Question about Fujinon EC-450HL5 Colonoscope
250 series colonoscope wont sray water
Will not spray water when push the button
  • 48 Answers
Check that there is water in the source (tank or water hose). Maybe the opening is filled with fecal matter
Posted on May 15, 2014
Why is the upper sray arm is not working in kitchenaid model KUDR01TJ
There are 2 spray arms for the top rack. A small one on the dishwasher top and a bigger one attached to the bottom of the upper rack. Both get water feed from a flat tube that runs up the back wall of the dishwasher. Not much to the very top little arm--just check the spray holes for any food blockage and try to clean with a brush or tooth pick. The bigger arm on the bottom of the top rack gets its water feed through a hole about half way up the flat tube on the back wall. When you push the rack all the way in, it has to plug itself into that hole in the back wall. Check that plug in area and make sure nothing broke off that would keep it from making a good seal with the rack all the way in. All check all the holes in the spray arm for food blockages. On the very end of all spray arms is a main hole that is the drive hole to spin the spray arm. The water shoots out that hole and acts like a jet engine to push the arm around. Make sure those holes are clear.
Mar 24, 2015 | KitchenAid Dishwashers
Washer fluid does not dispense on rear window of 2003 c240 mercedes
check the small housing that comes from washer bottle make sure that thats all attached if thats ok stick a pin in the jet as a build up of muck can get stuck in it blocking the jet up
Jan 25, 2014 | Mercedes C-Class Exterior Pillar Posts...
My ford econoline e150 van wont start unless you sray starting fluid in it then it runs but barely
Check the fuel pump pressure and volume. Fords also have a fuel inertia switch/relay. If the vehicle was bumped hard and then no t starting, find the switch and press the red reset button. This will restore fuel pump activity.
Dec 06, 2013 | Water Heaters
My bissell9200 sraying wont stop
line is clogged put hot water in tank take it outside and run the hot water through it. Keep hitting the trigger.
Nov 10, 2013 | Bissell 1699 ProHeat Clear View Upright...
Truck wont start
Try spraying some starter sray in the breather and if it cranks, but only runs on the sray you may have a fuel or glow plug problem.
Apr 29, 2013 | 1996 GMC Sierra
Bissel pro2 carpet cleaner stopped sraying how to fix
Hey Diane! Sorry you're having difficulty with the spray on your ProHeat 2X. Here's a quick link to troubleshooting steps to assist you.
http://www.bissell.com/FAQDetail.aspx?id=1122&cid=ccsocial
Jan 15, 2013 | Bissell 2X Proheat 9200 rug cleaner
Message -spray arm blocked
Check water pump inside the machine for its full speed.If the speed is low check the capcitor and replace.
May 27, 2010 | AEG 24 in. Favorit 80860iW Built-in...
Oil is coming out of rightside of engine . It was very cold . Oil was spraying out the right side BMW x5 3.0 2002
what color is the fluid? are you sure it's not trans fluid? if oil is sraying out of your engine. there is a big problem. but it could possibly be a loose oil filter
Mar 02, 2010 | 2002 BMW 5 Series
Bottom sray spinner doesn't spin. Computer and
Make sure that the spray bar when lifted by the water pressure is NOT hitting the dish rack OR has excessive friction. Test by manually lifting and turning.
Also the jets must exit at an angle to provide the torque.
Oct 20, 2009 | Amana 24 in. ADB2200AW Built-In Dishwasher
Top spray arm in dishwasher will not spray
poor water pressure due to a clogged flowplate assy if the flowplate assy is not clogged with gook and hard water then you may need a new motor, a weak motor may not push the water well enough to get up to the top
first check entire flow are impeller etc
Oct 08, 2009 | Kenmore Dishwashers
Fujinon EC-450HL5 Colonoscope Logo
37 people viewed this question
Top Fujinon Cameras Experts
Are you a Fujinon Camera Expert? Answer questions, earn points and help others
