - RCA DRC69705 7"" DUAL SCREEN PORTABLE DVD PLAYER-RCADRC69705: Electronics"
Magnavox dv220mw9 the vcr player won't play
Someone will have to open the unit to see what is happening---either tape is not loading all the way or when FF or Rewind hit not moving the reels----could be as simple as a belt or a bad drive idler (most use either a rubber wheel or gears to move the tape in Play, FF, and Rewind.
Dec 03, 2012 | GoVideo VR4940 DVD Player/VCR
DVD player won't play new movies
Try this
1.While the previews are playing, press the Menu Button on your DVD player remote to access the DVD's Main Menu.
2.Go to Scene Selection and press your Enter or Ok button on your DVD player remote.
3.Highlight Scene 2 and press the Enter or Ok button. This will start the DVD in Scene 2.
4.Use your rewind or reverse button on your DVD player remote to rewind back to the beginning of Scene 1.
Walt Disney Home Entertainment Technical Support
1-800-723-4763, Monday's 9:30-7:30 and Tuesday through Friday 9:30-6:30 CST
Excerpt from email tech support Walt Disney
Dec 07, 2007 | RCA B27TF680 27 in. TV/VCR/DVD Combo
Rewind and fast forward dont work
either a bad belt if used or the drive idler with this function is worn or slipping. It is called a transport problem.
Jun 12, 2012 | Samsung DVD-VR357
Video cassette player/recorder LGRC 689D wont rewind properly
The problem is in the idler assembly inside the machine, some use rubber that dry out and crack, or there is a spring loaded double clutch wheels that get weak over time. In order to fix this the idler assembly must be replaced.
May 04, 2012 | Televison & Video
I lost the remote control, how can rewind the hsv tape. Thanks.
There should be a rewind button on the front of the main unit (usually indicated by either REW or 2 arrows pointing to the left), this should be next to the fast forward (again indicated by either F-FWD or 2 arrows pointing to the right) as well as PLAY and STOP - for the VCR. The only thing you would need the remote for is to set the clock and/or perform setup for the DVD player as well as timer recording. Try a universal remote which will make fast forward, play, stop, record (to VHS) and rewind easier.
Apr 11, 2011 | JVC DR-MV7 DVD Recorder/VCR
DVD player will not recognize DVDs
restoring the factory setting may solve your problem
for your model you should press Fast Forward and fast Rewind buttons at front panel simultaneously for at least fifteen seconds
i hope this will work
regards,
cseian
Jun 14, 2010 | Samsung DVD-V4600 DVD Player/VCR
Vcr tape keeps jamming after auto rewinding. and cant remove tape w/out damaging film
the problem is from the video head player,(the round shining silver metal) in the vcr,it needs servicing which can only be done by a vcr technician,so you have to consult the nearest technician in your area for assistance
Mar 01, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
On VCR, rewind is intermittent.
The motor is wearing down. I am guessing that this is a old VCR without a flying erase head. Time to start thinking of a blu-ray player (100$ now) or a dvd player, if you do not have a new 1080p tv.
Jun 28, 2009 | Electronics - Others
Parental control password for HM600D DVD Player
The default password is using the FAST FORWARD AND REWIND buttons, it is forward, back forward, back.
Jul 08, 2008 | Starlite HM600D DVD Player
Durabrand PVD709
You have a bad tact switch behind the front panel rewind button.
Sep 18, 2007 | Sony DVP-NS575P DVD Player
RCA DRC69705 7"" DUAL SCREEN PORTABLE DVD PLAYER-RCADRC69705: Electronics" Logo
57 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
