Question about Universal 48025, UNV48025 - 48025 Heavy-Duty Strip-Cut Shredder, 25 Sheet Capacity
Where is the reset button on universal 48025 schredder
I have a 2014 Chevy Silverado and want to unprogram or reset the remote garage door opener. I don't see anything anywhere about resetting it. Should I remove the positive battery lead for awhile?
See the link section 5- page 54 for the procedure.
Universal Remote System Operation Using the Universal Remote System Press and hold the appropriate Universal Remote system button for at least one-half second. The indicator light will come on while the signal is being transmitted. Erasing Universal Remote System Buttons Erase all programmed buttons when vehicle ownership is terminated. To erase: 1. Press and hold the two outside buttons until the indicator light begins to flash. This should take about 10 seconds. 2. Release both buttons.
Reprogramming a Single Universal Remote System Button
To reprogram any of the system buttons: 1. Press and hold any one of the buttons. Do not release the button. 2. The indicator light will begin to flash after 20 seconds. Without releasing the button, proceed with Step 1 under "Programming the Universal Remote System.
Hope this helps?
https://www.chevrolet.com/content/dam/Chevrolet/northamerica/usa/nscwebsite/en/Home/Ownership/Manuals%20and%20Videos/02_pdf/2k14silverado.pdf
Oct 03, 2016 | Building Materials
Instructions to control samsung t v
Try Pairing procedure:
  1. TV off
  2. Bring remote within 3 feet of TV
  3. Push Pairing button (Paper Clip or other pointed object in button hole)
  4. Turn on TV
  5. Should be paired. Try remote channel or other buttons.
  6. If not, try 2 more times.
  7. If still not working, push RESET button first and repeat Pairing.
Samsung remotes for LED / LCD TVs are generally RF, not IR.
Most Universal remotes do not generate RF signals, so disregard advice about codes for Universals.
  1. TV off
Within 3 feet of TV
PAIRING and RESET buttons:
Dec 08, 2015 | Samsung Televison & Video
The schredder runs backward, but forward does not.
Take care, because this thing can also shred your fingers.
Remove the plug from the outlet and try to remove the paper under the rolls. Us a tool, not your fingers. It even would be better, if you could put the top upside down, so you could see where the bulk of paper is clothing the wheels and the sensor.
I think you already emptied the bag under the shredder, because the paper full sensor also prevents the shredder from running forwards.
Jun 16, 2014 | Intimus 421 SE Shredder
Universal Remote: UR5U-8780L - Not Working and CBL Button Constantly Lit
press cable and record buttons at the same time and wait for all the lights to flash in sequence then let go. this will reset remote to factory defaults. then reprogram remote with codes for each device.here is a site for codes. http://www.universalremote.com/resources/pdfs/UR5U-8780L_UR5U-8790L.pdf
May 25, 2012 | Universal Remote Control Televison & Video
My schredder is jammed. I may haveput too many paged in it.
The industry trick is to soak the jammed paper with hot soapy water for 2 days.
Nov 29, 2009 | Office Equipment & Supplies
PArts
I am nin need of a motor for a royal shreader
Aug 03, 2009 | Royal 15MX Shredder
Royal AG15X schredder stopped working after I tried schredding some stupid charity solicitation that apparently had a coin inside the envelope!! I'm think a fuse might have popped or something; I've taken...
I am wondering if you have something that is jammed. Is there any way you can get into the unit to turn the cutters manually? If so try to turn them backwards first and see what happens. Good luck. Unplug it to do this.
Aug 22, 2017 | Royal AG15X Shredder
Can't get rid of clock dispaly
Without the original remote or a universal remote that does not have a display button, try unplugging the television for at least 2 minutes and plug the tv back in. This should reset the tv. If the universal remote has a display button, depress the button until you get the desired display results.
Nov 05, 2008 | JVC AV-36D503 36" TV
Universal 48025, UNV48025 - 48025 Heavy-Duty Strip-Cut Shredder, 25 Sheet Capacity Logo
46 people viewed this question
Top Universal Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you an Universal Office Equipment and Supply Expert? Answer questions, earn points and help others
