Question about Royal 112MX Shredder
Royal 112 MX Shredder quit cutting side to side
Worked fine at first. Any quick tips that I can do myself? Don't want to spend the money to send back.
SOURCE: Royal 1280 MX green light turns red, does not run
The 1280mx has a circuit that detects the high current when the motor is jammed. The 5 watt, 0.5 ohm resistor/fuse (marked as R1) that is part of this circuit blew on my unit. No visible signs of failure, you have to remove it from the circuit board to test it. When R1 fails more current than normal passes through the R2-1k ohm resistor; need to check if it also failed.
Posted on Oct 18, 2008
SOURCE: Royal Orca 9512
I had something very much like what you tell of.
Take off top with 4 hex/Allen screws, careful not to stress wires to panel rocker switch. support it somehow. Follow the line cord in and check the fuse, maybe we should have done this first, huh?
With VOM check cont of black lead thru fuse into safety switch adjacent. ON MINE IT WAS JAMMED. I could not free it, and surmising it was an interface with custom waste receiver which I did not have I bypassed it with a drop of solder. SUCCESS!!
But not quite. therre was still a pesky intermittent on/off that came and went.
Traced it all down to a cold solder, dry, joint on a red lead going to the front panel switch. Take it off, tighten tabs, solder what had been only crimped at factory and SUCCESS!!
All back together and there is a reason they call this thing ORCA:
Good luck with forensics as this thing delivers uniform quarter inch squares, confetti, no chance to decipher one damn thing.
Hope this helps, David Anshus
Posted on Jul 16, 2009
  • 1218 Answers
SOURCE: Replacement gear for Royal PX100MX shredder
For replacement parts call Royal at 1-800-524-0799; they should be able to help.
Posted on Aug 22, 2010
  • 1218 Answers
SOURCE: I own a Royal RL170MX shredder. I turn on the
If the blades rotate then the paper should go in...just be sure the blades are turning in the forward direction and not in reverse.Also make sure you lubricate the blades with shredder oil.
  • 1218 Answers
SOURCE: royal 1200mx confetti cut shredder : wont turn on
If its dead...no lights, nothing, then the pcb inside has probably gone. Give Royal a call at 1-800-524-0799 for parts and prices.
Posted on Sep 08, 2010
ROYAL 150 MX WILL ONLY TAKE 2 SHEETS
Have you ever "oiled" the machine.
ALL cross-cut shredders need to be oiled to help clear out the paper dust and debris generated during the shredding process.
Pour some shredder oil across the cutting shafts while it is running and occassionaly put some oil onto a sheet of paper as you shred it.
May 09, 2011 | Royal 150MX Cross-Cut Shredder
My royal shredder will shred paper just fine but now it won't shred a credit card. any ideas?
Silly question if it shreds paper fine but....when did you last oil the machine.???
Cross cut shredders need to be regularly oiled..( pour some shredder oil across the cutting blades).
It may just be that the credit card is too thick!
Jan 25, 2011 | Royal 112MX Shredder
I am unable to open the shredder up in iorder to empty it out and clear it.What am i doing wrong?The model is ROYAL 10 sheet crosscut shredder PX 1000 MX .HELP! Thanks. Dave
If you have "overfilled" it, then yes it can be hard to get the bin out...there is no other way than to try to get the paper out a little at a time until the whole bin can be removed.(I heard of one customer say they got it out by turning the machine upside-down) altho' I have never tried that myself. Be aware this may make a mess while trying to get the paper out.
Jan 08, 2011 | Royal VF1000MX Shredder
Need basket 4 rl170mx shredder
Give Royal a call at 1-800-524-0799 for parts.
Jul 31, 2010 | Royal 150MX Cross-Cut Shredder
Our Royal 15 mx cross cut shredder will back out material, but there is no green light and no ability to feed in paper. Is this a gearbox problem? Is there anything we can do? Nothing appears to be stuck...
Does it sound like the motor is running forward or is it just "dead" when you try to shred paper..... if the motor is running.....then its a gear...but most likely you have lost the pcb in the machine...give Royal a call at 1-800-524-0799 for info on parts and prices.
Jul 22, 2010 | Royal 15MX Shredder
Light doesn't go on and shredder doesn't work-where do I take it
Dont know of an agent myself in that area but try calling Royal at 1-800-524-0799 and maybe they can guide you to someone.
Mar 06, 2010 | Royal 150MX Cross-Cut Shredder
Nov 25, 2007 | Royal 1280MX Shredder
Royal 112MX Shredder Logo
99 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Adorjani Laszlo
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
