Leaing water My Unit UBHA-17J10SFDA is leaking water. Can't seem to find a clogged drain pipe like last time. Any suggestions?
  • 439 Answers
If this is a window unit, then you will need to slightly tilt it down in the back (out of the window).
Posted on Jun 22, 2009
Condenser leaking
No reason to disconnect. Just use a snake to unclog the pipe.
Sep 07, 2014 | Heating & Cooling
Water leak from under door
When your refer defrosts a couple times a day it produces about a quarter of a cup of water each time.This occurs in the freezer section.The water travels down a drain pipe (or tube) that leads to a drian pan in the bottom of the unit. It is collected and evaporates from the heat of the motor.
If the drain is plugged water will form inside the unit itself.If the drain tube has somehow moved and not allowing the water to collect in the drain pan it will go on the floor.Either way,if the drain is the problem the amount of water should be pretty small, no more than a cup or two.If you have an icemaker or ice and water through the door and the amount of water on the floor is more than a cup or two. I would find the water shutoff for the supply line(probably behind the unit in newer homes)and turn it off.Clean up the water and wait a day.If the water goes away assume that one of the plastic lines in the unit that carries water to the icemaker or door is leaking.If the water continues I would suspect the drain.The only way to check the drain is to unplug the unit and remove the cardboard back,locate the drain pan and see if water is present and that the drain line is in it's proper place.
If one of the water lines is leaking you will most likely need a service tech.
Also it's best to turn the icemaker off by lifting the arm or switch before you turn the water off for testing.
Mar 18, 2010 | Hotpoint HSS25GFP Side by Side...
Intermittant water leak front left hand side and ice build up on inside base of freezer compartment, but no evidence of water leaking out from door it seems to come from underneath the appliance.
Sounds like the drain hose from fridge unit to evaporator pan built on top of compressor is plugged. The drain holes are small and clog easily. I like to make the holes bigger. A pipe cleaner helps to clean the inside of the drain hose.
Make sure water is dripping onto evap tray.
Nov 25, 2009 | Refrigerators
Leaking water in front left side
hi tom
yes the drain tube may be glogged and when the unit defrosts the water just flows to the bottom of the un it then eventally out, if you have a clogged drain, you will see water on a pretty reglar basis
8, 10, 12 hours
the drain pipe is behind the back wall on the freezer, if you take that off you will se an ice build up, remove that ice and clear the drain tube
you may need to pull out the machine and remove the tube from the back to ensure that it is entirley clear
Oct 20, 2009 | Refrigerators
My Air conditioner leaks water
All A/C units drain water and need a clear path to drain water.
If window unit the unit MUST lean to the outside so the condensation water can drain that direction and insure the drain hole is clear of debree.
If an indoor central a/c unit the drain must be clogged the unit is leaning away from drain or the pipe going to the drain is clogged somewhere as it exits house. Cant drain if doesn't have a clear path to do it's job. Doubt it's a problem with the brand.
Aug 02, 2009 | Kenmore Heating & Cooling
Central A/C unit has a leak
The air handler has either a drip pan with exit pipes on the side or a drain pipe and any of which could be clogged.. Find out were the water is supose to exit,, and at that end - tape a strong wet vac to suk out any clog or debris..
Rate well ;o)
Jul 22, 2009 | Heating & Cooling
A/C Clogged drain pipe
Can you get to the hose in the house unit? If so canned air
May 26, 2009 | Carrier Heating & Cooling
Leaking water durign spin cycle
you have to de-clogged the drain outlet pipe. it could be clogged already that is why when it is draining, the pipe can not handle the amount of water coming out of the machine and it leaks out of the pipe or from the hose on the wall where the drain pipe is.
tnx 4 using fixya,
drcool
Oct 22, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Mitsubishi mr. slim is leaking water
you dont have enough fall creating a water trap which breeds bacteria into a green slim ball blocking drain you need to chop more brick wood what ever the pipe drain go through so there is very good fall problem solved the pipe being blocked causes water to back up these heads can loose 4 ltrs an hr in qld not sure on other state hope i was some help
regards john
john@topnotchelectrics.com.au
Jun 08, 2008 | Mitsubishi Mr. Slim MXZ30TN Air...
Kenmore Top Mount Refrigerator - leaking water from the Cold Control Defrost Timer/Automatic Defrost Control Housing
It freezes up for a few reasons. First the water is not running down fast enough. That is why the wire was added to add heat from the heater to the drain hole. The metal pan under the evaporator coil may not be lined up with the drain hole well enough and holding water there. If that looks ok the drain tube that runs down the inside back of the unit might be slightly restricted. Not much you can do about that. I would make sure that the aluminum wire goes in the hole about 2 inches and that the unit is tilted slightly back to help water flow.
Apr 18, 2008 | Refrigerators
Heating & Cooling Logo
95 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
