Question about Dynomax 2000 - 2001 Oldsmobile Bravada Exhaust System Kit 19331 Olds
HOW DO YOU CHANGE THE IGNITION LOCK?
HOW DO YOU CHANGE THE IGNITION SWITCH TUMBLER IN THE STEERING COLUMN?
Replace ignition switch
Have to pull steering wheel,column lock ,cam switch and there is a bolt to remove which will allow u to change tumbler. the actual switch is on top of the column by the pedals operated by a rod
Nov 09, 2013 | 1999 Chevrolet S-10 Pickup
Do i have to remove the steering wheel to change the ignition switch on a 2002 cavalier
Ignition switch located half way down steering column.
Ignition tumbler (Where you insert the key) Need to remove steering wheel, if tilt steering need remove c clip, then there is a hex bolt securing the tumbler.
Ignition switch is a bit more involved.
hope this helps, James Booth
May 17, 2011 | Chevrolet Cavalier Cars & Trucks
Key stuck in ignition -- cannot turn on or off. Can an ignition switch cause the tumbler to lock up? Or does the ignition tumbler need to be replaced? If the ignition tumbler needs to be replaced, how...
lets start simple.get a can of silacone spray oil and spray into the switch and keep moving key and you will find this will reliese the key,if you need to remove the ign switch dont panic as its a simple enough job.Forget about steering wheel and whatever,simply remove the outer plastic cover then this exposes the switch at the back of switch is a plug with wires pull it away ,then below the key you should see a tiny screw undo, and make sure the steering lock is not under pressure,ie steering wheel free,when trying to remove switch move steering wheel back/forward and switch should pull out.good luck.adrian,,,,
Nov 25, 2010 | 1988 Chevrolet Celebrity
How do i remove the steering column cover to get at the ignition tumbler on a 1993 dodge dakota
CAUTION Disconnect and isolate the negative (ground) battery cable. This will disable the air bag system. Failure to disconnect the battery could result in accidental deployment and possible personal injury. Allow the system capacitor to discharge for two minutes then begin air bag system component removal. To install:
  1. Engage the electrical connectors to the ignition switch and make sure the switch locking tabs are fully seated.
  2. Before attaching the ignition switch to a tilt steering column, the transmission shifter must be in the PARK position. Also the park lock dowel pin and the column lock flag must be properly indexed before installing the switch as follows:
    1. Place the transmission shifter in the PARK position
    2. Place the ignition switch in the LOCK position. The switch is in the lock position when the column lock flag is parallel to the ignition switch terminals.
    3. Position the ignition switch park lock dowel pin so it will engage the steering column park lock slider linkage.
    4. Apply a light coating of grease to the column lock flag and the park lock dowel pin.
  3. Place the ignition switch against the lock housing opening on the steering column. Ensure that the ignition switch park lock dowel pin enters the slot in the park lock slider linkage in the steering column.
  4. Install the retaining bracket and ignition switch mounting screws, then tighten the screws to 22-30 inch lbs. (3-4 Nm).
  5. If the vehicle is equipped with a tilt steering column, install the tilt lever.
  6. With the key cylinder and the ignition switch in the LOCK position, insert the key cylinder into the ignition switch until it bottoms.
  7. Insert the ignition key into the lock cylinder. While pushing the key cylinder in toward the ignition switch, rotate the ignition key until the end of travel.
  8. Install the retaining screw into the bracket and lock cylinder. Tighten the screw to 22-30 inch lbs. (3-4 Nm).
  9. Install the steering column covers, then the tilt lever, if equipped.
  10. Connect the negative battery cable.
  11. Check for proper operation.
Jul 30, 2010 | 1993 Dodge Dakota
Cant get key switch out of housing, on a 1974 chevy pick up.Trere are no screws or clips visible.
If you mean remove the ignition tumbler from the steering column, you will have to remove the steering wheel and lock plate, then you will need to remove the turn signal lever and screws, and then pull the turn signal switch up and out of the way, you should then be able to see the housing for the ignition tumbler down in the steering column. Look at the tumbler housing and there should be a small slot towards the end of the housing that you can put a small standard screwdriver into and depress a locking latch that is built into the tumbler. When this latch is depressed you will be able to pull the ignition tumbler straight out of the column.
Apr 19, 2010 | 1986 Chevrolet Chevy
Was replacing the ignition switch and accidently broke off a silver piece off of where the switch goes connected. Can you some one tell me if this can be replaced and if I have to replace the entire key...
Replacing An Ignition Switch..
If The Ignition Switch Is Defective, It Must Be Replaced Regardless. Before Removing A Dashboard-mounted Switch, The Tumbler (Lock Mechanism) Must Be Removed From The Switch.Normally A Small Piece Of Wire Is Inserted Into A Hole IN The Front Of The Switch And The Key Is Turned.This Will Release The Tumbler From The Switch So The Tumbler Can Be Pulled Free. Then Unplug The Wires And Remove The Old Switch.
