Question about Gestetner Office Equipment & Supplies
C7417n color yellow not found
If black ink is out, will copy in color possible from pc? Also how do I reset this printer?
Dear
Since the model is not found, its difficult to say. however in most cases the subtractive colors are used ie cyan,magenta and yellow. with mixing these white is produced but in case of basic color used ie. red,green and yellow, on mixing these black color is produced. Mostly cyan, magenta and yellow is used hence you can not produce black color so the a complete color print not possible.
Thanks.
Mar 17, 2015 | Office Equipment & Supplies
I cannot see red and yellow in my print
Take supply status page.. check all colors..> check supplies >any colors found dull or un even density clean laser scanner assm..> if any color missed do the calibration/set factory default settings..> Mechanical alignment disturbed, Professional only can perform this activity..
Oct 22, 2011 | HP Color LaserJet 2600n Printer
My Printer Aficio C7417n is displaying error SC486
Open the front door , The blue clips {} on each side
hang them up and remove the paper which stucked into your printer
then put down the clips
and close the front door
it's done 4 me , hope it'll be the same for you
and sorry for my bad English :)
May 26, 2011 | Gestetner C7417 Laser Printer
I need a copy of the wiring diagram/color code for the colby stereo system in a 90-FORD AEROSTAR
90 Ford Aerostar Colby Stereo System
Wiring color code:
Speaker Power Ground
Left Front Orange/light green Light Blue/white
Right front White/light green Dark green/orange
Right Rear Tan/light green Brown/black
Left Rear Tan/white Tan/yellow
Other Wires:
Yellow/black = Hot - Key On
Light green/yellow = Hot - Direct to Battery
Light blue/Red = Radio lights
Black = Ground
Black/light green = Ground
This is what I found for you,hope it helps. Good luck.
Sep 26, 2010 | Car Audio & Video
Canon Pixma yellow color problem
Either the ink you are using is not going to give the color you want, or you have print heads that are blocked.
Mar 11, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
I M NOT GETTING FULL COLOURS IN THE COLOURED PRINT ?
tell me details about color.
Print Cyan, Magenta, yellow and Black color........ have you found any change ?
Inform me
Thanks
Oct 27, 2009 | HP DesignJet 90 - printer - color -...
Sharp AR-C240P Printer Prints Everything with red cast
iF YOU HAVE NOT CHANGE THE DRUM TRY IT. FOR ANY COLOR THAT IS RUNNING OVER POWERING.
Jun 23, 2009 | Sharp AR-C240P Printer
Bad yellow cast to photos when printed
If you have a yellow cast to your photos, the problem might not be your printer. If you're using a digital camera, indoors under incandescent lighting without a flash your pictures will look yellow.
If this is the case, set your camera's White Balance to Incandescent lighting or use the flash. If all of your pictures, even those taken in daylight, look yellow you'll have to adjust the colors on your printer using the "toolbox" software that comes with it and back the yellow off. I've found that HP printers tend to have better color rendition than Canon.
May 24, 2009 | Canon Office Equipment & Supplies
Vertical line down left side of page aprox 2" from left side con
when I opened the front door to the cartridge compartement there was a green line of toner on the feed belt, I wiped it off. then I slightly closed the door to open the toner cartridges and found the one creating the mark and cleaned it.
no more line
Dec 27, 2008 | HP Color LaserJet 2600n Printer
Dell 3200 Projector color green instead of yellow on VGA not on S-Video
I have found that the S-Video port has the correct colors, but the VGA port has green inplace of yellow. I believe the VGA port on the projector is the problem. I don't know how to replace the VGA port or if it can be replaced. Thanks D. James, tweezers.
Mar 29, 2008 | Dell 3200MP Multimedia Projector
13 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
