Question about Sony Cyber-shot DSC-W70 Digital Camera
My Sony Cyber-shot DSC-W70 Digital Camera now shows use compatible battery only error and then turns off with the same Sony battery I came with the camera. How do I fix this problem?
  • 10,594 Answers
Buy new battery, charge it fully and power up camera with that.
Posted on Jun 22, 2009
When i turn on my Cyber-shot camara it always says " For use with compatible battery only." What do i do ?
sorry to say this friend....u have inserted an incompatible battery in your camera
that is why the message "for use with compatible battery only" keep showing up whenever u switch on your camera
so u got to replace your currently installed battery to the compatible battery of your model
so i have searched the web for your model's compatible battery list...just check with it in the below link
http://www.sales-battery.com/digital-camera-batteries/sony-cybershot-dsc-t100_r.htm
even check with your sony cyber-shot model's manual for compatible battery info
in case if you have lost your manual friend...below is the link for your model's manual download
http://www.pdf-manual.com/user-guide-instruction-owner-manual-sony-cyber-shot-dsc-t100-13434.html
"feel free to ask further help friend....am here to guide u based on cameras:-)"
Aug 27, 2011 | Sony Cyber-shot DSC-T100 Digital Camera
Whenever i open it its sony cyber shot it says for use with compatible battery and turn off and by the way the battery was a new one and i didnt use it alot
Possible that the voltage on the cell is not as specified on the model and so the battery voltage detector thinks that the battery is not the recommended type due to the low voltage/current ratio.
I would suggest that you try with a new set than to suspect the camera.
Make sure the terminals are clean.
Mar 30, 2011 | Sony Cyber-shot DSC-W70 Digital Camera
SONY DSC CYBER SHOT
Try clean contacts of camera for battery and contacts of the battery also, specially the middle one - it is for communication between camera and circuit inside the battery. If the problem persists, try use another battery in your camera, or your battery in other compatible product - you determine this way if the problem is inside the battery (I hope, it is cheaper) or inside the camera.
Aug 17, 2009 | Sony Cyber-shot DSC-W70 Digital Camera
The Sony battery that came with the camera no longer works
I had the same problem and tried cleaning the contact points with alcohol on cotton swabs and it didn't work so I tried using a clean pencil eraser and after cleaning both the battery contact points and the 3 contact points within the camera using a twisting motion, it works!
Jul 19, 2009 | Sony Cyber-shot DSC-W70 Digital Camera
My sony cyber-shot DSC-W70 is flashing an error code, 91:01, how can i fix it?
Click Menu
go to setup
then go to setup 1
and go to initialize
then click ok and then ok again
put in the right date and time then
click ok
That should fix your problem! ;)
Jul 10, 2009 | Sony Cyber-shot DSC-W70 Digital Camera
For use with compatible battery only...Sony Cybershot
Try to reset the camera. Reset is an option in the menu.
Jun 14, 2009 | Sony Cyber-shot DSC-W70 Digital Camera
Lens does not go out , can i fix myself?
Hi There,
Remove the batteries then re-install them. Turn the camera on and let me know if it works.
Mar 30, 2009 | Sony Cyber-shot DSC-W70 Digital Camera
Hello when i turn on the camera sony dsc-w70 it show me a massage "access" and then show me "turn the power off and on again" how to solve this problom ? thanks mahdiisari@gmail.com
   This problem related to the main board.Its getting malfunctioning.You have to replacw it from nearby SONY SERVICE CENTRE.
Thanks for using fixya,And dont forget to rate.
Oct 19, 2008 | Sony Cyber-shot DSC-W70 Digital Camera
Sony Cyber-shot DSC-W70...
It's a flash error, something has malfunctioned with your flash and the system board will continue to give this error until reset by service technician
Feb 27, 2008 | Sony Cyber-shot DSC-W70 Digital Camera
USB Mode/Battery compatible problem
I think maybe one of the battery connections are damaged if so try to straighten them with a very thin long nose pliers .The other possbility could be that you have a faulty circuit board .Service it at sony or hopefully youve bought an original battery
Aug 26, 2007 | Sony Cyber-shot DSC-W70 Digital Camera
Sony Cyber-shot DSC-W70 Digital Camera Logo
952 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
