Question about Brinno PHV1325 PeepHole Viewer 12mm Barrel
What is the reason that my PHV1325 shows only white screen when pressing the operation button instead of the actual external view ?
When turn on camera lcd screen is white instead of show view in front of camera. might be internal shutter stucked.
Not much to go on. I hear a lot about white screens, but don't know what it looks like. Cold be the LED's on the back are lightning and no info is send to the screen. Did you try to change the settings? sometimes the screen is switched off, to save power. Press the display button several times. It is on the top of the control button on the back.
If you take a picture, do you get an image on the memory card? Perhaps you only can see it on the PC.
If you don't get an image (or just a white image) your sensor could be damaged.
Dec 08, 2013 | Sony Cyber-shot® DSC-H20 Digital Camera
I tried to hook up an external "Sharp" monitor to my Lenovo G555 using a VGA chord. It did not show on the monitor. I went through the control panel and picked "Connect To a Projector"....
Do you still have your Lenovo G555 manual? "Try to read when connecting to the projector section"
I will give you some universal function keys to solve your problem
press and hold this:
Fn F3
Fn F4
Fn F5
Fn F6
do this one at a time
others does not function with Fn they use ctrl button. Try to press and hold ctrl with the button mention above with not pressing Fn
Jul 26, 2011 | Computers & Internet
I buy vga to rca and s video cable to conect toshiba laptop to tv and dont show grafic options how ican make work
There is a button to switch from laptop monitor to external monitor or can view on both monitors. There is a button with a drawing of two monitors, usually the F5 button. Press FN and F5 simultaneously to switch from laptop monitor to external monitor. Press them again to view both on laptop and external monitor. Press them again the third time to view only on your laptop monitor.
Sep 07, 2010 | Computers & Internet
Operating instructions for dsr pd177p sony video camera. I am not in postion to operate the camera, please guide how to operate the camera.
It is not very easy to say few lines to tutor ,but learn to use only by experience.Put the battery on for charging.Once fully charged slide the power switch to camera.Open the lens cap ,open the view finder display.Now you can see the picture on your screen.Set the camera to auto focus.show the camera to a white screen so as to white balance the camera.Now point at an object and do a trial Zooming using the auto zoom with your finger.The image will come closer and you can draw it to white screen.Having an object in view on the white screen,press the record button.Slowly move the zoom forward to get the right frame of the object.Press reccording button once again to stop.Repeat the process on different scenes.
Now shift the mode switch to play and rewind and play the reccorded portion.Practice.
Sep 02, 2010 | Sony Dvcam DSR-PD150 DV Digital Camcorder
Where's the shooting information of d80 in the larger screen?
The Shooting Information screen was introduced with the D40. The older D80 does not have it. Instead it shows almost all of the information in the control panel and/or viewfinder, though you have to delve into the menus for some of it.
Most of the settings you could change via the Shooting Info screen on the D40, you can change by pressing the appropriate button and turning one of the command dials.
The D40 was intended as an introductory dSLR, doing more handholding for new photographers, putting things into visual, menu-driven screens. The D80 was intended as a midlevel camera, allowing faster operation using more buttons. It does less handholding, but once you learn where the controls are, it actually is faster to use. (Okay, that was based on my personal experience, since I've used both.)
May 27, 2010 | Nikon D80 Digital Camera with 18-135mm...
Can't view downloaded sections from Garmin Topo
In Map Setup page, scroll over to blue 'ball' icon (second from right), press lower left button on side of GPS unit, use Thumb switch to scroll down to "Show None", click Thumb switch in. All maps will disappear. Press lower left button on side of GPS unit again, scroll down to "Show Topo.....", click Thumb switch in. Your Topo maps should now show onscreen.
The reason your Topo map might not have shown is because, if you leave the Navigator map showing, and then just press "Show Topo", the layer showing Topo will still be under the Navigator map. This is why I always tell it to show none, and then load whatever map I need to see onto a bare screen.
If this solved your problem, please come back and rate our answer as this assists others. Thank you.
Feb 04, 2010 | Garmin eTrex Legend GPS Receiver
Hi, I have a Canon IXUS 95IS camera.. For some reason, when I attempt to take a photo, the LCD screen isn't displaying what is actually in view? In movie mode it comes up on the screen but when i flick it...
Ah yes! you have pressed the display button. Turn the camera on and you see the icons in the display, look for the Disp button and press it, the display will cycle through its modes icons, black, image and icons.
Jan 22, 2010 | Cameras
When I turn on the aspire one note book it goes to a white screen and will flash once and go to white screen and stays there, owver all other lights on the panel flash normal, but will not boot up. this is...
If you're still under warranty, you can diagnose one possible problem easily enough. Blank white screen with the LED indicator lights running normally otherwise will almost always mean that the LCD panel is bad. If you don't have an external monitor available, find a friend with one and hook up the laptop to that monitor. Be sure to have the laptop power off when you attach the monitor cable. Press the power up button and then the Fn+F? (whatever F key has a little icon on iyt showing a monitor) combo to switch to an external monitor. If your laptop's Operating System shows up on the monitor, you know for certain it's jus your LCD panel that's bad and you can ask the manufacturer to replace it.
Dec 05, 2009 | Acer Aspire One PC Notebook
Touble Viewing Picture
I have that problem. What I do to view the pics is to save it to the phone and then view the pictures from My Stuff/Graphics.
Aug 10, 2007 | Samsung SYNC SGH-A707 Cellular Phone
Brinno PHV1325 PeepHole Viewer 12mm Barrel Logo
Top Brinno Video Cameras Experts
Are you a Brinno Video Camera Expert? Answer questions, earn points and help others
