Labgear hdsr300 instructions - Computers & Internet
How do you unlock lost pin number on satellite box Hdsr300
Maybe you can find the needed info in the manual?
Labgear HDSR300 Manuals
Also have here some additional information on this Sattelite Receiver which might be useful:
HDSR300 Rubish
Items found similar to Labgear HDSR300 HD Satellite Receiver Remote HDMI...
Labgear HDSR300 setup
Aug 03, 2015 | Cell Phones
Where can i get a replacement battery for a Ohsen wr30m Watch?
In order to help people set the ohsen sport watches easlier in the right way, our company (www.360sportwatches.com) write the ohsen watch manual instruction in English for all the ohsen watch users, hope this page is useful for you to set your ohsen watch, this ohsen watch manual operation is suitable for almost all the Ohsen digital electornic watch, also it is suitable for the ohsen analogue quartz digital electronic sport watches, for details ohsen watches models, please have a look at the following content!
Ohsen watch manuales instruction description:
A Key = Light
B Key = Mode
C Key = Start
D Key = Reset
In normal time to show, press the button to enter B mode, click Settings when choosing D Key respectively, minutes and seconds, C key to adjust.
Hours, minutes, seconds, month, day, week;
12/24 hour clock selection
* Daily Alarm Clock
Daily alarm only " Hours" and " Minutes" to choose
The whole point timekeeping
* Running Seconds
From 0.04 seconds start running time;
The Longest 23 hours 59 minutes 59 seconds
* EL black light
Any mode, press the A light EL backlight for 3 seconds
* Use 3V batteries
Running Second Mode:
Press B button click into the race second mode, press the C key to start timing, the timing of the state, press the D key to pause time;
At the time of state, then C key, stop the clock, press the D key to this state would be zero time.
Press B button to return to normal time mode;
Alarm setting mode:
Regular time mode, press the B button 2 times into the alarm set;
Press C key to the "alarm" whole point of time" to set " open" and "off";
Press D key to adjust the hours, minutes;
Press C button to adjust the number of selected;
Press B tutton to return to normal time statues.
At the same time in any state, this button will issue a Bi Bi sound;
Time, date setting mode:
In normal working mode, press the B button 3 times to see the second in the flashing, then press the C key, " seconds" will be zero;
Press D key to select each "Hour" " Minute" " Day" " Week" set;
Press C key, you can adjust the number;
Press B button to return to normal time status;
12/24 hours;
Under normal travel time; Press B button 3 times to enter time setting mode, then second in the flashing, second place in the transferred into " H" when the table show has been converted to 24 hours system; when the position becomes"O" on the afternoon of adjustments; seconds into "R" for morning; "P" for PM.
Apr 01, 2015 | Watches
Chunghop rm139es code for labgear
0281,0280,0289. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
http://remotesearch.blogspot.com/
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Feb 21, 2015 | Televison & Video
How to fix labgear camera ?!
turn your camera on and record
Nov 19, 2013 | Home Security
Without connecting the aeriel to the labgear i get 77 tv channels and some music channels but when i put it through the labgear i only get 21 tv channels why am i losing my signal i have put a annuater in...
An attenuator reduces all signals. Attenuators are often used when you are close to a transmitter that causes interference to other stations. By knocking the signals down, the strong signal is less likely to interfere with the other stations, while the other station's signals will be reduced too - many can now be tuned and viewed. This comes with the risk that some stations that had a signal that was just over the threshold of being tuned and watched no longer have a signal level that passes through the attenuator. This is what is happening in your situation.
Determine if you can watch stations you like without the attenuator. If so, do not reinstall it. If you find that some of the stations are being interfered with by another station - see if you can change the amount of attenuation in the device. Some attenuators are adjustable and make this easy to do. If yours is not adjustable, you might consider purchasing an adjustable type - as the one you have is not suitable.
Lastly, consider installing a rotatable antenna. This will allow you to aim the antenna directly at the broadcaster's antenna - allowing you to reject signals not in the same direction. This should reduce your interference from other strong signals that originate from a different direction. This will also increase the signal strength from all transmitters as you can point your antenna directly as the antenna - instead of capturing signals from the side or back of your antenna.
I hope this helps and good luck! please rate my reply. thank you.
Apr 06, 2011 | Televison & Video
I have just had sky HD box installed but need a DVI to HDMI converter, however i cannot locate a one that fits my philips 42pf7520d tv.
I would expect most shops to carry that connector Here some links - I would expect Maplin to have a cable - however, I cant find a image on there website - so heres some links to amazon, I used the online manual - let me know whats different about these DVI connections on the TV - look the same from the manual
  • http://www.amazon.co.uk/Labgear-Premium-Gold-Plated-Adaptor/dp/B000GHQO0C
  • http://www.amazon.co.uk/Premium-HDMI-Cable-Gold-Metre/dp/B000GDI6FC/ref=pd_cp_ce_2
heres the support site for that TV http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=42PF7520D/10&slg=en&scy=GB
Direct link to user manual http://download.p4c.philips.com/files/4/42pf7520d_10/42pf7520d_10_dfu_eng.pdf
Apr 07, 2010 | Philips Televison & Video
Frequently lose reception
many thanks for responce, problem appears to be the labgear power unit, turns out to be more likely 18 years old.
Apr 09, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Admin password DVR-X4 IP
i lost the dvr password how to watch yastaday data
Mar 11, 2008 | CSi Speco Speco DVR-T4IP 4-Channel Triplex...
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
