Question about Hoover VHC391 T-80 Dryer
Why doesn't it spin? - Hoover VHC391 T-80 Dryer
    Sergeant:
  • 419 Answers
Could be few reason such as no power chck out house breaker or fuses ,broken parts,defective door switch or defective componants ,Need multimiter and knowledge of electricity
Posted on Jan 13, 2015
Motor spins but blade doesn't
If there is a shaft sleeve available from Kitchen Aid you will need to replace that and most likely the chopping blade if there is any damage up inside it.
May 01, 2013 | KitchenAid 3.5-Cup Food Chopper KFC3511
Will not drain and spin
see this causes:
t spins, but doesn't pump
the drain line is clogged+ some sock remain, remove with pliers,+pump defective.
It doesn't spin or pump
frozen pulley pump defective, replace
It pumps, but the water returns
improve the drain line. If drain hose reach more 4 inche cut of of excess. If lower add air/gap siphon break assembly.
see diagram
God bless you
Jul 03, 2012 | Kenmore Elite 45986 Front Load Washer
Not spinning or rinsing
see this possibles causes:
t doesn't pump or spin
frozen puller+ lid switch defective
It pumps, but doesn't spin
lid switch defective test, or motor coupler replace
It spins only with the lid closed
this is safety, the spin only with lid closed, tested
see the diagram . God bless you
May 16, 2012 | Washing Machines
Drains but drum wont spin
see this probably causes:
see for glogged drain line
see the pump pulley frozen
slow drain, improve the drain see the attachement
May 08, 2012 | Washing Machines
Kenmore Heavy Duty Plus Dryer 86273100 drum won't spin
How could the belt be in working order if the drum doesn't spin? Check to see if the belt has come off the motor. If the motor runs but your dryer doesn't spin, the belt is off. If the motor runs with the belt on but it still won't spin then you'll have a lot of black smoke because your drum is jammed. In other words, there are a number of things that could be wrong, but not very many.
Dec 22, 2011 | Washing Machines
Washer won't agitate or spin
Hello there and welcome to fixya
there are several things that you will need to check first ok please verrify the following
It doesn't pump or spin
If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
If your washer pumps out the water but doesn't spin, check these:
The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Sep 07, 2011 | GE Profile WPRE6100G Top Load Washer
My washing doesn't spin, It doesn't pump or spin
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 12, 2011 | Washing Machines
I have a L G and it does not spin dry the wash load How can this be fixed
Do you mean it doesn't spin at all...or it doesn't spin fast enough to dry the clothes?
If it will not spin at all you may have a loose belt or broken belt.
If it does not spin fast enough, you may have a loose belt or too latge a load.
Jun 26, 2011 | Washing Machines
Series 80 kenmore washer..doesn`t spin..
Make sure belts are still atached. Belts are relatively inexpensive and eazy to replace yourself.
Jan 14, 2008 | GE WSM2700D Top Load Stacked Washer /...
Hoover VHC391 T-80 Dryer Logo
80 people viewed this question
Top Hoover Dryers Experts
Tim Whalen
John Tripp
John Tripp
Are you a Hoover Dryer Expert? Answer questions, earn points and help others
