Question about Globe GPS10 10lb Portion Scale - Digital
Globe gps10 out message - Globe GPS10 10lb Portion Scale - Digital
Where is globe message center located
Google area code and it will give u info
Jan 21, 2015 | Cell Phones
What is the gprs/mms setting for sony ericsson X8? my network provider is globe philippines. i went to their customer service but even the representatives there can't help me with my problem.
Just follow this Guidelines
GPRS SETTINGS
1. Go to Menu>Choose Settings>Connectivity
2. Go to Data Accounts
3. Create New Account. GPRS/ PS Data
Account Name: MyGlobe GPRS
APN: www.globe.com.ph
4. Save Account
5. Go to Browser, Slect Options and click Internet Settings
6. Add New Profile
Connect Using: MyGlobe GPRS
IP ADDRESS: 203.177.042.214
ADVANCED
Chg. Homepage: MyGlobe GPRS
Address: http://www.globe.com.ph/globe.asp
Save Profile
MyGlobe Internet Settings
Account Name: MyGlobe INTERNET
APN: internet.globe.com.ph
4. Save Account
MyGlobe MMS Settings
Account Name: MyGlobe MMS
APN: mms.globe.com.ph
4. Save Account
5. Go to Messages>Picture Messages>Option>Internet Profile
6. Create New Profile
Connect Using: MyGlobe MMS
7. Save Profile
8. Select the profile MyGlobe MMS in Internet Profile
9. Save Settings
10. Go to Messages>Picture Messages >Options
11. Edit Message Server
http://192.40.100.22:100.21/mmsc
12. From Message Settings, make your Internet Profile: MyGlobe MMS
Hope it helps...
Jul 15, 2011 | Sony Ericsson XPERIA X8 Cell Phone
+639170000240, +639170000247, +639170000248 smart message centers, which areas in the Philippines
Hi!! I'm sorry, but locations cannot be traced using those numbers alone unless you have Phone tracker featured on your phone. Numbers starting 0917 means they are GLOBE handy phone carriers. If you know someone living in the Philippines, you might want to instruct them to buy Globe Sim card then go to Globe Prepaid- Specials-Tracker-Person Tracker- then enter those number listed above to track where in the Philippines these mobile Globe numbers are.
Hope this helps. Thank you for using Fixya! May you have a good day.
Mar 30, 2011 | Nokia Cell Phones
Message centre posted "check stop lamp" what does
Sounds like you have a blown brake light globe. Often the brake light circuit electrical resistance is monitored and will have detected a blown globe (bulb) Have someone put their foot on the brake pedal and make sure all the brake lights are working. If not replace the faulty globe or repair the fault. Blown brake light globes on a few modern vehicles can cause many engine running faults which seem unrelated to the brake lights.
Mar 07, 2011 | 2004 Volvo XC90
How to activate my mms? globe prepaid
  • For a complete listing of compatible MMS & GPRS phone handsets — send Nokia, Ericsson or Samsung (your handset model) to 2365.
  • To get your phone’s settings, text GO (handset model) to 2951. Example, GO N3650. (For a list of compatible handsets, refer to #1) Note: For Nokia 6220, 6600, and 6820, text GO < handset model >,1234 and send to 2951. Make sure to type in the two commas before the 1234 PIN. Regular text messaging charges will apply.
  • Enter 1234 when asked for PIN to save settings.
  • Send an MMS message for only Php 5.00 to activate the service.
or
This tutorial will help you setup your mobile phone and activate/configure GPRS, 3G and MMS features for Globe Telecoms.
GPRS SETTINGS
1. Go to Menu > Choose Settings > Connectivity
4. Save Account
5. Go to Internet Settings
7. Save Profile
8. Select the profile MyGlobe WAP in Internet Profile
9. Click Right Soft Key to Choose More and Select Settings
Internet Mode: HTTP
Use Proxy: Yes
Proxy Address: 203.177.042.214
Port Number: 8080
10. Save Settings and repeat Step 9 but this time choose Advance Settings
11. Change Homepage
Title: MyGlobe
12. Save Changes
3. Create New Account. GPRS / PS Data
4. Save Account
4. Save Account
7. Save Profile
Internet Mode: HTTP
Use Proxy: Yes
Port Number: 8080
10. Save Settings
11. Click Right Soft Key to Choose More and Select Advance Settings
12. Change Homepage. Enter the following parameters and save the settings
Address: http://192.40.100.22:10021/mmsc
13. Go to Messaging>Settings> Picture Message
14. Edit Message Server : http://192.40.100.22:100.21/mmsc
15. From Message Settings, make your Internet Profile: MyGlobe MMS
MyGlobe Stream Settings
3. Create New Account. GPRS/PS Data
Account Name: MyGlobe Stream
APN: real.globe.com.ph
4. Save Account
5. Go to Streaming Settings
6. Make MyGlobe Stream your default APN.
Jun 26, 2010 | LG KP500 Cookie black on T-Mobile U-Fix...
How to open Globe gprs to Nokia 6303
GPRS SETTINGS
4. Save Account
7. Save Profile
Internet Mode: HTTP
Use Proxy: Yes
Port Number: 8080
11. Change Homepage
Title: MyGlobe
12. Save Changes
4. Save Account
4. Save Account
7. Save Profile
Internet Mode: HTTP
Use Proxy: Yes
Port Number: 8080
10. Save Settings
4. Save Account
Connect Using: MyGlobe Stream
Jun 26, 2010 | Nokia 6303 Cell Phone
Golden globe
it means you have a message on your phone. Go to the website for att and click on msg and it will go away. I had same thing and it drove me crazy. It was a message from att about getting help online.
Apr 10, 2009 | RIM BlackBerry Bold 9000 Smartphone
Olympia OL 3000 Info Globe
Dit it stop all the led messages?
Mine started to show weird messages or nothing at all.
I removed the blue top and the spinning device inside has small screws that you can remove.
I cleaned the electric contacts with alcohol and now, the globe is working again.
Nov 02, 2007 | Electronics - Others
Globe GPS10 10lb Portion Scale - Digital Logo
27 people viewed this question
Top Globe Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Globe Health and Beauty Expert? Answer questions, earn points and help others
