Question about Sub-Zero 700TC Bottom Freezer Refrigerator
Sub zero 700 tc freezer drawers hot - Sub-Zero 700TC Bottom Freezer Refrigerator
JOE LLAMA
  • 26 Answers
SOURCE: Sub Zero Freezer Vacuum
If your freezer temps are ok, it may just be that your gasket is getting older and it becomes more porus as it ages. The vacume sound doesnt really mean alot except that the difference in the room temp and the cold of the freezer create this vacume.
Posted on Mar 31, 2008
SOURCE: Freezer not working on Sub-Zero 550 Refrigerator/Freezer
You probably need to defrost freezer - frozen moisture possibly stockedevap. fan motor in the freezer. Turn it OFF for 24 hours and start itover. Make sure no moisture condensation on the freezer compartmentsurfaces as walls and shelfs. If so wipe it out. Pull out and remove upper basket from the freezer, push fan switch which is located almost under ice maker.You have to hear evaporator fan motor start working. Still not work? Call to professionaltechie! Good luck! :)
______________________________
http://www.SubZeroLosAngeles.com
Posted on Nov 12, 2008
  • 56 Answers
SOURCE: sub zero 700 TR error code 06
Error code six means: from SZ
Refrig. evaporator thermistor read open or shorted for 10+ seconds, or repeatedly read erratic temp’s
Erratic temp can be many things such as an open door. Clear the code by holding the bell key for 15-30 seconds or until you hear a tone. Keep an eye on your temps for a couple of days. If it comes back its time to call a service tech. If you are in OC I have the number of the best tech for Sub Zero in all of SoCal. There is more tests that can be done depending on how tech savvy you are.
Posted on Jan 23, 2009
SOURCE: Sub-zero 550. freezer icing
You probably have some food on the way. Unload the freezer and see if the door would close better. Looks like you have a warm air leak.
Sub-zero refrigerator repair in orange county, ca
appliance repair orange county, ca
Posted on Feb 06, 2010
SOURCE: sub zero 650: freezer drawer rollers squeak. Any
Good solution...don't use WD40. A great product is called JIGALOO. It does not leave a sticky coating and that means a smooth operation. Also great for sticking windows and door hinges. No drip and no mess.
Posted on May 26, 2010
Refrigerator sub zero 736 TC water leaking under vegetable drawer
Usually from plugged evaporator drain tube.
remove all the drawers and unscrew the frame that holds the drawers. Free the the drain tube (need to unscrew the clamps that hold the tube to the back wall). Pull it up from the bottom hole where it drains into the pan and free it from the top drain pan. Most likely it\'s plugged with crap and fungus and yecchy stuff. Clean it out and reinstall it.
Jul 09, 2014 | Sub-Zero 650 / O Bottom Freezer...
Water is leaking out from the fridge floor onto the ground.
The drain pan in the back evaporates from the heat of the compressor. The freezer drain drains into this pan. If there is water under the bins it sounds like the drain is partially clogged and over flowing into the refrig section. But I need more info, like model , brand.
Nov 17, 2013 | Sub-Zero 700 Refrigerator Freezer...
Sub Zero 700 TC with two freezer drawers on bottom. Ice sheet is forming on the bottom below the drawers and causing the drawer to stick. I have defrosted the freezer with a hair dryer and thought this...
How are the ice cubes? Are they normal size or hollow? I was wondering if some of the water was not making it into the ice maker and causing this issue. Is there any frosting issue not mentioned? Any water droplets on or around the back wall of the unit (inside)? I am a service tech certified and would like to know more about this issue. Have you cleared the drain completely, meaning after you de-iced unit, did you use water to verify the drain was cleared?
I you like to know more, so I can direct you in solving this issue.
Sep 22, 2013 | Sub-Zero 700TC Bottom Freezer Refrigerator
In the control panel apear two bars like this - -
You have a code error that needs to be fixed. Call either your mfr or refer to manual or google the problem , include. Model # and code .
Feb 07, 2013 | Sub-Zero 700 Refrigerator Freezer...
My freezer drawers are very warm All food defrosted smells horrible even after cleaning. Should I clean condensor, temp is not cooling?
It is likely the condenser fan is not functioning, or the condenser is dirty. You may need to open the compressor access panel to check. If you can hear the compressor running, and the condenser feels warm, the fan should be running. If it isn't, it probably needs to be replaced. Another symptom is the area around the doors feels warm.
Jan 01, 2013 | Sub-Zero 700 Refrigerator Freezer...
Sub Zero 700 suddenly stops after 12 years. Compresser is burning hot.
The compressor will normally be 100 to 110 degrees. I would suspect the thermostat or mouse damage in the freezer area. Also, if you keep it overstocked, to the point of poor air circulation, you could just have ice blockage. Put the frozen food in a styrofoam cooler or a good heavy corrugated box and give the unit a good full defrosting.
Dec 15, 2012 | Sub-Zero 700 Refrigerator Freezer...
Water on floor
The hose that goes into the drip pan to defrost the refer is plugged with stuff.
take the back off and see the hose connection.A coat hanger works well.Usually a 1/4" hose.
Also see where the bottom of the freezer drains into the drip pan.That may be plugged,also.
The temp may be set too low and the condenser is frozen up,leaking water into the floor.Just ice stuck to the condenser.
Possible that the condenser FAN stopped turning. That will ice up and melt at random:
see/hear that the fan is working.
If stuff gets into the fan,it will ice up,melt and make a mess on the floor.
Nov 26, 2012 | Sub-Zero 700 Refrigerator Freezer...
Is there a way to remove the drawer in the bottom freezer?
Pull the drawer all the way out until it stops. Then lift the front of the freezer drawer (a couple of inches), and pull out further (4-6"). The front will then lower to the floor. Lift the back of the drawer upward and slid the entire drawer forward. You may want to protect your floor. I did the above with the freezer drawer full and scratched my floor a little...
Jun 27, 2010 | Sub-Zero 650 / O Bottom Freezer...
The freeszer door on my Sub Zero does't have suction anymore
what is the mod num> 650, 700? no a lot help. check the freeze inside the upper part for any ice build up
Apr 02, 2010 | Sub-Zero Bottom Freezer Refrigerator
Refrigerators Logo
48 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
ACME Sub Zero...
ACME Sub Zero...
Sal DeAngelo
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
