Question about Hoover Ultra U6430-900 WindTunnel Bagged Upright Vacuum
Motor shaft getting really hot
So that it melts the flat belt and starts to smoke. Any solution?
  • 833 Answers
Open up the area where the beater is with the belt off. Turn the beater by hand...if it turns hard, the bearings are jammed up with old grease or debris. You'll have to deal with that.
Posted on Dec 07, 2007
Bissell bagless motor shaft is too hot and melting belts
My guess is that the roller binds on the carpet (high pile?) and the motor shaft, glazed from use, spins without moving the belt and quickly burns a hote through it. I've had that experience!
Sep 27, 2012 | Bissell Vacuums
I have a Eureka Power Plus vacuum, model 4702, type A. To start off, it never really had great suction. Marginal at best. Then today I was vacuuming and smelled something burning and turned off the...
If it is the motor it may smell electrical and the motor is likely shot. It's very possible it needs a new belt. Your model has a stretch belt and they should be replaced at least every six months (even if it's never been used) because belts need to be stretched so far to be installed they will lose elasticity and slip on the shaft which can cause the belt to melt.
Jun 26, 2017 | Vacuums
I have a Kenmore Whisper Belt 116-50612007. Up until now it has worked tremendously well. Suddenly, it is smoking from the power nozzle when I vacuum. I checked to see that it wasn't clogged up and that...
It's most likely the belt. A loose or worn belt will slip on the motor shaft and cause the burning odor. Take a look at it first, check for obvious wear and/or melting.
However, if the brush is spinning properly, it could be the motor on it's last legs.
Jan 02, 2011 | Vacuums
The little belt inside the head of the vaccum with the beater bar is not always spinning therefor is melting. Is it normal for the metal pin that it is going around on to get really hot?
The Belt should be changed at this point. This will allow for the proper tension to be on the brush between the motor assembly (metal pin) and the brush so that it spins at the proper speed.
Is it "normal" for the metal pin (motor shaft) to get hot.... not normal, however in the problem you have described, yes it is normal for this situation.
Change the belt and your problem should go away.
Nov 05, 2010 | Filter Queen Majestic Canister Vacuum
How to fix a vacume that is smoking
any electrical unit that smokes,is ,not worth repairing
Jul 01, 2010 | Eureka 2961AVZ Bagless Upright Vacuum
Smoke came out of vacuum cleaner while I was using it - what would cause this?
belt probably melted due to brush assembly seezing ,this has a bearing on each side and if you replace the belt and brush assembly make sure you clean all the ols belt residue off the shaft motor ,put it all back and you are good to go
May 10, 2010 | Bissell 37604 Lift-Off Pet Bagless Upright...
Vacuum Belt keep breaking
When your first belt burnt, the burnt plastics goes into the roller ends and then it dries off causing your roller to not turn or put more pressure on your belt. Until you clean that you will continue burning your belts soon after you put them in. You need to add a little bit of WD40 or any other type of lubricant after you remove the tar from the roller.
Feb 26, 2010 | Dirt Devil Breeze Bagless VacuumVacuum
Vacuum belts smokes and needs to be replaced 3x's in 6 months is tis normal or did I get a lemon
brush roller berings may be faulty making the brush stick and motor shaft spins against belt causing melting. remove brush roller, clean out end berings and see if ends spin freely or if they stick. if they stick, you might need to replace brush roller.
Jul 30, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
Belt and lifter getting hot right away on start up.
I would say that it is definitely running backwards. I have a guide to replacing the power switch that outlines the reassembly of the Kirby and tells you which carbon brush wire plugs into which hole on the power switch. Each carbon brush has a letter (B or O) and the same two letters are on the switch to help you get the wires back on right. (the "B" attaches to the "B" and the "O" attaches to the "O") Here is the link to the guide and I hope it helps,...
Jun 19, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Vacuum motor shaft too hot
Check the brush roll ends, will they turn easily or is one frozen. If so, you need to replace the brush roll. If the motor turns on, it and the belt are trying to turn the brush roll and can't. Also check the ends where the brush roll sits in and make sure it hasn't overheated and melted., If it did you will have to replave the base.
Mar 11, 2008 | Dirt Devil Featherlight Bagless Upright...
Hoover Ultra U6430-900 WindTunnel Bagged Upright Vacuum Logo
134 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
