Question about Combi Baby Gear
I need to find replacement parts for a combi twin sport stroller
Back right wheel bracket the attaches the wheels.
  • 18 Answers
SOURCE: wheels
The problem suggests that the equipment was has undergone overloading or has given away after fair life.In both cases check whether there is any damage in the place of fitment. If you find that the place of fitment is clear then pick up the wheels compatible with your equipment from the store and try fixing it. If you are unable to fix the wheels then consult the service engineer.
Posted on Sep 07, 2007
SOURCE: wheels for a "combi" stroller
I just called 1800-99-COMBI to replace a set of wheels and they are mailing them to my home for free! Yes, you will need the model, lot # and date of manufacture date from the sticker on the leg of the stroller. Good luck!
Posted on Aug 05, 2008
SOURCE: Replacement Wheel - for Jeep Wrangler Twin Umbrella Stroller
Just call Kolcraft themselves. They are really easy to talk to. I have had to do it a couple of times. They have replacement parts for a lot of stollers that may not be online. Just go to www.kolcraft.com and click on contact us on the bottom of the page. It will give you a phone number to call. Good luck!
Posted on Aug 21, 2008
SOURCE: GRACO STROLLER FRONT WHEEL BROKEN
Contact Graco directly...the will send out a free replacement wheel. The whole unit comes together and snaps on.
Posted on Feb 08, 2009
  • 5 Answers
SOURCE: wheels for an evenflo stroller
check the label on the back of seat and find model and date.
My Evenflo Aura( same as on the picture above) was model #
1782478 and the date of product was 081706. With those numbers go to:
https://plweb.evenflo.com/product_detail.aspx?prodid=11263
Rear whells are for $19.90 and shipping is $9
Sorry for my English, but nobody wants to teach me English in communist Poland twenty years ago :)
Posted on Aug 13, 2009
Need to replace flap on cmm1200
1. Push the mower down to its lowest mowing position.
2. Turn it up on its right side, so the left side is in the air.
3. The existing flap is held in place with a glob of glue at the left (now top) end. Remove the glue by whatever means you like. I "chiseled" at it with taps from a flap-blade screwdriver and hammer.
4. Now you can slide the remnants of the old flap out and slide the new one in. You'll have to bend it slightly even with the mower in its lowest position to get it past the wheel, but it shouldn't be close to breaking.
5. Replace the glob of glue with whatever you have handy that plays well with plastic and rubber. By coincidence I already had DAP Alex Ultra 230 Black loaded in my caulk gun - worked fine.
Apr 07, 2013 | Black & Decker 19" Electric Lawnhog...
I need a detailed instruction on how to fold a combi stroller
1. Lock both front swivel wheels. Not locking the swivel wheels before folding the stroller can damage the wheels 2. Empty the basket. 3. Fold the canopy by lifting the canopy levers. 4. Remove your player from the canopy. 5. Lift and hold the folding levers up on both sides of the handle. 6. Tilt the stroller onto its back wheels and roll it forward and then pull it back quickly and the front guardrail will fold inward. 7. Turn handle inward with an underhand hold to latch and lock.
Jun 02, 2011 | Combi Cosmo DX Stroller
I need to replace my blower motor on my air handler
Turn off power to machine and have a 5/16" or 1/4" nut driver handy take off front door of machine. Take a rubber coated Screw driver and place across the terminals of the Capacitor to discharge any stored electricity. Cut wires for blower Black, Red, white, two browns one with white lines on it probably. Look inside machine and locate where bracket holds squirrel cage to air handler and there you will find either 5/16" or 3/8" screw remove pull bracket out. Then you will need a 1/2" socket and a crescent wrench. Remove screws for motor bracket that is attached to squirrel cage. Also you need to loosen the set screw that attaches blower wheel to motor. Apply wd-40 if needed to remove blower wheel from motor. Then install new motor on the flat part of the shaft comes through wheel attach set screw to motor shaft at that position. Install new cap that goes with motor. place entire housing of motor back into air handler and then follow wires that where previously cut back to either relays, sequencers, or fan timer board located in top section of air handler. Tighten everything up and turn power on and make sure air is coming out of vents. Then your good to go.
Apr 29, 2011 | Heating & Cooling
Where to find replacement wheel for Combi twin stroller TS-2 7035?
Replacement parts for our products are available only through Combi. Call the Customer Relations Department at 1-800-992-6624. You will need to have your model number and serial number or manufacture date available.
Feb 28, 2011 | Toys
Need to know the torque specs for a rear wheel bearing on a 1999 monte carlo?
Hub & Bearing 3.8L engine Removal & Installation To Remove:
All W-body cars are equipped with sealed hub and bearing assemblies. The hub and bearing assemblies are not serviceable. If the assembly is damaged, the complete unit must be replaced.
  1. Disconnect the negative battery cable.
  2. Raise and safely support the vehicle with jackstands.
  3. Remove the rear wheel and tire assembly.
  4. If equipped with rear disc brakes, remove the caliper, bracket and rotor.
  5. If equipped with rear drum brakes, remove the brake hose bracket and drum.
  6. If equipped, detach the ABS electrical harness.
  7. Unfasten the four hub/bearing-to-knuckle attaching bolts, then remove the hub/bearing assembly.
To Install:
  1. Install the hub/bearing assembly onto the knuckle. Install the four attaching bolts and tighten to 52 ft. lbs. (70 Nm).
