Question about Arctic Air 22 cu. ft. Commercial Freezer F22CWF
Arctic freezer where are the coils
Where are the coils
    Problem Solver:
  • 5 Answers
The evaporator coil is behind the ss panel inside the box behind the shelves. The condenser coil is underneath, accessible from the bottom rear of the unit.
Posted on Apr 01, 2015
    Problem Solver:
  • 12 Answers
If you are speaking of the condensoning coil on your freezer you will not see them because they run in the outside cabinet walls. This is why you freezer feels warm on the outside. That is why you will not hear or find a condensing fan.
Posted on Oct 13, 2014
    Problem Solver:
  • 14 Answers
Some freezers don't operate with coils. If you search for that on google you might be able to find the parts manual. Your other option, assuming it is broken, is to find a replacement. http://www.refrigerationice.com/Services.html
Posted on Sep 24, 2014
Arctic air freezer
motor humming is from 2 things
start / run capacitor is failed
compressor is seized and the motor is not turning
call in an technician for a proper diagnosis and quote
Jul 08, 2016 | Artic Air Arctic Air F22CW12 Commercial...
Error message ,HA on display of Arctic Air AF49
http://www.arcticairco.com/docs/reach-in-owners-manual.pdf PAGE NO. 9
Maximum temperature alarm, Outputs unchanged. I think your board needs to be reseted, but dont do it by your self, look for help.
Regards,
May 25, 2015 | Artic Air Arctic Air AF49 Two Door Reach...
Arctic air freezer building up ice but not freezing
It is a defrost problem. Either the defrost timer is not working or the defrost heater is shorted out. You will need to ohm out the heater. It should have close to infinite ohms. If "open" then that is your problem.
Nov 09, 2013 | Arctic Air 22 cu. ft. Commercial Freezer...
I have arctic air commercial freezer m # F2CW11 s/n# WB338336 freon R134a what psig ? low side and high side when system on
Good day,
When running, the low side is usually about 2 to 4 lbs pressure. The high side is determined by the load and the temperature in the room or area. Minimum 125 lbs. maximum approx. 150 lbs.
Oct 28, 2010 | Arctic Air 22 cu. ft. Commercial Freezer...
The temp only goes down to 30 farenheit. the thermostat control knob is set to the coldest position. is the thermostat faulty or can it be adjusted?
Check list:
Fans running
Compressor cool to the touch
Not short cycling (low freon)
coils cleaned
no air restrictions
If all of that is good bypass the control
see if it gets down to 0
If it does replace the control
May 25, 2010 | Arctic Air 22 cu. ft. Commercial Freezer...
Heat strip not working in freezer
What they are talking about is the defrost coil...
The most common problem though is the defrost timer fails....
Here are a couple of tips that I wrote that will help you figure this out...
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
heatman101
Apr 15, 2010 | Arctic Air 22 cu. ft. / 623 liter Upright...
I have ice build up in the coils and the freezer is not freezing , thawed the coils with a dryer but in a couple of days it is back again
Can't locate specific manual for your product but sounds like a defrost problem.
Unit should defrost on a regular basis. Usually controlled by a timer. It should turn refrigeration system off, including fans, and turn on heaters to clear any frost or ice on the evap coils. Cycle varies on usage. Look for timer and see if it is running. Make a mark on it and give it an hour and check again to see if it has moved.
Hope this gets you started.
Mar 03, 2010 | Arctic Air 22 cu. ft. Commercial Freezer...
Ice build up
Sounds like moisture built up in insulation and may be defrost problem. If you can check inside coil to see if it is clear then moisture is in wall and carrying cold to out side or area is not well insulated. Again hard to tell with out getting into it .
Jun 28, 2009 | Arctic Air 22 cu. ft. Commercial Freezer...
Have a arctic air f22cwf freezer that will not freeze right
There is a starter relay on the compressor. It sounds like it needs replacing. If you listen for awhile when it trys to start the compressor there will be a clicking sound but then nothing will happen. That is the most likely cause.
May 05, 2009 | Arctic Air 22 cu. ft. Commercial Freezer...
Arctic Air 22 cu. ft. Commercial Freezer F22CWF Logo
170 people viewed this question
Top Arctic Air Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you an Arctic Air Freezer Expert? Answer questions, earn points and help others
