Question about ASUS Computers & Internet
Monitor is displaying only black but other lights are working
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 44 Answers
My first suggestion would be to check that your cable between it and your video card is secure, even unplug and plug it back in as a test. That is the easiest and cheapest fix, but your problems could be much worse, such as a hard drive or motherboard failure on the PC itself. If possible, try starting your PC using another monitor. If it starts normally then the issue is either with a loose monitor cable or perhaps the monitor is faulty...Good luck! :)
Posted on May 09, 2014
M93p suddenly the screen goes black screen
Here's some tricks I would try...
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or orange or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Good luck
Jun 19, 2014 | Lenovo M93P Tiny I7-4765T 8GB 500 WIN7/8
BOUNCING CHARACTERS/DISPLAY
6. If the power light is on and yellow or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
Mar 22, 2014 | AOC 19" LED Monitor e950Swn Black
Black screen
first check your display in monitor with the help of vga cable attach your laptop in the monitor,if display comes in the monitor it means your screen faulty .or if display cant seen on monitor it means there is an fault on MOTHERBOARDS BGA CHIP.
Jan 29, 2014 | Lifetime Acer Aspire 4736Z Replacement...
Screen goes black or pixelates
Aug 18, 2013 | ViewSonic VX715 17" LCD Monitor
Latitude B130 screen works great then cuts out to complete black, works with external monitor
Are you sure that the display is not set for external monitor only? Also take bright flashlight and shine on the display. If you can see the images then the problem is with the back light and usually caused by a bad inverter. Some times you can get the back light or inverter bu most times it is easier and cheaper to replace the entire display.
Aug 20, 2012 | Dell LATITUDE Computers & Internet
Black display
You say black display. Not sure what you mean. Either the monitor is working or it is not. If you see nothing on the monitor and the power light is yellow, then it is not getting a signal.
If the power light is green and you see nothing, look really closely. You might even shine a flashlight at the monitor to see if there is actually a dim display. If so, the backlight has gone out and needs to be replaced.
I'm assuming that you have tried to brighten the display with the monitor controls.
Jan 09, 2012 | ViewSonic VA720 17" LCD Flat Panel Monitor
Power light on but there is no display.
I have the same problem with my acer al1617b if you get any suggestions please let me know
thanks
Nov 11, 2009 | Gateway FPD2275W LCD Monitor
My monitor light comes on but there is no signal.
Isolate the problem. Connect the problem monitor into different computer. If the problem monitor worked on another computer, try connecting a CRT monitor to the problem computer. Once the display comes back, change the screen resolution.
Jul 29, 2009 | Gateway FPD1775W Monitor
When it's turned on, the light on my monitor blinks but the screen doesn't display anything. Why might this be happening, and how can I fix it? Monitor will go on for a split second, then screen will go...
they normally turn off like this when they aren't receiving a video signal from the pc (same as when you turn off the pc). make sure that it is connected properly, and that the video output is activated. try disconnecting from the other monitor while its on and connect the problem monitor...if it still isn't working then there may be a problem with the cable or the monitor itself. Try another VGA or DVI cable. Hope this helps
Mar 29, 2008 | Computers & Internet
Computers & Internet Logo
46 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
