Question about Toshiba 32HL67 32 in. LCD Television
Remove stand sanyo dp19649? - Toshiba 32HL67 32 in. LCD Television
I have purchased a new remote for my sanyo tv. the lights on the remote buttons will not light up.
J. if you know the lights on remote are to light up and they do not, it is defective, return for replacement or refund. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Sanyo DP19649 Owner Manual Remote Control Operation
How to Program Universal Remote Welcome to Remote Central Universal Remote Control Reviews More
Apr 12, 2016 | Sanyo DP19647 DP19648 DP19649 DP26640...
I have a manual, but cannot remove unwanted channels on my DP19649. How do I do this????
As far as I understand, some TV's don't have the skip channel feature. If your TV has the 'Skip Channel' feature, you first select channels that have no signal (either a blue screen or snowy screen) then press the up -down arrows to select the 'Skip' and Ok button on your Remote. The Manual should explain how it is done.
Oct 18, 2014 | Sanyo DP19649 LCD TV
Sanyo dp19649 lcd tv it powers up for 5 seconds then shuts off
Indicates something short circuit in the main board.
Sep 09, 2013 | Sanyo DP19649 LCD TV
How to unlock my Sanyo LCD 32K30 TV?
Hi good day. My sanyo lcd 32K30 was locked and i dont know how to unlock it because i dont have a remote control. Would you please help me to fix it? Thanks
Jul 26, 2011 | Sanyo DP19649 LCD TV
Need a users manual sanyo dp19649
Typed "sanyo dp19649 manual" into Google, this is what came up on the first result:
http://us.sanyo.com/LCD-Televisions/720p-18-5-LCD-HDTV
below the picture of the TV there are 3 tabs, you want the "downloads" tab. There you can download the Owner's Manual in PDF format.
Apr 03, 2011 | Televison & Video
Will the standard coaxial cable input on a Sanyo DP19649 accept the 480i digital output from "TV2" of a DISH network ViP722K satellite box?
This will absolutely work!!! You will just want to make sure that your tv is set to channel 60 or 73.
Sep 22, 2010 | Sanyo DP19649 LCD TV
We have a Sanyo DP19649 and headphones dont work
Turn speakers off in sound menu if available. Then turn up volume to hear in headphones.
May 06, 2010 | Sanyo DP19648 19 in. LCD TV
Need to program a GE Universal remote for Sanyo HDTV DP19649. Sanyo codes listed by GE don't work. Thanks!
http://www.remotecodelist.com/remotes/old-index.html
in this page you need read step by step for solved you problem...
bye
Mar 07, 2010 | Sanyo DP19649 LCD TV
Sanyo DP19649 - how od I unlock the stand pivot so
Sorry you can not pivot the table stand on the tv. If it is a wall mount can you give model # and make. Or you can look in back of the tv and you should see the pivot point in the center of the bracket that holds it to the wall.
Dec 27, 2009 | Sanyo Televison & Video
Toshiba 32HL67 32 in. LCD Television Logo
12 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
