Question about Canon BJC S450 InkJet Printer
What is the large orange plastic piece on a canon pixma 3200 printer?
2 Suggested Answers
MUKHTAR
  • 2022 Answers
SOURCE: Why is the orange light on my Canon IP5200 printer keep flashing?
make sure all the catridges are proper and there is no paper jam inside in the printer.
Posted on Jan 14, 2010
I bought new ink cartridges. They will not fit
take the plastics ink cardriges protectors, and try again. the orange plastics, is to remove. Only is necessary for transport, outside of printer (ink slot).
Dec 22, 2009 | Canon PIXMA MP600 all-In-One InkJet...
HOW TO REFILL THE PRINTER CARTRIDGES OF mp830
here are the instructions:
http://www.refillinstructions.com/Canon/C15.htm
I pour up to 15ml. in PGI-5BK (the large black) and 10ml. in the other ones (small black + color).
You can seal the hole that you make with silicone and put a piece of adhesive tape over.
Also when you remove the orange seal, leave the cartridge for a couple of minutes, cause it usually leaks a bit. You can put it on some tissue, that will absorb the excess ink.
Dec 14, 2008 | Canon PIXMA MP830 All-In-One InkJet...
MP830 has a 6A00 code
The 6A00 is a Canon generic code for paper path jam and seems to be a very common problem with these printers. Click Here to read some resolutions to this issue that may or may not work for you.
Nov 23, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Ip4300 canon pixma
I have the Canon Pixma iP4000R printer. I had an error code of a600 and my power light was blinking/flashing green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange (12 oranges).
I tried the “waste ink counter reset reset” procedure: Power on while holding the stop/reset button and pushing the service button twice, then pushing the stop/rest button 4 times to clear the error, but that didn’t work.
My ink cartridge carrier wasn't moving. I thought I had a paper jam.
I looked at a few blogs about my error on other Canon Pixma models and they kept talking about “sponges”.
The following is what I discovered that cleared my error and now my printer is back to printing!
The “sponges” are 2 hard pieces of absorbing plastic or something of the like. I was looking for a softer material like long thin gray foam strip material in my printer. The 2 "sponges" on my Pixma iP4000R were next to each other-one was rectangular and one was square-like. Originally they were white but the ink made them black/navy.
The "sponges" are located on the right under where the ink cartridge carrier "rests".
I didn't see the sponges at first, as there was a white “L” shaped plastic piece that had a spring attached to it. The “L” shaped piece was moved forward out of its place. I used my pen tip and pushed that piece back and found that the rectangular "sponge" had popped out of its place.
I used a pen tip popped both “sponges” out and rinsed them with water and voila they were once again white. I think the rectangular one had so much ink on it it popped itself out of place.
My error is gone and I can print again!
Nov 19, 2008 | Canon PIXMA iP4000R InkJet Printer
Error code 6A00
6A00 error on a Canon IP4200 is an AP Postion Error. This means one of three things. A problem with the sheet feeder, Logic board or the Purge Unit. Sadly these part are either working or not working and are difficult to repair. You could try resetting the EEPROM on the unit by entering service mode. A service manual will show you how to do that:
http://www.tradebit.com/filedetail.php/4593231-canon-pixma-ip4200-printer-service-manual
If that helps please rate my solution
Nov 03, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Error Code 6A00
I have the Canon Pixma iP4000R printer. I had an error code of 6A00 and my power light was blinking/flashing green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange (12 oranges).
My ink cartridge carrier wasn't moving-staying in the center. I thought I had a paper jam.
The “sponges” are 2 hard pieces of absorbing plastic or something of the like. I was looking for a softer material like the long thin gray foam strip material in my printer. The 2 "sponges" on my Pixma iP4000R were next to each other-one was rectangular and one was square-like. Originally they were white but the ink made them black/navy.
I didn't see the sponges at first, as there was a white backwards “L” shaped plastic piece that had a spring attached to it. The “L” shaped piece was moved forward out of its place. I used my pen tip and pushed that piece back and found that the rectangular "sponge" had popped out of its place.
Apr 16, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Had paper jam. removed paper, now getting 11 flashes, but cannot clear error as per manual instructions. getting service error 6A00.
I didn't see the sponges at first, as there was a white backwards “L” shaped plastic piece that had a spring attached to it(purge unit). The “L” shaped piece was moved forward out of its place. I used my pen tip and pushed that piece back and found that the rectangular "sponge" had popped out of its place.
Apr 08, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
CANON MP830 PRINTER ERROR CODE 6A00
6A00 is a purge unit fault, if you have have a years canon warrenty i would call them and get a engineer out to investergate the fault, If not strip machine and and see if the purge unit is moving back and forward. it could be that the carriage unit is stuck on the purge and the carriage unit cant move.
Hope this helps
Mar 10, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Pixma IP4000 12 flashing lights error 6A00
IP4000 12 flashing lights error 6A00 problem, and notify you when a new solution is offered.
Dec 02, 2007 | Canon PIXMA iP4000 InkJet Photo Printer
Cannon printer mp830
I had the same problem with my Pixma MP830 printer giving me a 6A00 error indicator. I solved my problem. Hope this will solve yours too. I moved the printer head over to the left. I noticed two black pieces of paper or sponges attaced to a spring on the right hand side where the head is at rest when not being used. I with a paper towel absorbed a little of the black in off the paper or sponge like material. I found the two white long pieces held by the spring were forward and would move. I used a ball point pen and moved the closed piece with the spring attached to the rear of the printer and it remained there. I surmised it was out of place because when I started up the printer again my 6A00 error code was gone and my printer was working again. It took me a long time to get to this point (like 6 hours) but that saved me from taking my printer in and spending like $80.00 or more for them to take care of the problem. Hope this helps you fix your Canon Pixma MP830 printer or other models giving the same error code to you.
CALL ME DON W
Nov 01, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Canon BJC S450 InkJet Printer Logo
413 people viewed this question
old marine
old marine
