Question about Vivitek D510 Projector
Manual vivitek 510
Audio in
Where can I find a Parts repair manual for vivitek model rp56hd22a ?
It is called a service manual. Most repairs for this model require lamp and housing replacements and they are available online but are expensive; $100 plus or minus in the USA. You can google for other parts but they are hard to find on this model.
Encompass has some parts showing, take a look there.
Feb 10, 2015 | Vivitek Televison & Video
Circuit manual of power supply of vivitek d832mx
These are not available except for payment but you can get technical help for your fault from the link below; http://www.vivitek.in/For fault on SMPS get some tips from the link below:
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
Nov 30, 2011 | Vivitek D832MX Projector
How do i reset my vivitek lamp?
Check your menu options for something like lamp options or special features. I believe if my memory is correct its a user accessable feature from the main menu.. If you cant find it that way send Vivitek an email here for technical support they should email you the user manual telling you how.
http://www.vivitekusa.com/v_contact_support.asp
Oct 17, 2010 | Vivitek V37655 56" DLP TV
I have a 52" rear projection vivitek dlp tv. Picture is fine, but it has a loud humming sound. Does anyone know what it is or how to fix it??
turn on video mode if loud humming still occurred replace filter capacitor on audio section from your tv ckt board.
Mar 31, 2010 | Vivitek V37655 56" DLP TV
56dlp vivitek stop talking
*********************This is a possible solution**************************
Mine does this as well for some reason.
I found that switching the audio mode using the remote gets the sound back. I have no idea what sets it off and why or when it decides to do this, but as soon as I press the "Audio" key on the remote, the sound comes back and I put it back to BBE, because that gives me the best sound.
Good Luck!
Apr 02, 2009 | Vivitek V37655 56" DLP TV
Vivitek
check the settings on your TV, my new TV was set to analog on the audio screen, in which no sound came out after I set it on the digital mark, sound was there, I hope this will help you
Sep 06, 2008 | Vivitek V37835 46 in. LCD Television
Direct tv recorder and Vivitek V37835 46 in. LCD remote code for controller
IN THE GOOGLE SEARCH ENGINE TYPE VIVITEK V37835 MANUAL. ONCE YOU GET THE MANUAL LOOK IN THE SECTION OF THE MANUAL THAT SAYS SETUP CODES FOR SATTELITE RECEIVERS. FOLLOW THE INSTRUCTIONS FOR PROGRAMMING UR REMOTE. ALSO WANT TO LET YOU KNOW THAT I HAVE DISH SATTELITE AND I USE MY VIVITEK REMOTE NOT THE SATTELITE REMOTE FOR MY PROGRAMMING. MAYBE TRY THIS. IT WORKS FOR ME.
Oct 18, 2007 | Vivitek V37835 46 in. LCD Television
Vivitek D510 Projector Logo
46 people viewed this question
Top Vivitek Office Equipment & Supplies Experts
Miguel Luiz Martins
Are you a Vivitek Office Equipment and Supply Expert? Answer questions, earn points and help others
