Question about Samsung FX510BGS
No power to control panel
Just purchased and installed. No electrical power to oven.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 15 Answers
Look around the rear of the Range for a long black cord.. on the end of that cord should be a plug that fits into a standard 120 volt household power outlet.
Grasp firmly the plug end, line up the flat and round prongs with the like holes in the household outlet, and insert the plug into the outlet.
In the unused portion of the outlet, plug in something simple like a lamp or any portable kitchen appliance just to test the power is working.
Your Range Control Panel & Display should now light up, and maybe beep once or twice to confirm it's working.
Posted on Mar 01, 2016
Can't read oven temp on control board.
Hello;
My name is Peter. I am a retire field service appliance technician.
The model numbers you provided are for wall space heaters.
Open the oven door the model number should be on a label on the face of the oven or on the side of the door.
Your control panel has red lights on it. Sometimes they burn out and you can not read the numbers.
Find the model number and go into the following website. Record the control panel part number. Search the web for this part number.
I recently, purchased a remanufactured oven control board for $45.00, when Sears wanted $256.00.
Make sure you ground yourself before you touch the control board, by touching something metal. Static electricity will knock out a control board.
Water Filters Lawn Garden Appliance Parts
Mae sure you turn the power off to your range before you start the work.
Feb 28, 2016 | Kenmore 95012 / 95014 Electric Kitchen...
No power on double oven after a storm
I have a RBD275PRS00 built in double oven. Had an electric
www.fixya.com/support/t8971528-rbd275prs00_built
Apr 16, 2011 - Had an electric storm the other night and ever since the oven won't -Whirlpool ... Question about Whirlpool RBD275PR Electric Double Oven ... For an oven to require parts after 2.5 yrs of service and 2 self cleanings tells me ... fiest press the on key see if the display comes if not the turn the power off for 5-8 ...
Whirlpool panel buzzing Ovens Questions & Answers - Fixya
www.fixya.com > Forum > Tags > panel buzzing > Ovens
Whirlpool ovens panel buzzing related questions and answers. ... the control panel on my Whirlpool electric double oven Model is RBD305PDS14? ... No power on control panel During self clean cycle the power to the panel went out. ... panel the instrument panel on an oven won't change time because of a storm problem.
Jan 01, 2016 | Whirlpool RBD275PR Electric Double Oven
Nothing happen what should i do now? i try to unlock and is nothing on the screen is black and by the screen with tha clock say F2;E1
If your oven is displaying the F2 E1 error code, then the problem is probably NOT just that the CONTROL LOCK feature on the oven was engaged.
The F2 E1 error is probably an indication of an electrical fault inside the electronic control system for the oven.
Sometimes this is simply a temporary error in the control panel circuitry which can be cleared by shutting off the electrical power supply to the oven for a minute or so at the breaker box.
Other times this is caused by a loose wire or faulty connection inside the control panel, or it is simply a faulty control panel circuit board.
Try switching off the electrical power to the oven using the corresponding breaker at the main fuse panel in your home. When you switch the power back on after a minute or so, press the CANCEL button on the oven controls panel.
If the above procedures do not work then you will likely need to contact a local service technician to disassemble the oven, diagnose the cause, and repair the problem.
If your oven is new, be sure to contact your dealer at the place of purchase since the cost of the repair may be covered under the terms of your warranty.
Good luck.
Joe.
Nov 03, 2011 | KitchenAid Ovens
I have a whirlpool electric glass top stove (model # rf364pxpq ). our electricity went out for only a moment, and when it came back on, the control panel is blank and the oven doesnt turn on. the stove top...
I just encountered the same problem. Power surge during storm caused the control panel to go blank. I removed the panel to get the part number. Reinstalled control panel and it started working. Below are the steps 1) Turn off breaker 2) Unplug unit 3) Remove rear panel 4) Unplug all connections to control panel 5) Wait 5-minutes 6) Reconnect all wires in reverse order 7) Install rear panel 8) Plug in unit 9) Switch breaker to on position Control panel came on, set clock and all oven functions worked.
Jan 02, 2011 | Whirlpool Kitchen Ranges
Touch pad will not allow me turn oven off
It sounds like that is what it is. Purchase it yourself from a local appliance parts place, not a dealer. It will cost you much more. To install it is easy. Just replace wire for wire.
Dec 12, 2008 | Kenmore 47783 Electric Single Oven
Whirlpool electric oven problem
thermal fuse to board blows, relays turn fans off, the thermal cut out on rear of oven kills element. change both fuses, install new style oversized blower.
Sep 22, 2008 | Ovens
Samsung FX510BGS Logo
88 people viewed this question
Top Samsung Kitchen Ranges Experts
Oloyede Monsuru
Are you a Samsung Kitchen Range Expert? Answer questions, earn points and help others
