Question about Video Cameras
Sd card error
Card err is displayed
  • kakima May 08, 2014
    What make and model camera? What size memory card?
2 Suggested Answers
david_hanna
  • 58 Answers
SOURCE: how do I correct a sd card error display
you may have to format the card using a pc/laptop, if the laptop picks the card up then format the card using FATx or FAT32 do not use NTFS for cards (you can use it but not recommended if using it in various electronic devices) if the card wont format then its simply faulty and a new one is needed.
Posted on May 09, 2014
Why is my camera reading err sd when I insert sd card
I can think of a few possible issues:
1. SD card not formatted (format it in the camera)
2. SD card bad. try another one.
3. SD card bigger than camera can handle.
Sep 16, 2014 | Wildgame Innovations IR4c Digital Game...
SD Card Error ATC3K
https://sportcameramanuals.jimdo.com/oregon-scientific/ for free.
Jul 05, 2014 | Oregon Scientific ATC3K SD Card Camcorder...
I have the a Casio Keyboard that has an SD slot, but whenever i put songs on my SD card & then plug it into the keyboard, it says that there is an ERROR . What am i supposed to do . Step by Step . to...
Does it say ERR NO FILE? If so, then read on. The reason you have this error is because you don't have a folder on your sd card named MUSICDAT. Solution:
  1. Insert your sd card into computer
  2. Make folder called MUSICDAT.
  3. Then, transfer all files inside the folder (make sure your songs are in MIDI format).
  4. Safely remove your sd card.
  5. You're ready to put it in you Casio Keyboard!
If you still get the error, take time to read you manual. Read the "using the sd card" part. The folder name might be different for your Casio Keyboard (because mine's a CTK-5000).
...and IF you still get the error, perhaps the songs you meant in your question are MP3 songs (like the ones you play on the iPod)? Then, that's a different topic... :)
Well then, good luck!
Feb 28, 2011 | Casio Lighted Keyboard LK90STADMC
When I put a SD card in the slot, it says SD ERR
hi, when it says SD error it must be some problem with the card or else the slot alone. so try a different SD card first. look at one important thing. see to that the lock in side of the card is released. also wipe the golden contacts in the card with a cotton dipped in alcohol. this must work for you. else revert back to us. thank you sweet rascal
Oct 18, 2009 | Naxa Electronics NX-252 7 in. Portable DVD...
Card Error
If you should see the warning message "CARD ERROR" in the LCD Display, please check the following: Always choose reliable quality SD Cards. Toshiba Digital Cameras are tested for maximum performance with Toshiba SD Cards, Delkin SD Cards and Panasonic SD Cards. These are leading brands in the development of standard SD technology. Performance by other brands of SD cards may vary. Check the LOCK switch on the SD Card. The camera can not save images to an SD Card when it is in the lock protected position. If the SD Card is NEW, it may be necessary to FORMAT the card. This only applies to NEW SD Cards. If you format a card with images, all images will be erased. You can FORMAT your card periodically to maximize capacity and erase 'unseen' files, please be sure to download all images before choosing FORMAT as all images will be erased. Your Toshiba Digital Camera is designed for use with SD Cards. MultiMedia Cards are similar in size and shape to SD Cards, although with close inspection you will find that SD Cards have a different 'PIN" connection configuration, are slightly thicker in size, and have a manual slide LOCK switch on the side. Toshiba Digital Cameras are not designed or guaranteed to accept MultiMedia Cards. Please be sure to look for SD Cards from Toshiba, Panasonic and Delkin, the leaders in SD Card Technology.
Sep 11, 2005 | Toshiba PDR-3330 Digital Camera
Card Error
Sep 11, 2005 | Toshiba PDR-3320 Digital Camera
Card Error
Sep 11, 2005 | Toshiba PDR-3300 Digital Camera
Card Error
Sep 11, 2005 | Toshiba PDR-2300 Digital Camera
Card Error
Sep 11, 2005 | Toshiba PDR-2 Digital Camera
Error 50
The "E50" error code indicates formatting a SD card has failed. Solution To clear the "E50" error, try performing the following procedure. 1. Try using another SD card. If you have another SD card, try loading it in the camera. If the error code is not displayed when the other SD card is loaded, there may be something wrong with the first one rather than with the camera. 2. Use your computer's ScanDisk utility to check the SD card for errors. Use ScanDisk to check the SD card for card error or card failure. Refer to the instruction manual for your operating system or Windows Help for further instructions. (If you are using a Macintosh, use the "Disk First Aid" program to check for card error or card failure. Refer to the instruction manual for your Macintosh OS for further information.) Be sure to back up the data on the SD card on the computer before you check the SD card. If a card error or card failure occurs when you use your computer's ScanDisk, there is something wrong with the SD card. Follow ScanDisk's on-screen instructions to solve the problem.
Aug 31, 2005 | Canon PowerShot SD110 / IXUS IIs Digital...
Video Cameras Logo
79 people viewed this question
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
