tv changes from by itself tv/video mode to video 1 then to video 2. i cannot get the remote to work while this is happening. when the tv stops doing this for a few minuets i get picture and sound good. then its back to tv/vid mode.
I would check to see if the Input button is stuck on the front panel of TV. If it is not stuck then it is probably still bad. Tactile switches are notorious for failing in this manor. The only real fix if it is not stuck down is replacing the switch.
I hope this helps,
Skyassoc
Toshiba 36A43 36" TV - The menu keeps coming up every few seconds and changing options on it's...
(More)
Toshiba 36A43 36" TV - The menu keeps coming up every few seconds and changing options on it's own. Like someone is using the remote, but the actual remote is unresponsive. The remote does work at times, but the main issue is the menu screen coming up on its own and making changes - on its own.
Toshiba 36a43 tv has the demonstration screen running constantly over regular programming. Can't get...
(More)
Toshiba 36a43 tv has the demonstration screen running constantly over regular programming. Can't get it to shut off, remote will not respond & there is no reset button. Help please?
Our Toshiba 36A43 was just repaired. A new power supply was put in, bring home and volume goes down...
(More)
Our Toshiba 36A43 was just repaired. A new power supply was put in, bring home and volume goes down to 0. Bring back up ,goes back down. Is this part of the power supply kit I paid for?. Ive put in $194. already. Kathy
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
