Question about Frigidaire FGUB2642LF
FGUB2642LF1 ICE t3 error code - Frigidaire FGUB2642LF
What is code 1ce t3
The th3 sensor on the back of the generation 1 ice maker in your fresh food section is out. Check the resistance of the sensor and it should be between 6k - 80k ohms. If the sensor is good the ice maker control board on the back of the unit is faulting.
Feb 19, 2015 | Frigidaire Refrigerators
Error code on my electrolux refirgerator
Good Morning Friend,
I understand you are receiving a T3 error code when you turn the ice maker on your Electrolux refrigerator. I suggest resetting your appliance, by either unplugging your appliance or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and make sure your ice maker is on. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 02, 2014 | Electrolux 25.9 Cu. Ft. Side-by-Side...
How to fix err,30 on canon t3
Have a look here for error code 30
http://www.canon.co.uk/support/consumer_products/product_ranges/cameras/eos/error_codes/
Jun 20, 2014 | Canon EOS 1100D Rebel T3 Body Only Digital...
Canon eos t3 error 30
Error Code 30 indicates that a
Malfunction related to the shutter has been detected.
Apr 17, 2014 | Canon EOS 1100D Rebel T3 Body Only Digital...
Ice t3 error
check water supply line for blockage. check lever is operating correctly. empty tray and see if it makes ice.
Dec 10, 2013 | Electrolux EI23BC56IS (226 cu ft) Bottom...
Freezer temp displays 1 C E refig temp t 3
Hello p_shields123 - Could the actual error code display be "ICE T3"? If so, it typically indicates that the TH3 thermistor in the Fresh Food Ice Maker compartment is shorted or open. Regrettably, this is not a simple DIY job. I would strongly recommend connecting with a professional to move forward accurately and to properly assist with the repairs.
Mar 11, 2013 | Frigidaire FGHB2844L
I have a maytag neptune electric dryer with a t3 code how do I fix it.
Take another look at that code. There is known "T3" error code for this dryer.
Jan 22, 2011 | Maytag Neptune MCE8000AY Electric Dryer
Riso 3770 error code T3
A T3 error code is indication of some kind of problem associated with the clamping mechanism. Most of the time, what happens is that there is a magnet attached to a flag on the rear side of the drum and it has fallen out of place. If you can find the magnet, reattach it with a strong adhesive.
Check for smooth operation of the clamp by hand as well and lubricate if necessary.
Mar 14, 2010 | Riso RZ310 Duplicator
Frigidaire FGUB2642LF Logo
46 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
