Question about Microwave Ovens
Where is the fuse panel for John deere 737 zero turn mower fifty inch cut
I replaced clock panel turn power on nothing is there a code
If no display---you may have a bad fuse. It should be located behind the control panel. The fuse will look like the old auto glass fuses about 1/4 diameter and 1 1/4 inch long but made out of a ceramic material you can't see through. Color could be white--brown or a gray color. Amp size will be stamped on the end usually 15 or 20 amps.
May 12, 2015 | Kenmore 4888 Elite 30" Built-In Microwave...
Panasonic Microwave NN-CT552W has no power - plug fuse ok - Has it got a thermal cut out or internal fuse? - Unit was ok after cooking some jacket potatoes
All microwaves has both internal thermal cut out and internal fuse, Yours problem sounds like an open 9 volts transformer that power up the front panel
Nov 07, 2014 | Microwave Ovens
The microwave will not turn on.
check control unit or any other thermal fuse is open
Jan 26, 2014 | Kenmore Microwave Ovens
No power lights no power in microwave
First check is the main fuse of the unit. On countertop units, you will need to take the shell off. The fuse will be close to where the cord comes through into the unit. OTR units, this main fuse is usually behind the control panel or possibly behind the vent. Usually the fuse is obvious if blown, otherwise test with an OHM meter, if open, replace fuse.
Some brands will also have a thermal cut-off fuse in the incoming voltage line to the control board. Older Maytags and Samsungs have this fuse in it. This thermostat looking fuse is usually above the oven cavity somewhere under the outside shell. Sometimes you can get to it through the vent of OTR models. Test with an OHM meter, replace if open.
remember use VOM. God bless you
Apr 02, 2013 | Samsung 2.0 cu ft Over-the-Range Microwave...
Microwave runs but does not heat up food
On many newer microwaves the control panel can stay lit even if the fuse
is blown. (Cartridge fuse inside microwave). If the microwave panel is functional but
no humming this would be a good indication of that.
Make sure power is off before replacing the fuse. Be aware the capacitors may still hold
a good charge and avoid touching the leads to them. (They look like metal cans with tabs
usually). The fuse will be an automotive style fuse with a ceramic middle. These are
available for a couple of dollars at any appliance parts store, and possibly radio shack.
The rating is stamped on the metal ends (250 V= two hundred fifty volts) (4A= four amps)
Make sure to use exact amperage and equal or higher voltage rating. These are a slow blow
fuse.
If the microwave is humming but not cooking then I would suspect the Magnetron tube
has failed. Many times the cost of the replacement doesn't justify it's purchase.
Hope this helps.
Mar 05, 2011 | GE JVM1850 1000 Watts Microwave Oven
Coffee maker pluged
pour vinigar in than sunbitch then let it sit fer 45mins, maybe an hour then turn that hot puppie on and let that vinigar go through her then do the same thing with water and it should be set and if she aint then you got yourself a defective coffee maker and you should go buy a new one i reccomend the john deere model fx762 gets the job done
Dec 05, 2010 | Microwave Ovens
When i turn on my microwave it cuts out afer a couple of seconds and displays H 95, john thanks
Please check your TCO- thermal cut out sensor mounted on the cavity . If this senses a higherr thermal point it might cut off.
Also check on the main capacitor or if the magnetron is faulty.
Helpful?
Aug 25, 2010 | Neff Microwave Ovens
Installed in 2/29/02, The unit stopped working today. Totally dead. I checked the plug (fine), checked the circuit, fine, and power to house is fine.
2 simple things to check: Inside there is a fuse (15 A) check it. Check that the TCOs (thermal cut outs) are closed ie zero resistance across them.
Oct 28, 2009 | Whirlpool GH7145XF Microwave Oven
No power operation.
GARY, IF YOU LOOK AT THE FUSE WITH A MAGNIFING GLASS IT SHOULD GIVE YOU THE VOLTAGE AND AMPS OF THIS FUSE
Aug 23, 2009 | KitchenAid KCMS185J Microwave Oven
I have an Amana Microwave mvh250C, won't warm food
Absolutely not worth fixing as a brand new one with lots of features can now be purchased for as little as fifty dollars.
May 14, 2009 | Amana MVH250 Microwave Oven
Microwave Ovens Logo
15 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
