Question about GE JKS05 Electric Single Oven
Cut out dimensions for GE model JKP60 - GE JKS05 Electric Single Oven
I have a GE wall oven, model # JKP07G004B0 and I would like to replace it. I need to know which new one will fit the space.
Since it is so old the diminsions are no longer available online and the only way to get the size is pull it out 4-6 inches and measure height,width and depth of the cut out portion of the cabinet it fits into
GENE
Jul 30, 2011 | GE Ovens
GE Model JKP44GOV1BB need dimensions of this OLD GE OVEN to see if it will fit the space allotted
The measurement's should be 30" wide, 36" tall and 26" deep.
May 02, 2011 | Ovens
GE Elec oven JT952-30" blinks the "lock" after self-clean
Try unplugging power cord or trip circuit breaker, to cut the power to the appliance, then wait one or towo hours for the oven to cool down completely.
If the door stays locked, then there is a fault, probably a faulty temp probe that had blown because of high temperatures generated on self cleaning, or a defective control assembly. In that case you will need to call a technician to take apart the oven and fix the fault.
Enter model number here to find assembly diagrams and parts.
Jan 02, 2009 | GE Profile JT952 Electric Double Oven
Replacement for built in oven/microwave
Hello tippett_631
Welcome to fixya,
You said, ,
22 years ago you built the house you are currently living in. The above oven/microwave oven was built in. You are interested in replacing this unit with a new unit but it must be the same size. ? by the way i You would be happy with a double oven versus the microwave/oven duo. You have measured across the front of the unit and it only measures 26" across. Any assistance you could give us would be greatly appreciated.
I can help you!
The front is 26 inches.
And how high is it from the top to bottom?
Also when I sell a wall oven I always send out the installer to check the hole or cutout size.
Most of the time no wall oven fits with out at least one cut!
Do you have any room to cut a little on all sides?
What is your model number now. And what color do you want now??
I will send you some GE wall oven models and sizes so you can check your self if it will fit. usually they have to cut at least one side to fit it in the old hole!
Sep 25, 2008 | GE Ovens
GE JKS05 Electric Single Oven Logo
62 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a GE Oven Expert? Answer questions, earn points and help others
