Question about Et2 Frost 4 Light Linear Pendant
How to replace low beam bulb - Et2 Frost 4 Light Linear Pendant
I have a 2006 civic SI. DRL indicator is on, driver side low and high beam ok. Passenger side low beam ok but DRL and hi beam not working. Any help is appreciated.
When either the high or low beam light is out in either side, DRL (daytime running lights) indicator will come on. When one bulb goes out, that's a clue the opposite bulb will burn out soon, so its best to replace both bulbs. If it was a fuse issue, both left and right side would be out. If driver side is OK but passenger side is not, then its a bulb issue. A 2006 Honda civic takes 9006 (HB4) low beam bulbs and 9005 (HB3) high beam bulbs. Cheapest is online from Walmart site-2-store. After procuring, wear latex, vinyl, or ANY gloves to keep your (corrosive) oil skin from coming in contact with headlight glass bulbs. Your skin oil will chemically react and cause shorter life span on glass bulbs. Instruction don't tell you this, so you handle with your hands, then need to replace bulbs 3 years later instead of 5 years (or more) in the future. With gloves on, pop the hood and look behind each headlight. Turn counter clockwise to unlock headlight bulb holders. Its a quarter to half turn to unlock bulb holder lock. Replace one bulb at a time so you don't confuse high beam from low beam. The wire has a tab you need to lift to pull out & disconnect wire connector. You might need a slim narrow-**** (NOT phillips) screwdriver to lift the tab; or use your house key. Snap the wire connector to the new bulb, then twist into headlight housing to secure bulb holders, then move on to the next bulb to repeat the procedure. Pict below, 9005 high beam is on the left, 9006 low beam is on the right. Handle by grasping the plastic base, not the glass bulbs. The raised potrusion on the bottom center is where the tab locks onto wire connector. Replace all 4 bulbs now, but in the future, its likely the low beam will wear out before the high beam. In the future, replace only the pair, not all 4. The factory installs inferior bulbs that go out sooner, hoping you'll take to dealership and they ******** you with higher parts-n-labor fees. As opposed to Walmart online site-2-store, it would cost you AT LEAST triple in parts & labor from dealership to replace all 4 headlight bulbs :-(
Nov 29, 2013 | 2006 Honda Civic
I have a 2005 chev impala can i replace my high beams headlights with just low beam lights
NO YOU HAVE TO REPLACE HIGH BEAM LIGHT BULBS WITH HIGH BEAM LIGHT BULBS BECAUSE HIGH BEAM LIGHT BULBS AND LOW BEAM LIGHT BULBS TWO DIFFERENT TYPES OF BULBS.WEAR CLEAN LATEX GLOVES HANDLING THE HEADLIGHT BULBS WHICH IS HALOGEN LIGHT BULBS, OIL FROM FINGERS OR HAND WILL CAUSE HALOGEN BULBS TO OVER HEAT BLOW OUT.
Jul 05, 2011 | 2005 Chevrolet Impala
Only one head light works in low beam, both works in high beam
Bulb is burned out, it has two filaments in it , low beam and high beam. Replace bulb!
Jan 12, 2011 | 2000 Honda Odyssey
2002 gmc safari head light won't work on low beam but will work on high beam
First check, is there more than one headlight bulb, if so, the low beam bulb has failed, needs replacing.
If not you'll probably find that the head light bulb has a double filament, low and high beam. The low beam filament has failed. You have to replace the bulb.
Dec 24, 2010 | GMC Safari Cars & Trucks
I recently puchased blueish headlight bulbs for my 2006 Volvo S80. The original bulbs were 55W for both the low and high beams. i replaced the high beams with 100w blueish bulbs and they work fine. When...
i think im right in saying the low beam bulbs are twin filament(low and high beam in one)and the main/high beam are single filament(spotlights).
Aug 17, 2010 | 2006 Volvo S60
Low beam burnt out
The headlight on an 03 baja are a double element bulb for high an low beam. I replaced mine with 9007 bulb from auto parts store. Be careful to pay attention to bulb position, they can be installed up side down having the high beam as your low beam. I would shine the lights up against a wall or garage door and flip your high and low beams on and off to see how the shine.
Feb 21, 2010 | 2003 Subaru Baja
How to change front headlamp bulb? Low beam
  1. Open the hood.
  2. Remove Grille.
  3. Remove the 2 retainers on back of headlamp assembly and remove the headlamp from the sheet metal panel.
  4. Remove the access cover from the rear of the headlamp.
  5. Disconnect the electrical connector from the socket.
  6. Rotate the bulb and socket counter clockwise in order to remove the bulb and socket from the housing.
  7. Disconnect the electrical connector from the socket.
  8. Remove the bulb and socket from the headlamp.
Installation Procedure Important: • Replace a high beam bulb with another high beam bulb. The high beam bulb has a black socket. • Replace a low beam bulb with another low beam bulb. The low beam bulb has a gray tip and a grey socket.
Oct 14, 2009 | 2002 Chevrolet TrailBlazer
Low beams do not work, replaced turn signal switch but still no low beams. High beams work but no low. Please Help
its probally the bulb........alot of car headlights are DUAL element meaning one bulb has 2 little elements inside one for low beam one for high beam...............Most times the low beam burns out because its used more.....get it one bulb gives both high and low beams.......REPLACE bulb......if you don't know what kind go to auto part store, tell them the make of your car and they will give you the right one .....
May 09, 2009 | 1997 Ford Explorer AWD
Low beam not work !!
replace the headlight bulbs. Usually when the bulbs blow out the low beam blows out first, but the high beams still work. If you want and need both low and high beams to work then replace the headlight bulbs with brand new ones and I garauntee that both low and high beams will work
Mar 27, 2009 | 1999 Dodge Caravan
2005 Honda CRV High Beam
Honda Headlight Bulb(H1) - This bulb is the high and low beam bulb for your vehicle. One bulb required for each headlight.
This headlight bulb fits:
  • CR-V 2005-2006 (requires 2 bulbs per side)
Mar 21, 2009 | 2005 Honda CR-V
Et2 Frost 4 Light Linear Pendant Logo
69 people viewed this question
Top Et2 Photography Experts
Tony
Are you an Et2 Photography Expert? Answer questions, earn points and help others
