Question about Acer Aspire 5100 Notebook
System bios version 2.84 bus:06 device:01,function:00 ERROR RESOURCE CONFLICT-PCI IN SLOT 03 bus:06 device:04,function:00 RESOURCE CONFLICT-PCI IN SLOT 03 bus:06 device:04,function:01 RESOURCE CONFLICT-PCI IN SLOT 03 bus:06 device:04,function:02 RESOURCE CONFLICT-PCI IN SLOT 03 bus:06 device:04,function:03 PRESS TO RESUME TO SETUP plus when it going to its run through it stop gives me two beeps then i get this message i wipe the hard drive i can get windows back in but only without the service packs when i get updates and when i get to service pack two it wont boot up it locks up i tried to install windows xp with service pack it wont load it stops on installing set up i know this used to have vista on it can someone please help me ps when i had windows in i did notice i need drivers for some stuff like bus ect..this is a laptop acer asphire 5100 bl51 thank you guys alot if u can help
  • 115 Answers
Http://www.smartcomputing.com/Editorial/article.asp?article=articles/2004/w1509/06w01/06w01.asp&guid
This is an article on basic troubleshooting since that sort of bios error could be anything from video card to harddrive.
If i were a betting man i would say the HD is toast at some point, so before you update next time try and Check Disk to see if you pass...
You can also download some slaxware linux distro's and put them on a USB stick for other diagnosing tools.
Have you installed anything new? Did you add any hardware, etc? Are we talking OEM vista in which case some manufacturers have to take the original OS off the disk...
If i were you i would get a new HD and try out a fresh install...
Posted on Jun 22, 2009
Bus: 06, Device: 01, Function: 00 ERROR Resource Conflict - PCI Network Controller in Slot 02 Bus: 06, Device: 02, Function: 00 ERROR Resource Conflict - PCI in Slot 03 Bus: 06, Device: 04, Function:...
I would firstly reboot and if that doesn't clear the error run www.iobit.com asc.setup utility to remove crosslinked files and sort out a crosslinked registry. Failing that remove the driver from the Control Panel and let the OS set up a fresh driver. Make sure the driver is the correct one!
May 02, 2011 | Acer Aspire 5100 Notebook
When starting the laptop acer 5100 it tyries to start and it shows the following Bus 06, device 02 ,function 00 error resource conflict pci in slot 03 bus 06 device 04 function...
If it just started doing this all of a sudden, then it is a good bet that *********** board is fried. If you just installed some memory or a communications card or new drive, then take it out and see if it still does it. If not, check the installation instructions to make sure it was put in right.
Sep 08, 2010 | Acer Aspire 5100 Notebook
Al encender mi ACER Aspire 5100 suenan 2 pitidos y en la pantalla me pone: Sistem BIOS Version:V3.13 Bus:06, Device:01, Function:00 ERROR Resource Conflict - PCI in slot 03 Bus 06, Device:04, Function...
You have a n IRQ conflict meaning you have a device that is trying to use an IRQ slot that its not meant to talk on. From the looks of it you have been in the bios already so go back in and set it to factory default.
Aug 16, 2010 | Computers & Internet
I BOUGHT A USED ASPIRE 3100-5100 MOTHERBOARD AND GET THIS ERROR WHEN IT TRIES TO BOOT. ERROR Resource Conflict ? PCI in slot 03 Bus:06, Deice:01, Function:00 ERROR Resource Conflict ? PCI in slot 03...
You should try clearing the cmos battery. It's a small battery on the motherboard that can be taken off. Take it off for 20 minutes and put it back in. Then boot up again.
May 03, 2010 | Computers & Internet
My laptop wil not boot. Not even in safemode . It has wndows xp that i had recently put on there.. its been doing this for a min but it would come on after a few tries.. This is exactly what happens when i...
Hello Karen
Try removing and resetting your memory modules.
Blow some air in the slots to remove any dirt trapped in there.
They are locate don the back of your laptop.
The instructions are in the manual under how to change or upgrade memory modules.
Please don;t forget to rate this answer if it helps
Jul 22, 2009 | Acer Aspire 5100 Notebook
Aspire 5100 resource conflict - pci slot 3
Yuor RAM memory conflicts with each other check RAM memory fix same frequency memory into laptop.
Thanks for using fixya.
Jul 20, 2009 | Acer Aspire 5100 Notebook
Laptop will not fully start
This could be a device failure. However, try flashing the bios. Do this by going to Acer's support site and creating a bootable disc with the bios or updated bios, if there is any, on it. Then run this in your machine. You will have to use a different computer to do this, apparently. If this doesn't fix the problem, then you will need to take it in and have a tech run down the device that failed.
Jun 26, 2008 | Acer Aspire 5100 Notebook
check for an update of bios on acer.com it will fix your laptop problem....
Apr 24, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Acer Aspire 5100 Notebook Logo
549 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
