Question about Husqvarna Forest & Garden 125c 17" Curvgastrimmer
I may have fed the string on the wrong way. I tapped the button to get more thread and it siezed . How do you get that head off?? I don't have a manuel.
  • 59 Answers
It is a left hand thread
Posted on Jun 23, 2009
Ryobi gas powered string trimmer
head threads are left hand thread so in effect you have to "do it up" to unscrew it
Apr 15, 2017 | Ryobi Garden
How do I thread the singer 132k6 including the bobbin. is there a diagram i may see
Hope this sight will help if not you may have to contact the manufacturing company for owners manuaql
Jan 09, 2015 | Singer Sewing Machines
How to feed trimmer line on y25 yard trimmer gas
Depending on what type of string head you have. If it's a "tap and go" style head, just rev it up full throttle and tap it on the ground. It should feed the string out and the blade on the shield will cut off the string to the correct length.
Sep 22, 2012 | Yard Machines Gas String Trimmer Y25
The spline for my Poulan TE475 WeedEater comes out during start up and wraps around the shaft. I use .080 round spline. It started recently to do this.
The string head on these units is very poorly designed. There is hardly anything in the head to retain the line. I suggest removing the stock string head and going to Home Depot and getting a replacement Universal type head or one for the Ryobi or Homelite They are basically interchangeable. Check the length available on the shaft end (threaded part) after removing the head.Use a large wrench or pliars to hold the dust cap when you unscrew the head. If you feel the driveshaft turning, don't continue turning head or you will break the flex driveshaft.
Jun 30, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
Homelite trimmer, gas, string - y is the string wrapping itself around the head of the trimmer?
The line on my new 26cc Homelite would also feed out by itself. That started me thinking the line was wound backwards. I wrapped the line in the opposite direction as was shown on the bump feed reel and now the dang thing works although the bump feed needs to be "bumped" pretty hard to work. Is it possible that the reel was manufactured with the (string direction) arrows pointing the wrong direction? The new 26cc unit is also underpowered compared to my older 25cc trimmer.
Jul 20, 2010 | Homelite Factory Reconditioned 26cc...
;How do you lengthen the string? (Have the grass
To lengthen the string:
- Turn the Grass Hog upside down
- Push in on the two release buttons on either side of the spool (they're orange)
- Pull the spool head off and spin it to release more string while you pull the string with your hand (make sure it is still fed out through the hole in the base)
- Pop the spool head back into place
Test the Grass Hog to make sure the string is not too long. If it is you'll hear it cracking against the plastic guard on the base.
May 02, 2010 | Black & Decker Cst2000 12 - Volt Cordless...
Cross-threaded spark plug threads on 2007 stratoliner 1900. right , rear cylinder. What can be done without removing the head?
You need to get hold of the correct "TAP", with a get deal of care re-tap the original thread. Then replace the spark plug and all should be well.
Feb 02, 2010 | 2007 Yamaha Stratoliner
Need help restringing it
For starters, if you don't have the original, in-the-box trimmer thread, you should get the appropriate diameter. Ez enough, you just need .9 to .10 diameter thread are somewhere around that diameter.
Which attachment are you trying to restring, there are several. One will have holes for a "fixed string" with a label that says "stop" on it. This is the fixed string attachment head. Take a piece of fix string, these are pieces of precut string that come with various other tidbits in the box, about 10-12 inches long. insert the string through the head the inserted end comes out the other side. Pull that end out to the edge of the "stop" label. Repeat the process for the metal hole on the other side. That's it, now you are ready to go.
The other trimmer head is a bit more difficult. Unscrew the top sleeve to expose the bare, 2 chambered core - have replacement or original thread ready to go (same diameter as mentioned previously). Once you have removed the top, notice that there are two holes with notches in between the 2 thread chambers. The notches will indicate which chamber you will be sending the thread that will be coming through the holes. Have the thread ready to go, and insert one end all the way through the hole on one side and then out the other. Now you must get the string ends coming out more-or-less equidistant from the two attachment holes so that you get an equal balance of thread being fed out of the head - either with helper holding the attachment head or by just hooking the attachment head around a pole or something, pull the 2 threads through to get them equidistant.
Once you've done this, follow the notches at the respective holes to wind the thread into the proper chamber, as if it were fishing line. Finally, put the head sleeve back
For the other trimmer head
Aug 18, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
I need to remove the head from my poulan pro ppb 250e. How do i do that.
After all the bolts have been removed from the head, tap all the way around,(http://www1.mscdirect.com/CGI/NNSRIT?PMPXNO=4760615&PMT4NO=65151144), where the head meets the bottom of the motor. It will come off with a little coaxing.
Jim
Jun 09, 2009 | Poulan Garden
Husqvarna Forest & Garden 125c 17" Curvgastrimmer Logo
182 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Tim Whalen
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
