Question about Samsung Dryers
What would make my Samsung dryer model # DV350AEW/XAA run for only 2-3 minutes and not dry my clothes
It is only running for 2-3 minutes cutting off and my clothes are not dry
  • 17 Answers
SOURCE: Error Code
Here's some magic help on the dryers: I have a duet sport- Whirlpool hides the complete service manual inside the cover at the bottom front of the machine- remove the bottom 2 screws, drop the cover & you have all test & service instructions--- (:
Posted on Dec 16, 2007
maklean
  • 1665 Answers
SOURCE: Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
http://www.repairclinic.com/0088_8_1.asp
Heating element Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it.
Type in model No at search tab to find parts availability
http://www.repairclinic.com/SmartSearch/SmartSearch.aspx
Posted on Jul 15, 2008
  • 686 Answers
SOURCE: Can I run the dryer vent vertical and how high?
yes
Posted on Apr 08, 2009
  • 20 Answers
SOURCE: dryer stops after 2 min run
change its thermistor.
Posted on May 23, 2010
  • 291 Answers
SOURCE: have a samsung dryer model DV209AEW/XAA. I "hand
Check to make sure your child lock is off first. Hold the time and signal buttons simultaneously for three seconds. Unlikely, but do check. Some of these dryers have a safety switch that the idler pulley has to engage to allow the dryer to run. I tried to find a schematic for this model but could not get one to tell if you do have a safety switch. Look at the arm of the idler pulley and see if it is contacting the switch actuator correctly. When a belt breaks or pops off, sometimes the arm of the pulley will move to the other side of the switch actuator and will not allow the dryer to run once a belt is reistalled. I would also look to see if a wire was knocked off of the motor switch when your belt came off. Good Luck, Appliance Specialists
Posted on Dec 03, 2010
I have Samsung gas dryer model DV410. no heat, replaced two thermal fuse and hi low limit. Now it only works with timed cycle mode. the rest mode, it runs only for least the 5 minutes and shut off.
timed cycle mean dryer not on sensor dry mode. check wire connection on moisture sensor bars (i think you forget to put 2 wire connector put together). when you use other cycle dryer use moisture sensor to dry cloths so sensor not working dryer will stop in 5 minutes or so because dryer think there are no wet cloths to dry. hope this help you.
May 02, 2017 | Samsung Dryers
WHY DOES MY SAMSUNG MODEL DV448AEP/XAA SENSOR DRY MODE RUN FOR TWO MINUTES AND THEN WILL GO TO COOL DOWN MODE, ALL OTHER DRY CYCLES MANUEL AND STEAM CYCLE OPERATE FINE!
Sensor is screwed or the timer relay for that part of it is not working . Go to an appliance store to get wiring diagrams ordered and might even know about the problem w that model
Feb 19, 2015 | Samsung Dryers
Kenmore dryer 90 series
Since no model number was given, check to see if you have a setting commonly noted as "wrinkle guard", "wrinkle shield", "press care" or something to that affect. Those settings will run the dryer for as much as 90 min after a completed drying cycle to prevent wrinkles in clothing, allowing you time to remove the cloths after a dry cycle if you are busy. Pleazer Appliance...
Apr 09, 2014 | Dryers
Thumping noise while running
Chunk of rubber missing from the drive belt.
Jan 21, 2014 | Samsung Dryers
Samsung Dryer starts for 5 seconds then stops, but drying time still counts down.
I got the same problem and I tried to take off the belt let see the motor still running by itself but it still run for couple second then stop.
Jun 12, 2012 | Dryers
SAMSUNG --MODEL# DV3C6BEW/XAA NOW COMPLETELY SHUT OFF. CAN NOT TURN ON OFR OFF EARLIER -NOT HEATING PROPERLY, TAKES A WHOLE DAY TO DRY CLOTH.. IF YOU SET DRYER TO 60 MINUTES, IN 15 MINUTES, IT...
dryer has a restriction in the venting process; disconnect vent hose and run dryer should work, if not then you will need to take apart and clean out all the lint inside the dryer.
washer:
http://www.ehow.com/how_4910369_troubleshoot-washing-machine.html
Jan 11, 2011 | Samsung Dryers
Dryers Logo
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
