Question about Kenmore Progressive Bagless Upright with Inteli-Clean SystemVacuum
Why is my vacuum spitting out dirt as I vacuum?
    Master:
  • Kenmore Master
  • 850 Answers
Hi, it's Ambrai from Crucial Vacuum.
This usually means that your vacuum isn't suctioning properly. Your brush roll spins and picks up debris, but if it is not suctioned up, the debris will go back on to your carpet.
Poor suction can be caused by a clogged hose or a dirty filter. First, remove the hose from the vacuum. Toss a coin down your hose and if the coin does not come out of the other end, your hose is clogged and you will need to clean it. If it comes out of the other end, your hose is not clogged. To check if your filter needs to be changed, open the dirt bin canister and remove your filter. For optimal performance, it is recommended to change your filter every three to six months.
You can purchase direct your replacement filters from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/kenmore-dcf1-dcf2-filter.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Ambrai Brown
Crucial Vacuum Customer Care
Posted on May 08, 2014
2 Suggested Answers
  • 430 Answers
SOURCE: vacuum not picking up dirt
The neck in your power head is likely clogged. Disconnect from the wand and look inside. Also check the wand.Since you have suction on the bare floor the hose is likely not blocked.
Posted on Sep 11, 2009
The vacuum spits out the dirt what is wrong
Lauri,
Most likely, you have a clog somewhere that is preventing the dirt from going to where it is collected in your vacuum and that will usually result in dirt being spit back out.
Aug 13, 2015 | Vacuums
DIRT DEVIL SPITTING OUT DIRT
Spitting out dirt usually means there is a clog restricting the airflow.
Jan 14, 2014 | Bissell Cleanview Helix Deluxe Bagless...
Vacuum picks up some dirt and debris but not all, and spits some back out?
Some blockage at the pickup or in the hose if it uses one---dirt etc being kicked back out is a clear sign of this----if it has a tube check that first, and if a head with turning brush do not miss looking for a blockage there.
Dec 11, 2012 | Eureka True Clean Upright Vacuum (Yellow)...
Vacuum cleaner not picking up and sometimes spits ouit dirt
Check to see if bag (or if not bag then chamber is full).
Check to see if filter is clean.
If your vacuum has a bag, check to see that it is properly mounted.
Sorry I couldn't be more specific but it would help if you would specify what type of vacuum you have, whether you are using the hose or just the floor part, and where it is spitting the dirt from.
Hope this helps. If not, let me know the answer to the above questions and we'll go from there. Good luck!
Mar 13, 2010 | Vacuums
What causes a vacuum to make lots of dust and throw back out what it vacuumed
It sounds like the airducts that lead to your dirt chamber are clogged. The dirt can't get through to the dirt cup so it spits it back out and blows dust everywhere.
Nov 27, 2009 | Eureka 5892AVZ Bagless Upright Cyclonic...
My vacuum is spitting dirt as my feet and legs. Even when the filters and canister are clean and empty.
if you are using it on any surface that isnt carpet put the height setting knob to the lowest setting it should no longer spit dirt at your legs and feet
Aug 01, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
While vacuuming, debris spits out the back.
that's normal. try lowering the heght adjustment
Mar 18, 2009 | Hoover U5753-900 WindTunnel Bagless...
Dirt Devil Breeze-Bagless Vacuum
You probably have a clog either in the hose , wands, or the dirt inlet by the brush roll.
Mar 08, 2008 | Dirt Devil Breeze Canister M082550 Bagless...
Bissell powerforce
I just got done fixing a unit with this problem. After a bit of time, dirt will build up in the lower unit and clog the vacumm tube. Symptoms: No air flow coming out of the vacuum. Motor is hot. Stuff is spitting out of the front Motor wouldnt start it had over heated. You should remover the roller and clear the clog by hand. Let the motor cool down and it should start once it had cooled down.
Mar 07, 2007 | Bissell 3594 CleanView PowerTrak Bagless...
Kenmore Progressive Bagless Upright with Inteli-Clean SystemVacuum Logo
82 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
