The default address to get to the web interface is 192.168.1.1
The default password is 1234 (No username required)
If that doesn't work, you can restore it to the factory default by pressing the reset button on the back and holding it in for 10 seconds. Be aware that doing this will erase all existing configuration information.
ok... so im guessing your using sat for internet, so you would set one plug with zyxel PL-100 and it sending signal in, while adding zyxel PL-100 a computer works, and another craps out... Solution: use a router insert satalite into wan port, set up router run a client wire from the router to a zyxel PL-100 and the others should pick up off that one..
like so.. :direct from zyxel website specific for pl-100
if you only have usb connection in your modem, internet on the zyxel router will not work since it's using ethernet connection. in order for your zyxel device to work with tiscali, you will need a cable/dsl router that has ethernet connection as well. you can contact tiscali if they can provide you with that kind of modem.
I can tell that your network topology is not the most complicated ever.So u ve got 3 terminals,1 desktop pc and 2 laptop.Simple,reset your zyxel(from the button on the back) and reconfigure the Local area interface connection(ip & subnet mask for the zyxel),reconfigure your internet connection,(WAN zyxel interface) in case the zyxel is your Internet gateway too.Third,make sure NAT & Firewall are up and running(usually are by default) Finally,reconfigure the WiFi interface with the correct SSID name & WEP key or whatever security you prefer.Write down the security pass for your wireless and you are done.Good Luck.
If a LAN connected PC will not work while a wireless laptop is connected you need to go into advanced router setup, bandwidth management, and untick the three boxes labeled "active" to disable the band width management. Easy!