A Steering Column-mounted Ignition Switch Is Separated From The Tumbler. It Is Normally About Halfway Down And On Top Of The Steering Column. To Remove This Type Of Switch, Remove The Fasteners Holding The Steering Column To The Dash. This Will Let The Column Drop Down So You Can Replace The Ignition Switch.
Apr 09, 2010 | 1999 Dodge Caravan
How do I replace ignition switch in a 1995 suburban. I need to replace the tumbler. is it the kind that has the screw behind the turn signal switch behind the steering wheel, with a retainer screw to the...
1 disconnect the negative cable at battery
2 place the ignition switch in the lock position. if the key lock cylinder has been removed, pull the actuating rod up until a definite stop can be felt then move down one detent
3 lower and support the steering column
4 remove the ignition switch retaining screws and lift the switch out of the steering column jacket
5 prior to installation, make sure the ignition switch is in the lock position
6 connect the accuating rod to the switch
7 press switch into position and install screws
8 install steering column bolts
Nov 17, 2009 | 1995 Chevrolet Suburban
1990 FORD F150 IGNITION SWITCH PROBLEM
You may need a new steering column or your ignition lock cylinder might be bad
Aug 12, 2009 | 1990 Ford F150
Need instructions on how to change ignition switch on the steering coloumn of a 1974 chevy truck
how do i change the lock ignition on a 1986 chevy truck. got the lock ring off but the steering wheel will not come off
Jul 13, 2009 | 1986 Chevrolet Chevy
Remove ignition tumbler
lock cylinder removal
Section 11-04: Steering Column 1996 Escort, Tracer Workshop Manual
REMOVAL AND INSTALLATION Ignition Switch Lock Cylinder Removal
  1. stf~us~en~file=ani_caut.gif~gen~ref.gif WARNING: THE ELECTRICAL CIRCUIT NECESSARY FOR DRIVER SIDE AIR BAG MODULE DEPLOYMENT IS POWERED DIRECTLY FROM THE BATTERY. TO AVOID ACCIDENTAL DEPLOYMENT AND POSSIBLE PERSONAL INJURY, THE BATTERY GROUND CABLE MUST BE DISCONNECTED PRIOR TO SERVICING OR REPLACING ANY DRIVER SIDE AIR BAG MODULE SYSTEM COMPONENTS.
    Remove the steering wheel (3600). Refer to the procedure in this section.
  1. Remove the multi-function switch (13K359). Refer to Section 11-05 for the removal procedure.
  1. Disconnect the ignition switch electrical connector.
  1. Remove the ignition/shifter interlock cable mounting bracket bolt and position the ignition/shifter interlock cable mounting bracket and the ignition/shifter interlock cable (3F719) aside.
  1. Remove the four steering column upper mounting bracket bolts and lower the steering column (3C529).
  1. Use a hammer and chisel to make a groove in the head of each of the two ignition switch lock cylinder bracket bolts.
  1. Remove the two ignition switch lock cylinder bracket bolts with a screwdriver and discard the bolts.
  1. Remove the ignition switch lock cylinder and the ignition switch lock cylinder bracket.
Installation
  1. Position the ignition switch lock cylinder and bracket and install two new bolts, tightening them only enough to hold the ignition switch lock cylinder in position.
  1. With the key in the ignition, verify the operation of the ignition switch lock cylinder. If necessary, reposition the ignition switch lock cylinder until it operates properly.
  1. Tighten the ignition switch lock cylinder bracket bolts until the bolt heads break off.
  1. Position the steering column and install the four steering column upper mounting bracket bolts. Tighten the steering column upper mounting bracket bolts to 9-14 Nm (80-124 lb-in).
  1. On vehicles equipped with tilt column, remove the upper mounting bracket retaining pin.
  1. Position the ignition/shifter interlock cable mounting bracket and install the bolt. Tighten the ignition/shifter interlock cable mounting bracket bolt to 4-6 Nm (35-53 lb-in).
  1. Connect the ignition switch electrical connector.
  1. Install the multi-function switch. Refer to Section 11-05 for the installation procedure.
  1. Install the steering wheel. Refer to the procedure in this section.
  1. Inspect the shift interlock system. Refer to Section 07-05 for the procedure.
Apr 07, 2009 | 1995 Mercury Tracer
Dynomax 2000 - 2001 Oldsmobile Bravada Exhaust System Kit 19331 Olds Logo
65 people viewed this question
Top Dynomax Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Dynomax Measuring Tool and Sensor Expert? Answer questions, earn points and help others
