Question about Bodum Coffee Makers & Espresso Machines
Why doesn't my coffee manchine start brewing?
The green light on my coffee goes ON but nothing happens. The water doesn't start to heat up or move in coffee tray.
  • 12 Answers
SOURCE: Coffee does not brew
The thermal breaker has died in it. This is usually mounted on, or near the heating elementm and usually turns off when excessive temperatures are present (such as when a pot boils dry, or the unit is left on for days) It can be checked with a ohm meter on its contacts. If it shows as good, it should show up as normally closed. Some overtemp breakers have a small button for resetting, but most are simply supposed to reset themselves once the heat is sufficiently reduced. There are also heat fuses that blow...for good when excessive heat is detected, mounted in the same place, they are often a metal bullet shaped tube. OR.....your power cord...or main power switch could also be faulty.
Posted on May 01, 2006
ThaMp3Doctor
  • 8596 Answers
SOURCE: coffee maker won't brew
This one has two AUTO dial settings - AUTO-ON and AUTO-OFF. AUTO-OFF merely keeps the hot plate warm for a fixed period of time. AUTO-ON is the one that allows your coffeemaker to go off at the pre-programmed time in the morning.
If it is set to AUTO-ON, but is not brewing at the set time, unplug the machine for longer than 20 minutes. Then plug it back in, reset the clock, reset the prog time for a time that is just a few minutes into the future, and then test the auto-on feature.
If it stil ldoes not brew, just turn the machine to brew and press on. If it brews a pot, then your problem is electrical. If it doesn't brew a pot on the regular brew setting, then you either have: A) Calcium buildup/clog, or B) a hose leak (or worse).
To rule out the calcium buildup possibility, let half a caraffe worth of vinegar sit in the water reservoir for about an hour. After the hour, turn it to brew and press on, and brew the vinegar just as if it were coffee. If the vinegar goes through, your problem is solved.
Otherwise, call Cuisinart and find out if you are still in-warranty. Thep roduct has a 3-year warranty.
-Tha Mp3 Doctor
Posted on Mar 21, 2009
SOURCE: OPEN HEAD
Open the head and pull out the piece that hold the k-cup. Take a paperclip and clean out the needle. Replace and you shouldn't have a problem. We had the samething happen to us.
Posted on Apr 29, 2009
  • 85 Answers
SOURCE: won't brew
Hello myrna287,
This is really a common problem with this unit that is fixable.
I recently had this similar problem. If you still have your machine try the following.
Your described problem may be one of two problems. Let's start with the easier solution first. In the DCC 1200 there is a filter "stick or column" in the left rear. Pull it out and remove the clogged carbon filter(s) that are in there. Shine a light into the receptacle and remove the debris in the bottom. It is likely that this is causing the problem with you machine needing to be started on multiple times. See if this solution works. If it does, you might run 8 cups of water and 4 cups of vinegar through to help decalcify the units plumbing. Do this once or twice and then rinse with at least one pot run-through of clean water. If this works then you are good to go.
Next, if this does not solve your problem we can do the following: unplug the unit and lay it on its back. You will need a #10 torx driver (hardware store if you don't have one) to remove the bottom cover plate. There are 4 torx screws holding it on. When removed, you will find 2 orange hoses. Carefully attempt to remove the left hose without splitting. I used an eyeglass screwdriver to loosen it up. If it splits, just cut off the split and stretch it to reconnect when time comes. As you look into the hose you will find a little black valve inside as well a some gunk. Clean it all out with a fine wire as best you can. Rinse well. Attempt to reconnect the hose back onto the pipe. Slip the pipe clamp back into place. Replace the cover and screws and you should be good to go again. This is not as daunting as it may seem. You can do it. :o) Good luck! If this answer helps, please leave positive feedback for me. Much appreciated. Regards, NormanZ
Posted on Jul 09, 2009
  • 58 Answers
SOURCE: Keurig shuts off as water heats and as coffee is brewing?
Contact Keurig customer service at 1-866-901-BREW (2739) -- everyone i have spoken to was very kind and helpful
Posted on Jun 24, 2010
Green light goes ON but nothing happens
I have the same problem after using it only twice...the store won't take it back as they no longer carry them, and there is no place local to repair them...and I can find nothing online to fix it. it was too expensive of a machine to have this kind of problem that is not easily repairable.
May 07, 2014 | Bodum Bistro b.over Coffee Brewer - Black
My7 DCC-1200 series coffee maker fail to brewe, light goes on but nothing happens
have you checked if the water filter needs to be replaced? this happened to me before and when the filter is worn water is not getting through so try to replace it. its only $5 on Amazon so worth the cost before you toss it.
Hope this helps.
Mar 19, 2013 | Cuisinart Dcc-1200 Brew Central 12-cup...
Coffee maker turns on but will not brew
why question to all of this is with a "self clean" button, why doesn't it every tell you to clean it..... ??
Sep 07, 2012 | Cuisinart DCC-1200 Coffee Maker
We are attempting to use the LA3 by pouring water into the top of the machine as opposed to auto through a water line. The water heats up, the green ready light comes on, I push the start button and it...
If it is not connected to a water line then you cannot use the hot water faucet or the start/brew button, you will have to manually brew coffee by pouring the water into the reservoir.
Nov 16, 2011 | Brewmatic LA3 Coffee Maker
I push the start button (the one with the red light) and the light turns on, but then nothing happens. (Yes, I had water in the tank and coffee in the filter part.) Usually, I push the button, the light...
Sounds like there an issue with the heating element. When the element goes bad it wont pull any water from the tank nor will it heat the water sending it up through the shower head and onto the beans. Unfortunately, since Braun has discontinued ALL kitchen appliances here in the US many of the parts are obsolete including the heating element for this machine.
Mar 29, 2011 | Braun FlavorSelect KF 180 Coffee Maker
! light flashing... machine won't brew coffee - when i press the button to make espresso nothing happens.. I've tried all the troubleshooting options - nothing works.
The machine is sensing one of the following is not properly fitted in.
Check bean lid, brewing unit is properly latch in, dreg drawer and tray is in, and water tank. And make sure the knob is in off position. If all those are properly in ..the green light will start flashing and warming up. When it reaches the working temperature it will start rinsing and it's ready to use.
Oct 11, 2010 | Saeco Odea Giro Plus Coffee Maker
Jun 14, 2010 | Keurig B50 Coffee Maker
After the coffee is ground and pressed, no water goes through to brew the coffee and dispense it
Sounds like the brew unit is blocked, to be sure try this, use the pre grounds button to brew a coffee, if no water comes out then it is the brew unit, remove unit and look under red o-ring, you will see a shower screen, clean shower and tube that flows to the discharge(top, you will have to remove the 2 screws up there, be careful not to lose the small plastic ball under the spring). Reassemble and try again.
Jan 18, 2010 | Gaggia Syncrony Logic 74884 Espresso...
Put in water turn on green light is on nothing happens
The green light is used for setting an automatic brew time. Turn the brew button until its red and your coffee will begin brewing.
Oct 24, 2009 | Cuisinart Brew Central 12-cup Coffee Maker
Coffee Makers & Espresso Machines Logo
48 people viewed this question
Top Bodum Coffee Makers & Espresso Machines Experts
vilhj
Level 1 Expert
ray gallant
Kolbrun...
Are you a Bodum Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
