Question about Fellowes Office Equipment & Supplies
My power shredder W11C stopped working forwards and backwards. The power source is O K
  • 20 Answers
Dear Edward,
Most of the shredders have a micro switch that senses if the paper has been introduced to the shredding slot, or not
These micro switches are activated by a little arm/leveler that touches the paper and activates de contact inside the shredder housing.
While disconnected from the power, try to check if the switch is working properly. Check if you can hear a "click noise" while moving it back and forth by using a paper clip (or a toothpick). When this sensor arm is broken, the device will not operate since it does not detect the presence of a paper sheet to be shredded (and the power to hte motor is shut off).
If this does not solve your investigation process, please make sure your power cord is fine. Otherwise, it would be an internal electric problem in the device (obviously!!!)
One additional possibility (since I have no further details from you) is that the device is on and you can hear the motor running but the paper is not being pulled by the blades - in this case gears that move the shredder blades are most probably broken (that has happened to my shredder - and I had to dump it).
I hope this gives you some light in further investigating your problem.
Posted on Jun 17, 2014
JayBlair
  • 328 Answers
SOURCE: My Shredder does not work
Simple cleaning may solve this. Use some compressed air first on the sensors that are located just below the opening on top and in the center. Then also may be two sensors underneith the cutter blades. Make sure the power in disconnected first. Then a cotton swab to gently wipe any residue from them.
Posted on May 15, 2009
SOURCE: Our Fellowes shredder (#W11C) will
I have that problem as well after a few months of normal use
Posted on Aug 23, 2009
JackHeath
  • 1049 Answers
SOURCE: I have a tech solutions shredder. Envelope got
There is probably paper, dust, or something still in the shredder somewhere obstructing the sensor. Run it backwards for a minute or so, then turn it over and blow it out, and after unplug the shredder and plug it back in. Then see if it runs forward.
Posted on Mar 17, 2010
canontech
  • 1219 Answers
The stucked envelope may move the sensor or damadge it. You should check the sensor.
Posted on May 11, 2010
HansPP
  • 2510 Answers
SOURCE: I have a fellowes shredder
Check if the power cable was not damaged or pulled out of the connection during the mishap.
Posted on Jun 08, 2011
Where is the fuse in the fellowes w11c?
There probably isn't a fuse. Or it's a non-replaceable one.
They suggest you allow it to cool for 20 minutes, when it becomes overheated it's supposed to shut down. Then in the case of a paper jam, try reverse, if that doesn't work, try forward again.
Aug 02, 2016 | Fellowes Powershred W11C Shredder 120V,...
My shredder will only work in reverse.
There must be a button on the shredder you need to push so it works forward, this button has 2 options: forward for shredding, and backward to push caught papers out of shredder.
Jul 07, 2014 | Cross Royal 7 HT700X Shredder
My Shredder W11C stopped working suddenly both forward and backwar. The power source is O K.
if you can hear the motor working but the paper won't pull in and shred then you broke a tooth on the plastic gear. This happens when you try to shred too much at one time. It happened to me but I couldn't find a plastic gear or the company to replace the gear. I liked the machine so I made my own tooth with DEVCON home plastic welder. With a little ingenuity and some tools you could try to fix it. Or like someone said buy a new shredder
May 07, 2014 | Fellowes Office Equipment & Supplies
Suddenly stopped. Power source is good.p Had been working ed. Does not go forward nor backward. Power source is goog.
It could be there is still some material in the cutting wheels. We have had this happen to our shredder a few times, do your best to get stuck materials free.
Good Luck
May 07, 2014 | Fellowes Powershred Personal W11C Shredder...
My paper shredder has stopped working. There is nothing jamming it - what should I do?
I had this same problem on one machine i repaired and when I took off ththe top cover it had a bad gear where it was split and it would run fine backwards, but not forward. the gear is available online. it was also
clogged with paper, which must have caused a lot of torque on the gear. they are plastic, so they will break instead of really messing something up. good luck
Jul 24, 2012 | Fellowes P-48C Cross-Cut Paper Shredder
Fellowes W11C: will only run in reverse. Where are the sensors located?
There is a switch to put it in reverse. This is not a sensor problem. All the sensor does is detect something in the slot.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
Feb 26, 2011 | Fellowes W11C Confetti-Cut Shredder
Was shredding papers and unit stopped,and will not take anymore papers,but it will still go in reverse Fellowes model w11c
Make sure you use a can of compressed air and cotton swabs to cean the entrance and exit sensors.
Jun 11, 2009 | Fellowes W11C Confetti-Cut Shredder
117 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Jim Keysor
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
