Question about Panasonic Lumix DMC-TZ25 Digital Camera Black
My TZ25 won't charge - the red charging flashes. Do you know why?
Red blinking light
Hi, Ephraim. The flashing red light indicates that the device is showing "low battery". It could be that the LG phone charger fits the charging port on your bluetooth headset but it is not compatible with your device. In order for you to know that it is charging, the device should show a steady red light(means charging).
Please take a look at the table reference below.
•With the Charger Plugged In
______________________________________________________________________
•Headset Indicator Headset Status
Red-----------------------------------------------Charging (battery level less than 50% charge)
Yellow-------------------------------------------Charging (battery level more than 50% charge)
Green--------------------------------------------Charging complete
With No Charger Plugged In
Off ---------------------------------------------Power off
Three blue flashes------------------------Powering on/off
Steady blue --------------------------------Pairing/connect mode
Rapid blue/purple flashes -------------Connection successful
Quick blue flash --------------------------Incoming/outgoing call
Slow blue pulse --------------------------Connected (on a call)
Slow blue flash ---------------------------Standby (not on a call)
Slow red flash ----------------------------Idle (not connected to phone)
Slow purple pulse -----------------------Connected call muted
Steady red ---------------------------------Attempting to connect
Quick red flash ----------------------------Low battery
Note: After 20 minutes on a call or of inactivity, the light stops flashing to conserve power, but the headset remains on
Hope that'll help you in some way.
**Please rate my post and/or leave a comment** ...Thanks...
Sep 25, 2013 | Motorola Mobility H560 Bluetooth Headset
Battery charger on quantum electric wheelchair starts out ember color then starts flashing red I check wires everything is plugged check it about 3 months ago everything was ok now th chair won't
Did you charge it at all during the 3 months? Did you store chair on a full charge? Check to see if batteries are dead. Batteries should be disconnected and/or stored on a full charge. If left connected they should be fully charge every week.
Mar 17, 2013 | Health & Beauty
My Sony Ericsson Multipoint Bluetooth headset VH410 won't charge
light is not flashing only red light is coming on charging from last two days
Sep 18, 2012 | Sony Ericsson Multipoint Bluetooth Headset...
Blackberry playbook red light flashes but it won 't turn on
this happened to me, it needs charging make sure the lead has the blackberry symbol facing up....
May 12, 2012 | RIM Blackberry Playbook 7Inch Tablet...
Red and green flashing lights on 18v lxt charger
Batteries don't always look degraded but if they've been in use for a while or have a bad cell, they will show up bad on the charger and it won't charge them. The only way to test the batteries is to try to charge them on another charger. If the batteries show defective on another charger, they are bad and you'll have to replace them. Also try to charge some batteries you know to be good on your charger to see if it's the problem. If your batteries charge on another charger, your current charger is bad and they don't have any replaceable parts in them so you'd be looking at replacing it.
Feb 21, 2012 | Makita Tools & Hardware - Others
My Nikon Coolpix S2550 says the battery is low when I need to use the flash - but I have fully charged the battery please help
try leaving the camera on to drain the battery down, then try charging it again.. or could be a bad battery
Dec 30, 2011 | Nikon Cameras
My Nikon Coolpix s230 flash won't work. It just blinks red in the lower right hand corner. I've tried all the settings and they all won't flash.
If there is a problem with the flash itself or the mainboard connection to the flash it will not charge. If the flash won't charge then it won't go off when you take a picture. The only way to fix the problem is to replace the flash with a good used one and see if that fixes it. If not, then you need to replace the mainboard. Good used parts can usually be found online for cheap; that auction website doesn't pay me to type their name, so I don't, sorry. Hope this helps!
Thomas Drayton
Owner, www.darntoothysam.com
Affordable Digital Camera Repair
Jul 24, 2011 | Nikon COOLPIX S230 Digital Camera
Ntn7143cr battery won,t charge. put in charger flashes red then green.
Clean your battery contacts on the battery and charger with a pencil eraser to assure good contact. Flashing red or flashing in general usually is the sign of a too low to charge battery, a shorted battery or a bad connection. In some instances, a battery will begin to charge once left on the flashing charger for an hour or so. Try this and see if the light becomes constant. If so, it is charging. If it still flashes, replace the battery.
Best regards.
Apr 04, 2010 | Motorola MT1000 Compatible 2 Way Radio...
WON"T WORK
sounds like a dead battery. Plug the origional charger into it and the front led (below the flash) should flash red. If the red led in the back of the camera flashes or stays lit, then you have the wrong charger plugged in. (the camera won't power up if the back red/green led is on when plugged in)
May 08, 2008 | Jazz DV-179 Digital Camera
Headphones change batteries
Any luck with that model number??
Apr 06, 2008 | Radio Communications
Panasonic Lumix DMC-TZ25 Digital Camera Black Logo
19 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
