Question about Samsung LN32A330 32 in. LCD TV
On screen says BBC ONE audio channel cannot get rid of command on screen
Screen freezes BBC Channels only. Unfreeze by switching off TV. Handset and TVs buttons fail to work. Minutes laterscreen freezes again. No problem with non BBC channels
turning tv off and on wont make it better
you on roof antenna or a cable tv
if antenna only
you may be in weak signal area
or a new construction site or buildings deflecting the signal
antenna problem or needs upgrade
go back to TV set up and re-tune tv to bbc if possible
if it freezes then you know its an interrupted signal
Mar 26, 2017 | Televison & Video
How do I get the BBC channels back
Sounds like you need to check if the tv is set to the right region.as BBC is region orientated.
Dec 08, 2014 | Televison & Video
Lost BBC channels after update on free view
Freeview channels were changed on 3rd September, large notices all over tv;s for previous week.
BBC channels moved to 100... BBC News is now 130.
Sep 09, 2014 | Sony VIAO P4 PCV-RS712 3.0GHz 512MB 200GB...
How to tune freeview for digihome PVR80 it wont record bbc how to fine tune it .when we had to re-tune for channel 5 it worked perfect so please tell me how to do that again
On your remote control, press 'menu'.
Then select 'set up' on the screen.
Then select 'Installation' on the screen.
Then select 'Automatic channel scan' on the screen.
The box should then scan for all channels, and with luck BBC will be included. If not, please repost. Some older Digihome PVR80s can't cope with the new multiplexing standard employed by digital freeview.
May 07, 2010 | Televison & Video
ITV channels say no signal BBC and others working ok What do I have to do?
auto scan for the channels and you'll find channel 853 itv audio description will now work! channel 4 is now 854!!
Hope this helps
Jan 26, 2010 | StarTech.com StarView SV211K 2-port KVM...
Unable to record any BBC channels on tvonics dvr
I had this problem and did 'Menu' then 'Settings' and 'Reset set top box'. This will lose your channels and timers, but the recorded programs will still be there. After I did this I could record again on BBC!
Jan 07, 2010 | Televison & Video
How do i move channel 800 bbc to number 1 in place
go into tuning menu and if it in list it displays swap or change move the channels that are mixed up
if not work then make a favorites channels list
Dec 17, 2009 | Televison & Video
After retune no bbc 1 2 bbc news channels tv with
Sounds like you haven't retuned the set correctly. Use the factory settings/ default setting if poss. Look out for too much signal if you are on a booster.
Nov 06, 2009 | Pace Televison & Video
ITD 58, 59, 60, 61
press info button on the remote then goto tuning on the blue screen menu. say yes to auto tune then save.
Jul 28, 2008 | Sagem PVR 6280 Freeview DTV Receiver /...
Samsung LN32A330 32 in. LCD TV Logo
21 people viewed this question
Jerry Greenberg
Jerry Greenberg
