Question about Admiral 3.4 cu. ft. Top Load Washer in White ATW4675YQ
Thinking of buying Admiral ATW4675YQ; is this a good machine?
Washer shakes bad with large loads
then get out your level and relevel it or do smaller loads
Sep 01, 2015 | Admiral 3.4 cu. ft. Top Load Washer in...
Why won't my washing machine stop cycling?
Sounds as if somehow machine got placed in continuous wash mode you have an F5E4 code tells me you know how to enter diagnostics go to diagnostic turn the knob till wash, rinse, and done are lit press the start button washer should not start and lights should go out unplug washer and wait 10 seconds plug back up should not start if not then you are done if so repeat process
Jan 14, 2015 | Admiral 3.4 cu. ft. Top Load Washer in...
HOW CAN I SOAK OVERNIGHT
... Wow. I can't believe people on this website are serious. Okay Mr. Caps lock. STOP THE WASHER WHEN IT IS ON THE RINSE/FILL CYCLE. LET **** OVERNIGHT. IT'S NOT ROCKET SCIENCE.
Oct 31, 2014 | Admiral 3.4 cu. ft. Top Load Washer in...
Washer not even 1 year old does not wash
Good morning.
The manufacturer provides a one year warranty. What exactly is the question? Perhaps Fixya should screen these comments before sending them out as questions to be answered.
Take care and have a good day.
Rich Seyfert
Jul 11, 2014 | Admiral 3.4 cu. ft. Top Load Washer in...
How to fix it!
change/check water lever switch
Jun 14, 2014 | Admiral 3.4 cu. ft. Top Load Washer in...
Admiral dryer timer not turning and no heat
It could be the high temp fuse on the element and the timer not turning depends doyou have it on the auto dry because it will not advance if it is not heating because the sensors are not detecting a decrease in the humidity levels because the element not working.
Mar 14, 2014 | Admiral 3.4 cu. ft. Top Load Washer in...
WONT DRAIN OR SPIN
Check lid switch and plastic tag on lid that operates the switch.
Switch can be shorted out to test operation, if machine spins, replace switch, do not leave shorted.
Aug 24, 2013 | Admiral 3.4 cu. ft. Top Load Washer in...
Admiral atw4675yq doesn't dispense warm water
Guest,
So I was lucky enough to buy the extended warranty with your same unit and when I noticed the same issue, I called the technician.
What he tells me is that this time of year, city water is too warm to require the addition of hot (71 degrees as read at the flow). Apparently to meet the Energy Star requirement, the temperatures were lowered from what they used to be.
He suggested that I wait until Dec/Jan until my cold water temp gets into the 60s and then listen for the hot to kick in intermittently.
From what I have read on the web from other customers of various other makes and models, this problem does not seem to be restricted to Admiral.
Hope that helps. Take care and have a good day.
Mar 14, 2013 | Admiral 3.4 cu. ft. Top Load Washer in...
Admiral 3.4 cu. ft. Top Load Washer in White ATW4675YQ Logo
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
