Question about Toro Zero Turn TimeCutter MX Series MX4260 23 HP Kawasaki 42 Fabricated Deck 74640
Toro timecutter42 blades squealing and won't turn
Thought it was the pto giving problems before
  • Toro Master
  • 2,760 Answers
Just had a guy tuesday bring me a zero turn that did the same thing xcept his fell off his trailer ramp and bent one of the blade spindles so now blade digs into cover , engine off blades spin sort of free?
Posted on Jun 05, 2014
2 Suggested Answers
  • 6468 Answers
SOURCE: toro riding lawn mower pto switch not engaging to turn blades
see if you have power and ground to the connector that goes to the clutch it could be a bad safety switch
Posted on May 22, 2012
TORO 120 DIES IN FORWARD OR REVERSE WITH OUT PTO ENGAGED PROBLEM JUST STARTED
Initial thought is carb problem. I would look at the choke being stuck first. If not then possible debris in it. I would suggest a rebuild and cleaning of the carb then.
Jul 15, 2016 | Toro Garden
I have a Toro 42 zero turn mower and the blades stop turning while mowing. The PTO switch knob melted. I replaced the PTO switch and the blades turned for 5 min. and then the PTO switch melted again.
Elertric blade drive clutches are a real pain when they go wrong
It sounds like a electrical short is causing the wires inside the switch to heat up beyond the safe melting point thereafter five mins the circuit gets between the fault gets broken as the switch fails the blades stop and the switch melts a bad eaRth corroded may cause this check the deck safety switches are not exposed e.g. they been damaged and the decks metal is shorting them out
a wire has been stripped of protective covering and is touching some metal shorting out something that vital to the blade controls operation the switch is getting a overload and subsequently melting your might need an lawnmower engineer to diagnose to the fault fully and repair
Apr 23, 2015 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
My pto is on all the time on my Toro zero turn. Blades are engaged when I start the engine even though the switch is in the off position? What would cause this?
Haven't had your particular problem, but my my blades would not turn when I pulled the PTO control knob. Turned out to be a bad PTO switch. Mechanic replaced the switch and it worked fine thereafter.
Dec 26, 2014 | Toro 42'' Zero Turn Lawn Mower 22hp Kawa...
Why doesn't my Toro z master PTO not engage
check to see if pto will engage if not check voltage at pto if non blown fuse if fuse not blown and power to pto bad pto jump the pto at pto with battery in mower does it start pto if does good pto have to check volts at switch check there start with that let me no what happened
Sep 04, 2014 | Toro 60'' Com Zero Turn Lawn Mower 27hp...
Timecutter z4200
If you were able to jump start mower then the problem lies with the battery connections or battery itself
Jul 11, 2014 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
you have burned out the reel bearings replace them and, always keep them lubricated
May 07, 2014 | Toro Zero Turn TimeCutter MX Series MX4260...
Hi I have the YTH2348, the problem i'm having is i'm getting a bearing sounding squeal when i have the blade clutch engaged. I noticed before it starts to squeal I'll hear a like loud click and...
if its an elect pto then it sounds like its in the workings of the pto pully
also if its a manual lever that you move to engage the belt, it could be the pully that tightens up the belt and turns the blades, most of the pullies are greaseless and prettymuch throw away
Jul 25, 2011 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Toro mower is blowing 30 amp fuse
Yes it is. It is an electro-magnetic device that 'grabs' your blade pulley, that normally free wheels, to turn your blades when there's power to it. Dwain
May 24, 2009 | Oregon Scientific Electric PTO Clutch for...
Toro Zero Turn TimeCutter MX Series MX4260 23 HP Kawasaki 42 Fabricated Deck 74640 Logo
125 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
