A
Anonymous Posted on May 07, 2014
Why does my computer say the door is open on my printer when it is not
Mp c5502. Why does it keep displaying 'door open' even though it's closed?
Sometimes Door open error shows in printer even if it is closed .
Follow This steps to Fix Open Door Error Message:-
*Close the cartridge access door completely.
*Check the cartridge door for obstruction.
*Reset the Printer
*Restart the Print Spool Device.
*Restart the computer.Restart the Printer.And If you are using Brother Printer And You Encounter With Brother Printer In Error State Windows 10 Issue then Read The Blog I Am Mentioning above.
HP PhotoSmart computer indicates "open door"
Open "Devices and Printers" in start menu.
Right click printer with green arrow - click see whats printing.
Delete all documents.
Restart computer - then restart printer
See if that clears your error messages.
"Printer Door Open"
Uninstall then re-install the printer?
2answers
It keeps on sayin my access door is open but my printer doesnt have a rear door
Access door is usually the one that opens to allow the insertion of new cartridges. Try opening and closing that one and restarting the device after completely unplugging from the mains and waiting 30 secs.
Please rate this answer!!
Cheers
Bob
Reads printer door is open when it is not open
Try restarting computer, I helped a friend with this issue and she is printing now.
I helped a friend with this, I just had her to restart her computer and she is now printing.
Printer light blinking. error message when I click on hp 3650 icon. ''printer door open'' can you advise? I rebooted computer.
when printer door open then printer carrage is unlock position? if you are right so your cartridge is ok other wise you change cartridge
or properly lock
1helpful
Printer says door open
aah simple solution to that modiboni. you need to check if the printer door is still open but youv already tried that im sureoption 2 im not to sure on your printer but when you open the door chek to see o protruding plastic that will activate a switch to say the door is closed if you see that the plastic is broken use a small item to push down the sensor and it hopefully should read that the printer door is closed.
1helpful
2answers
Printer Door
I have that exact problem at work. There is a bump on the right side of the lid...and when you close the lid it presses on a lever. Check and see that the bump actually pushes that lever downwards. That's how the printer determines that it's closed.
k24674
Grand Canyon Tech
Grand Canyon Tech
