Question about Lexmark MX310dn Monochrome Laser Multifunction Printer 35S5700
Disable automatic firmware updates
HOW TO disable automatic firmware updates
Automatic page updates causing problems with your screen reader
solve problem of Automatic page updates causing problems with your screen reader
Feb 24, 2011 | Yahoo Mail
My lan card automatically disables and enables and is connects at 10 Mbps rather 100 Mbps
Please check specifications of the network hub you are using. If this is only 10mbps, then your D600 will also connect at the same speed. If your hub is already 100mbps, and considering that if automatically disables and enables, then the network adapter of you laptop is probably defective. Try updating the firmware of the unit and also the device drivers, this may also possibly correct the problem. You may also want to consider buying a USB network card or just replacing the laptop if the above does not work.
Jan 10, 2011 | Dell Latitude D600 Notebook
I can only connect one laptop to the internet. When i turn on the second one it makes the first laptop loose its connection with the internet. My service provider says its the router. Can u help?
Hi! I think you have an IP conflict on your laptops. Do this: goto control panel and open the network section and put a fixed IP address for both the laptops, lats say: LapTop1: IP: 192.168.0.10 LapTop2: IP: 192.168.0.20
And put a DNS number in the same section where you put the IP numbers. The DNS number is the IP number of your router. WARNING! your router IP address must be in the same region as your laptops. Lats say Router IP: 192.168.0.1 than your DNS address on your laptops are 192.168.0.1.
Check in the router of some security restriction like how many users can be connected through WiFi connection, check for firewall enabled or disabled, if enabled try disable it and try to connect now.
I hope this solution will help to solve your problem.
Dec 29, 2010 | EnGenius ESR-1221 EXT Router
My laptop cannot connect to dir-300 wireless g router but my other desktop computer can connect through lan card, its operating system is vista while my laptop is xp
It does sound like you may need to upgrade firmware. DLink is still in the process of updating Vista firmware so be sure you get the right file!. Anyway here is the URL you need:
http://drivers.softpedia.com/get/FIRMWARE/Others/D-Link-DSL-300G-Firmware-R200Mb9cv.shtml
You might like to try:
1. Disable Windows Firewall
2. In Internet Options Control Panel go to the connection tab and then the LAN Settings where you can uncheck the "Automatically detect settings" button.
3. If you have any third party software, I would get rid of this and ensure that the"Windows Zero Configuration" in the Services menu is set to "Automatic" and the status is started.
Interestingly, Anti Virus programs sometimes interfere with wireless set up - you could see if it helps by disabling it whilst configuring your wireless. It might also be worth trying to connect without any encryption code & see if that will connect - you can then sort out the encryption.
You might find this site of some use
http://www.vista4beginners.com/How-to-setup-a-wireless-connection
Mar 15, 2009 | Computers & Internet
Windows XP home edition service pack 3
OK, do you wish to install further updates? if you dont, then what you can do is disable automatic updates
To do this, then right click on the desktop the icon My pc and select properties. The sub menu Automatic Updates you will find on the top, click that and check the box disable automatic updates
Some Automatic updates are dangerous and can cause your computer to stop working correctly. I would recommend you disable them. Once this is disabled, restart your computer and the access denied messages will disappear. This is because its most likely you have automatic updates set to download and install automatically. But once you disable this, problem should be solved.
