Question about Samsung SCX4826FN AllInOne Laser Printer
What is low heat error cycle power
Won't copy or scan, will print and receive faxes
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Samsung Expert
  • 167 Answers
Fuser problem check thermistor /thermostat
Posted on Oct 02, 2015
tom19511
  • 1601 Answers
SOURCE: low heat error
Low Heat Error
Cycle Power
There is a problem
in the fuser unit.
Unplug the power
cord and plug it back
in. If the problem
persists, please call
for service.
If this doesnt work call the fuser unit needs to be replaced.
Posted on Nov 02, 2007
namizhka
  • 148 Answers
SOURCE: Samsung CLP-315
try to do this set of instruction & solution:
  1. Go to Start | Control Panel | Printers And Other Hardware | Printers And Faxes. Double-click the icon for your printer to open the Documents window and clear any pending print jobs by selecting Cancel All Documents from the Printer drop-down menu
  2. Try printing a test page from the printer, not from Windows XP. Most printers have a built-in test function that's activated by holding down one or more buttons while the printer is starting up. Check your printer's user manual for instructions. If this page prints successfully, you know the problem is either with your connection or with the software in your computer.
  3. Check your printer's USB or parallel connection.
  4. Try printing something simple from Windows' Notepad. To open Notepad, go to Start | All Programs | Accessories | Notepad, type a few lines of text in a document, and try printing it. If it successfully prints, the problem is with the software program you originally tried to print from.
  5. Try printing using Windows XP's generic printer driver. Open and run the Add Printer Wizard. When you get to the Install Printer Software screen, select Generic under Manufacturer and Generic/Text Only under Printers (see Figure 2).
  6. Select No for Do You Want To Use This Printer As The Default Printer? (see Figure 3). Click Next.
  7. When prompted on the next screen, tell Windows XP to print a test page. If the page successfully prints, then you probably have a problem with your installed printer driver. Either update or reinstall the driver.
Posted on Sep 16, 2008
  • 406 Answers
SOURCE: Samsung clx-2160
This error is from the fuser unit. Try by replacing the fuser unit. or getting fuser unit tested.
Posted on Nov 30, 2008
  • 3 Answers
SOURCE: Samsung CLP-315 system error
Low heat error comes from the fuser unit, there is a thermostat on the fuser change that and it will work
Posted on Apr 17, 2009
  • 2678 Answers
SOURCE: What does this mean low heat error cycle power?
Cycle power = turn off and turn back on.
Posted on Aug 03, 2009
Error message
low heat does not allows u to print , wrong error
May 07, 2014 | Samsung SCX4826FN AllInOne Laser Printer
My HP Photosmart C5240 will print from computer but will not scan or make copies.
Is there any error message displayed on the control panel of the printer just like one of the following:
Scanner failure, power off and on
Scanner System Failure
Scanner failed, cannot make copies or fax
Scanner failure. Unable to scan, copy, or send a fax
Scanner failure, cycle power
You may want to try following these steps:
1. Check if the scanner light does turn on when you initiated the scanning process, if not you need to reset the product.
2. Try using your other electrical outlet because your AVR or Surge Extension may not be providing enough voltage for the printer.
3. Try using dirty cycle, meaning you need to directly cut the power of your printer by pulling of the power cord from the rear side of your printer and wait for about 30 seconds before inserting again and turn it on.
If all these steps do not improve your printer functionality, you may want to call the HP online help and ask for replacement.
Job Espinosa
Feb 15, 2011 | HP Photosmart C5280 Printer
Cant send nor receive faxes
dear sir,kindly follow the below instructions
Instructions
  1. Ensure that all cables are securely connected. First, make sure that the printer cable connecting your computer to your printer is connected securely. Then, make sure that the power cord is inserted into a wall outlet. Try your print job again after you have ensured that all cables are properly connected.
  2. Clear a paper jam if your printer is not responding or you are receiving a "Paper Jam" error message on your printer. To clear a jam, first open the rear output door by pushing down on the two levers on each side of the door. Opening the rear door simply makes it easier to clear a jam. Open the top cover on the front of the printer by pressing the release button on the right side of the printer. Locate the paper jam and use two hands to gently remove the paper jam. Try your print, scan, fax or copy job again.
  3. Clear stored or saved faxes if you are having trouble sending or receiving faxes. Old faxes may be stuck in the fax queue, which may be causing the printer to not respond. To remove stored faxes, press the "Menu" button on the printer and select "Fax Functions." Then select "Clear Saved Faxes." Wait for the queue to clear and try your fax job again.
  4. Remove paper from the automatic document feeder (ADF) input tray if your scan job is coming out crooked. The ADF input tray can only hold up to 50 sheets at a time. If there are more than 50 sheets in the input tray, the output may appear skewed. Try your scan job again after removing the paper.
  5. Adjust your computer monitor's display settings if your scanned image is not an accurate representation of the original image. This can be done in the "Control Panel" in Windows. Set the settings to the highest possible resolution and try your scan job again.
  6. Perform a power cycle on your printer if the previous steps were unsuccessful. To do this, turn off your printer, then unplug it from the wall. Wait a few minutes and plug the printer back in. Try your print, scan, fax or copy job again.
take care..thank you
Oct 04, 2010 | HP LaserJet 2840 Printer
Want copy ---comes up unrecoverable scan---ties up machine for 5-10 minutes---LEXMARK 5600-6600---IT also makes a knocking sound. until red light goes off and green light comes.on---1st time happened...
Unrecoverable scan error is a hardware problem. Features affected by this error are scan, copy and fax. Recommended action is to contact Lexmark technical support for assistance.
Sep 20, 2010 | Lexmark All-in-One Printer with PictBridge
Distorted copy quality in the sent faxes
Make sure the rollers that pull the paper through are clean and that the glass is also clean. Clean the rollers with a cloth dampened with alcohol.
Apr 20, 2009 | HP LaserJet 3050 All-In-One Printer
I have a Ink System Failure.
IssueAn 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print. Solution
Press the On button to turn the printer off.
Unplug the power cord from the back of the printer.
Remove all the ink cartridges.
Wait two minutes.
Plug the power cord into the back of the printer.
Press the On button to turn the printer on.
Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved.
If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.
Dec 20, 2008 | HP Photosmart C5180 All-In-One InkJet...
Canon will not receive faxes or copy documents
see if you have fax line(conect a telefone in the line to see if you have tone) or if the cable is conected.
Nov 21, 2008 | Canon NP 7130 Black and White Copier
Fax and cancel lights are flashing
I found this solution at HP website. It worked for me. Good luck!
A Scanner Bulb Error message is received as a result of the HP LaserJet 3300mfp series product scanner’s inability to find the home reference point.
SOLUTION:
Perform the following steps to walk the scan assembly from the home base and resolve the issue.
1. Remove and replace the power cord from the unit.
2. Wait approximately 35 seconds for the scanning assembly to “walk out" and then quickly remove the plug again.
3. Repeat steps 1 and 2, three to four times until the head moves approximately 1 inch away from its normal resting place.
4. Replace the plug and let the product fully finish the boot cycle.
Oct 08, 2008 | HP LaserJet 3330 All-In-One Printer
Samsung SCX4826FN AllInOne Laser Printer Logo
37 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
