Question about Estate TS25AFXK Side by Side Refrigerator
Whirlpool refrigerator making a clicking noise and not cooling
Whirlpool Refridgerator less than 2 years old Making loud buzzing noise this eve so I turned the cooling dial down to off. It stopped the buzzing, but now that I have powered it back to level 3 it will...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 08, 2011 | Whirlpool Refrigerators
My top freezer is not cooling, but the refridgerator section is cooling. Refridgerator makes a clicking noise. What could be causing this? I have a Whirlpool 21.0 cu.ft with icemaker
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then checkout the last two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
Sep 20, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
My 7 year old whirlpool refrigerator makes a clicking noise turns on but won't cool
more than likeky its your over-load / contactor to the compressor,remove it off the side of compressor and shake it if its bad it will clatter
Nov 01, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Compressor/Fan not working, one click noise
change the relay and clickson connecting directly to the compressor
Oct 18, 2009 | Whirlpool ED5FHEXMQ Side by Side...
Whirlpool refrigerator not cooling freezer seems to be working
my icemaker makes ice and water but the ice doesn't come out when pushing the button what is the problem?
Aug 30, 2009 | Whirlpool ED2FHEXNS 21.8 Cu. Ft....
Whirpool GS6SHAXLB03 Refrigerator or freezer do not cool.
This sounds like it's out of freon. Not just low but out. That clicking noise is a thermal overload shutting down the compressor. If you continue let it just click away it will burn this overload out and the compressor will have to be replaced. If the refrigerator just started doing this suddenly it could be that the compressor is locked up. If it has external capacitors either the start or run capacitor could be bad. If the capacitors are good then you could try a hard start kit to try to unlock the compressor.
Jun 30, 2009 | Whirlpool GS6SHAXLQ 25.5 Cubic Foot Side...
Runs but will not cool compressor sound is not the same as it was
If there is a clicking noise coming from the compressor, replace the start relay on the compressor. Make sure the compressor fan motor is running.
Jun 07, 2009 | Whirlpool GD5SHAX Side by Side...
FREEZER BUZZING NOISE - Whirlpool refrigerator Model# ED5FHEXNS01
My whirlpool side by side makes a vibrating noise when in cool cycle I press at the back of the panel in the freezer side and it stops
Apr 10, 2009 | Whirlpool GS6SHEXNL Side by Side...
Loss of cooling in refrigerator / freezer
you may have a bad ptc or cold control. if you hear a buzzing noise followed by a click, you have a bad ptc unplug the machine and call a service company quick
Jun 07, 2008 | Whirlpool ED2NTGXL Side by Side...
Estate TS25AFXK Side by Side Refrigerator Logo
Top Estate Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Audie Bogus
Audie Bogus
Level 1 Expert
Are you an Estate Refrigerator Expert? Answer questions, earn points and help others
