Question about GE Profile PFS22 33" Artica French Door Refrigerator w/ 22.2 Cu. Ft. Capacity, ClimateKeeper System ...
Spraying GE Artica
Recently water stopped coming out of our in door dispenser and we could hear a loud gurgling sound coming from inside. As it turns out water was leaking from near the filter and made quite a mess. I assumed my filter was clogged (it was overdue to be changed) so i removed and installed a replacement. Well the leaking which is actually more of a "spraying" is still occurring. The filter appears to be secure and tight. Could one of the hoses that lead into the filter be clogged or the like? I cannot see anything obvious that would be causing this.
  • 248 Answers
Check to be sure the filter wasn't frozen. Temp should not be below 35. A plugged filter will not cause leaking. If water still leaks from above filter, you need to replace filter head.
Posted on Nov 04, 2007
Water dispenser not working GE model GSH25JSX13
Do you hear a slight buzzing when you try to get water?? If yes, you may have a frozen water line inside the freezer door. GE had some problems with those models. They offer a heater kit that has to be installed in the dispenser area of the freezer door. Once installed, in about a day the water line should be defrosted enough to dispense water again. If you don't hear that buzzing sound when trying to get water, you could have a bad inlet valve which is at the lower back of the refrigerator where your house water line hook to the refrigerator.
Mar 04, 2015 | GE Refrigerators
I have a GE Profile refrigerator Model # PSC23MGTC it has an Artica Water & Ice dispenser on the freezer door, the ice will not come out, and noew the water works only when it wants to, I think I need...
Cut and paste this Factory Service manual for your refrigerator.
The troubleshooting guide will help locate the bad part.
http://appliancejunk.com/ge/refrigerator/31-9072.pdf
Aug 08, 2010 | GE 23.1 Cu. Ft. Side-by-Side Refrigerator...
Hotpoint HSS25GFP with a loud howling sound in freezer and no water dispensing
The howling sound usually comes from an electronic control when it's going bad. I've also heard of the noise coming from the special shaped condenser fan you have underneath around back. GE may have a fix for this.
Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws. Covering the opening with a blanket will prevent the loss of cold in the freezer. . GE makes a heater that will prevent this from happing again. The part number for this heater is WR49X10173.
disconnect the line to the water dispenser at the water inlet valve on the back where the water supply comes in and try the dispenser. if you hear the valve work but water doesn't come out, the valve is bad. If you don't hear the valve, the dispenser switch is bad
Feb 14, 2010 | Hotpoint HSS25GFP Side by Side...
2002 GE Artica Fridge stoppped cooling and freezing.
Hi monica ,
the heating element in your freezer might be bad or the thermostat. that is way your freezer is not melting the ice inside and the noise that you hear it's the fan that prob' tuch ice or also is getting bad.
let me know if you need more help...
Jan 08, 2010 | Refrigerators
Water won't come out of the dispenser. I Checked to the door and the water works to the door, but won't come from the dispenser.
open the door, place a blanket over the opening to keep yopur food cold, and use a blowdryer on medium to warm up the inside of the door in the area where the water comes out. It should thaw the line.
I had the same problem yesterday, and the water was flowing normally in about 10 minutes.
if you dont have a dryer, it will thaw on it's own, but may take a little longer
Dec 10, 2009 | GE Profile PFS22 33" Artica French Door...
I have a GE profile Arctica with side by side doors (psc23ng). There is a valve at the bottom rear right (facing the refrigerator) with seperate red and blue connections for water. It appears to be a valve...
That sounds like the water valve that receives water from your house plumbing and sends it to your icemaker and to the water dispenser. In addition to the hose connections, there are likely some electrical connections on it.
The valve should be readily available at any of the appliance parts places that sell on the internet. It should be fairly easy to replace. Most of those are pretty accessible.
Oct 20, 2009 | GE Profile PFS22 33" Artica French Door...
I have a ge gsl25jfta bs, it is a frost free refrigerator but recently it is developing lot of frost around the water dispenser area(inside). It started when my water dispenser had stopped working and i...
Sounds like the flapper is not shutting completely. Open the door and look into the door flapper hole from the inside. If its not closed its either stuck (push closed from outside) or broken. If broken you will need part replaced
Oct 05, 2017 | GE Refrigerators
GE Profile Artica - Water & ice dispensor not working.
This could be as simple as the door switch or as complex as the dispenser control board. I would try the door switch first. When the door is close it turns on the dispenser controls. If the contact is defective in the door/light switch then this happens. Unplug remove the door switch and mark wire locations. 1 Powers the lights and the other powers the dispenser. and one is the power itself. Sea Breeze
Jul 26, 2009 | GE Profile Arctica 25.4 Cubic Feet...
I have a side by side GE profile Artica refridgerator. The Ice maker is producing, but I cannot get water to come out. When I push the water dispenser, I can hear something happening, but nothing comes...
One of two things. Water solonoid in back defective or water line insideof freezer door is froozen. I just posted a write up about this. Check other response. UJ63
Mar 01, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile PFS22 33" Artica French Door Refrigerator w/ 22.2 Cu. Ft. Capacity, ClimateKeeper System ... Logo
143 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