  2. If equipped attach the ABS electrical harness.
  3. Install the rotor, caliper and bracket or drum and bracket, as applicable.
  4. Install the wheel and tire assembly.
  5. Carefully lower the vehicle.
  6. Connect the negative battery cable.
Jul 15, 2010 | 1999 Chevrolet Monte Carlo
How do you change the brakes on a 1988 dodge shadow
Brake Hose
FRONT BRAKE HOSE
  1. Raise the end of the vehicle which contains the hose to be repaired, then support the vehicle safely using jackstands. Make sure to block the wheels still on the ground to prevent the vehicle from rolling.
  2. If necessary, remove the wheel for easier access to the hose.
  3. Place a drain pan under the hose connections. First, disconnect the hose where it connects to the body bracket and steel tube.
  4. Unbolt the hose bracket from the strut assembly.
  5. Remove the bolt to disengage the banjo connection at the caliper.
To install:
  1. Position the new hose, noting that the body bracket and the body end of the hose are keyed to prevent installation of the hose in the wrong direction. First, attach the hose to the banjo connector on the caliper.
  2. Bolt the hose bracket, located in the center of the hose, to the strut, allowing the bracket to position the hose so it will not be twisted.
  3. Attach the hose to the body bracket and steel brake tube.
  4. Tighten the banjo fitting on the caliper to 19-29 ft. lbs. (26-39 Nm), the front hose-to-intermediate bracket to 75-115 inch lbs. (8-13 Nm), and the hose to brake tube to 115-170 inch lbs. (13-19 Nm).
  5. Bleed the system thoroughly, referring to the procedure presented later in this section.
  6. Install the wheel, if necessary.
  7. Lower the vehicle and remove the wheel block(s).
REAR BRAKE HOSE (TRAILING ARM-TO-FLOOR PAN)
  3. Place a drain pan under the hose connections. Disconnect the double nut (using a primary wrench and a back-up wrench) at the tube mounted on the floor pan.
  4. Disconnect the hose at the retaining clip.
  5. Disconnect the hose at the trailing arm tube.
To install:
  1. Install the new tube to the trailing arm connection first.
  2. Tighten the connection to 115-170 inch lbs. (13-19 Nm).
  3. Making sure the hose is not twisted, connect it to the tube on the floor pan.
  4. Again, tighten the connection to 115-170 inch lbs. (13-19 Nm).
  5. Bleed the system thoroughly, referring to the procedure later in this section.
Hope helps (remember rated this).
Jul 08, 2010 | 1988 Dodge Shadow
Removal of front right axle from a jaguar 2002 x-type
Loosen the wheel hub nut.
Remove the front road wheel and tire.
Remove the tie rod end retaining nut.
Using the special tool 204-192 Ball joint Splitter
detach the tie rod end.
Remove the subframe reinforcement plate retaining bolts.
Loosen the subframe rear mount bolt.
Loosen the subframe front mount bolt.
Remove and discard the wheel hub nut.
using spcial tools 204-269Forcing Screw,205-491-01 adapter nuts,205-491 wheel hub puller
Detach the wheel knuckle.
Remove the lower arm ball joint retaining bolt.
Reposition the lower arm.
using special tools 307-443 RH Halfshaft splitter ,307-442 RH Halfshaft splitter handle
detach the halfshaft.
Remove the exhaust muffler inlet pipe.
Remove the halfshaft seal.
Remove the transfer case Y bracket retaining bolt.
To prevent damage to the transfer box internal seal,
make sure that the link shaft is not retracted further than
200 mm from the transfer box casing.
remove the halfshaft.
Attach special tools to the halfshaft.
Lever the special tools to displace the halfshaft.
Install the transfer case Y bracket retaining bolt.
Remove the halfshaft.
Use suitable protective covers to protect the barshaft.
Remove the halfshaft snap ring.
Install a new snap ring to the halfshaft.
Install a new halfshaft seal.
Remove the special tool.
Make sure the CV joint splines are located fully.
Do not use excessive force when engaging the CV joint into the link shaft.
Install the halfshaft.
Tighten to 25 Nm.
Attach the wheel knuckle.
Install the lower arm ball joint retaining bolt.
Tighten to 83 Nm.
Install the exhaust muffler inlet pipe.
Tighten the subframe front mount retaining bolt.
Tighten to 142 Nm.
Loosely install the subframe rear mount retaining bolt.
Install the subframe reinforcement plate retaining bolts.
Tighten to 35 Nm. Tighten to 142 Nm.
Install the tie rod end.
Tighten to 35 Nm.
Loosely install a new wheel hub nut.
Install the front road wheel and tire.
Tighten the wheel hub nut.
Tighten to 330 Nm.
Check the subframe alignment.
May 20, 2010 | 2002 Jaguar X-Type
I'm looking for a replacement wheel for combi stroller
Hi
www.buggypitstop.co.uk/ is the site you need,excellent in advice and replacement of wheel plus making your stroller brand new again.
thanks
May 05, 2010 | Combi Cosmo DX Stroller
Baby Gear Logo
60 people viewed this question
Top Combi Baby Gear Experts
Paul Carew
ray gallant
Are you a Combi Baby Gear Expert? Answer questions, earn points and help others
