Question about Lexmark MX410de - Multifunction fax / copier / printer / - 35S5701
Why won't lexmark mx 410de won't answer fax - Lexmark MX410de - Multifunction fax / copier / printer / - 35S5701
I can't find the auto answer light on the Lexmark X6675
To turn on the Auto Answer for fax, on the control panel of your printer, press on Setup > Fax Setup > Ringing and Answering > Auto Answer > On.
Sep 10, 2012 | Lexmark X6675 All-In-One InkJet Printer
Can lexmark x4650 be set to recognize fax?
For more details on how to setup your Lexmark X4650 printer for faxing, please refer to the User's Guide found on the Lexmark website.
Additional info:If you have an answering on the same line as your fax:
To make sure the printer picks up incoming faxes, set Auto Answer to On, and then set the printer to pick up after a greater number of rings than the answering machine. For example, if the answering machine picks up calls after four rings, then set the printer to pick up after six rings. This way, the answering machine picks up calls first and your voice calls are received. If the call is a fax, then the printer detects the fax signal on the line and takes over the call.
If you have a voicemail feature associated in the same line as your fax:
Voice mail and fax can share the same telephone line if you subscribe to a distinctive ring service offered by your telephone company. This feature allows you to have multiple telephone numbers on one telephone line. Each telephone number has a designated ring pattern (single ring, double ring, triple ring, or double and triple ring). The different ring patterns let you know which telephone number was dialed, and which device you should use to answer the call.
If you do not have distinctive ring service, then set the printer to receive faxes manually (Auto Answer Off). This setting lets you receive both voice calls and fax calls, but works best if you use voice mail more often. You need to turn off voice mail whenever you are expecting a fax.
Feb 16, 2012 | Lexmark X4650 InkJet Printer
Fax won't answer
If you have an answering machine connected to the same line as your fax:
If you have a voicemail feature associated to the same line as your fax:
I hope this helps.
Should you need further assistance, please contact Lexmark Technical Support Center.
Feb 14, 2012 | Lexmark Pro901 All-In-One Inkjet Printer
I cannot receive faxes on my lexmark X4270. It will ring but nothing come through
Please go through the following checklists:
  • Make sure the that the fax line is working. To check, insert a telephone device straight to the fax line. You should get a dial tone.
  • Make sure the telephone cord from the phone jack in the wall is plugged into the Line port on the back of your Lexmark printer.
  • Assign the correct fax number on the printer.
  • If you have an answering machine connected to the same line as the fax, set the answering machine to answer incoming calls before the printer does. Increase the number of rings by a factor of 3 over the answering machine. For example, if the answering machine is set to pick up on 4 rings, set the printer to pick up on 7 rings.
  • If you have a voicemail feature in the same line as the fax, you may subscribe from your phone service provider for a distinctive ring pattern feature. You can program your printer to have a distinctive ring pattern and phone number for incoming faxes.
If these don't help, please contact Lexmark Technical Support Center for additional assistance.
Sep 24, 2011 | Lexmark X4270 All-In-One InkJet Printer
I have a lexmark x5650 printer and I can send a fax but I cannot recieve a fax. Can you please help me?
Ensure that the telephone/fax line is plugged into the Line port on the back of Lexmark printer and not in the Phone port.
Jul 26, 2011 | Lexmark X5650 All-in-One InkJet Printer
Lexmark 5250 won't fax. I have installed everything several times but says something about OCR not working. It will scan & print instead of sending document to Fax. I can open Fax window, but...
Use the Lexmark All-In-One Center application to send faxes from your computer (make sure your computer is connected to a fax modem). From the Creative Tasks section of the All-In-One Main page, click Fax using PC modem. Follow the instructions on the computer screen.
Jul 25, 2011 | Lexmark X5250 All-In-One InkJet Printer
How do I set up the fax auto answer on my Lexmark x364dn? Just started a new job that is very fax-centered, and I cant get my fax to auto-answer! Hooked up thru a GE phone/answering machine, no...
The factory default setting of the printer is set to auto answer, please sure that the connection between the fax machine and answering machine is properly connected. Please click on the link http://bit.ly/qCaWn8 to view more information.
For more information, please contact Lexmark Technical Support.
Mar 24, 2011 | Lexmark X364dn All-In-One Laser Printer
Lexmark All in One X6650 wont answer fax calls unless I hit start button. How do I get it to answer automatically again?
You may refer to the Lexmark X6650 user's guide. If you're using Windows operating system, you can access it by going to the Start menu -> All Programs/Programs -> Lexmark X6600 Series -> User's Guide. Scroll to page 22, Using Fax, for the instructions on how to receive fax automatically. You can also visit the Lexmark website to download the user's guide for free. Click on this link Lexmark 5600-6600 Series Fax Guide. I hope this information has been helpful. Thanks.
Dec 27, 2010 | Lexmark X6650 4-In-One Wireless InkJet...
X6690 fax setup
Turn auto-answer off and you can manually answer fax calls by pressing 9 on your touch-tone phone. See page 22 of the Fax Guide.
Jan 04, 2009 | Lexmark Office Equipment & Supplies
I can not receive a fax
First, make sure the phone line to the fax is plugged into the LINE socket, NOT THE PHONE socket on the machine. Next, try calling your fax machine from a cell phone to see if the fax answers. If no answer, you may have to go into FAX SETTINGS or FAX SETUP from the Lexmark menu. You may have to change any or all of the following: RINGER SETTINGS, AUTO RECEIVE, RECEIVE MODE, TONE/PULSE DIALING, OVERSEAS MODE, ETC. Trial and error getting the Lexmark to answer calls from the cell is probably the easiest way. BEFORE YOU START, print out or write down each setting you may change. This way, if it does not work, you can go back to the original setting.
Nov 23, 2008 | Lexmark Office Equipment & Supplies
Lexmark MX410de - Multifunction fax / copier / printer / - 35S5701 Logo
49 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