If you have any more questions, please let me know
Oct 16, 2008 | Microsoft Windows XP Home Edition
How to update the firmware and software for my Microsoft Broadband Networking device
Back up base station settings Before you start, back up the current settings for your base station. To do this, follow these steps: 1. Start the Microsoft Broadband Network Utility. 2. On the Tools menu, click Management Tool. 3. When you are prompted to, log on to the base station. To do this, use the password that you created when you ran the Setup Wizard the first time. If you did not run the Setup Wizard, use the following default base station password: admin 4. On the Management menu, click Back up and Restore Settings. 5. Click Back Up Settings. 6. Click Save. 7. Type a name for the file that contains your base station settings or use the default name Config.bin. 8. Click the folder where you want to save the file, and then click Save. Back to the top Back to the top Disable firewall or antivirus programs For information about how to disable your firewall or antivirus programs, view the documentation that came with the program, or contact the manufacturer's technical support. Back to the top Back to the top Install firmware update Warning Do not install the firmware update from a computer that is connected to your base station by using a wireless network connection. If your wireless signal is interrupted, weakened, or interfered with while the firmware update is running, your base station may become unusable. Automatic update 1. Start the Microsoft Broadband Network Utility. 2. On the Help menu, click Check for Updates Online. The Broadband Networking Update Service checks for updates by connecting to Microsoft. This can take several minutes, depending on your connection speed. If any new updates are available, a download screen appears. Otherwise, you receive a ?No new updates are available? message. 3. Follow the instructions on the Broadband Networking Update Service page to update the firmware of your device. If the automatic update fails, go to the "Manual Update" section. Manual update 1. Download the MSBNDownload.exe firmware update. To do this, visit the following Microsoft Web site: http://go.microsoft.com/fwlink/?linkid=6... (http://go.microsoft.com/fwlink/?linkid=6790) 2. Save the file to a location such as your desktop or the My Documents folder. 3. If you are updating a wireless base station, use an Ethernet cable to connect your computer to your base station. 4. To run the update, double-click the MSBNDownload file. 5. Follow the instructions that appear on the screen to update the firmware of your device. While the firmware is being saved to your base station, the power light on the base station blinks and then turns orange. When the light is solid green, the update is completed. If the update fails, the power light continues to blink slowly until you successfully update the firmware. In this situation, you can try to update the firmware again, or you can reset the base station.
Feb 16, 2006 | Microsoft Broadband Networking MN-500...
Back up base station settings Before you start, back up the current settings for your base station. To do this, follow these steps: 1. Start the Microsoft Broadband Network Utility. 2. On the Tools menu, click Management Tool. 3. When you are prompted to, log on to the base station. To do this, use the password that you created when you ran the Setup Wizard the first time. If you did not run the Setup Wizard, use the following default base station password: admin 4. On the Management menu, click Back up and Restore Settings. 5. Click Back Up Settings. 6. Click Save. 7. Type a name for the file that contains your base station settings or use the default name Config.bin. 8. Click the folder where you want to save the file, and then click Save. Back to the top Back to the top Disable firewall or antivirus programs For information about how to disable your firewall or antivirus programs, view the documentation that came with the program, or contact the manufacturer's technical support. Back to the top Back to the top Install firmware update Warning Do not install the firmware update from a computer that is connected to your base station by using a wireless network connection. If your wireless signal is interrupted, weakened, or interfered with while the firmware update is running, your base station may become unusable. Automatic update 1. Start the Microsoft Broadband Network Utility. 2. On the Help menu, click Check for Updates Online. The Broadband Networking Update Service checks for updates by connecting to Microsoft. This can take several minutes, depending on your connection speed. If any new updates are available, a download screen appears. Otherwise, you receive a ?No new updates are available? message. 3. Follow the instructions on the Broadband Networking Update Service page to update the firmware of your device. If the automatic update fails, go to the "Manual Update" section. Manual update 1. Download the MSBNDownload.exe firmware update. To do this, visit the following Microsoft Web site: http://go.microsoft.com/fwlink/?linkid=6790 (http://go.microsoft.com/fwlink/?linkid=6790) 2. Save the file to a location such as your desktop or the My Documents folder. 3. If you are updating a wireless base station, use an Ethernet cable to connect your computer to your base station. 4. To run the update, double-click the MSBNDownload file. 5. Follow the instructions that appear on the screen to update the firmware of your device. While the firmware is being saved to your base station, the power light on the base station blinks and then turns orange. When the light is solid green, the update is completed. If the update fails, the power light continues to blink slowly until you successfully update the firmware. In this situation, you can try to update the firmware again, or you can reset the base station.
Feb 16, 2006 | Microsoft Broadband Networking MN-100...
Lexmark MX310dn Monochrome Laser Multifunction Printer 35S5700 Logo
20 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
