Question about RCA 300W Bluray Theater Sys - RTB1016
Where can I download the firmware update for an RCA RTB1016 home theater system?
  • 151 Answers
SOURCE: Can't figure out how to connect a subwoofer to my RCA RTD315W
HI,the rca system should have a sub pre out socket,plug a phono cable into this then to input on your sub and set volume to half way,also make sure the sub is set to on in the setup menu on the system.
Hope this helps.
CABLE GUY.
Posted on Apr 19, 2009
  • 3 Answers
SOURCE: No Audio with home theater system
have you tried infra red link?
Posted on May 07, 2009
SOURCE: RCA 5.1-Channel 250 Watt Home Theater System - Model RTD209
Unit was working fine,took a movie out,put in new one,but would not play.Tried hitting open button ,unit will not respond,all other functions working ok.
What could be the problem,is it worth fixing?/Is there a reset button somewhere on unit?
Posted on Dec 31, 2010
PhilwithDISH
  • 123 Answers
SOURCE: can't find a code to
We would be happy to help with that. Here is a list of someof the codes that we have for RCA home theater systems: 703, 852, 772, 638, 704, and 727.
Press and hold the AUX mode button until all mode buttons at the top of theremote come on, then release. Enter the number 2 then one of the codesfor your RCA home theater system provided above. Press the pound (#) button, the modelight should flash three times. Checkthat the code works by trying several different functions on the remote to makesure it will properly operate your RCA home theater system. Keep in mind that some codesmay not be compatible with your equipment. If this is the case, please try theother codes listed for that device until you find one that is compatible withyour equipment.
We hope this helps you, and thank you for being a valued DISH Network Customer!
Phillip Chang
DISH Network Customer Service Representative
Posted on Feb 28, 2011
SOURCE: RCA RTD315W
my home theater RTD315W fails WELLCOME
Posted on Jun 04, 2011
Where to find firmware upgrade for rca rtd317w?
IF the receiver had an internet connection, the receiver will find it's own firmware updates provided that you have it configured to automatically update. You might have to manually engage a firmware search via the settings menu - try the service or software tab.
IF not - then it will be much harder.Usually a call to the manufacturer of visiting their website is a good place to start to see if this is even an option for you.
Another way you can flash or update the firmware of electronics is by way of a flash drive into an usb service port on the chassis. YOu will need detailed instructions that you will need to follow to the "T" else you "brick" the unit.
If you have none of these then I will assume that firmware updates are not even possible.
May 30, 2014 | RCA RTD317 Theater System
Update firmware
http://www.rcaaudiovideo.com/downloads/
Try the above link. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts. Surf the site with patience.
Beware; firmware update procedure should be done very cautiously. There should be no power supply interruption during the whole process.
Apr 08, 2014 | RCA RTB1016 300-Watt Blu-Ray Home Theater...
Rca updates
The update options are in the setup menu
Dec 08, 2013 | RCA 300W Bluray Theater Sys - RTB1016
RCA RTB1016 remote control code
go to Radio Shack or whatever other electronic stores like best buy
God bless you
Sep 30, 2012 | RCA RTB1016 300 W 5.1 Home Theater System...
UPDATE SOFTWARE RTB 10223
my blue-ray RTB10223 the sound 5.1 in youtube not working wy?
May 10, 2012 | RCA 300W Bluray Theater Sys - RTB1016
I have a RCA RTB 1023 blu-ray home threater system that when I play a blu-ray disc it is freezing. please help.
If you have the availability to connect it to the internet via the network jack on the back of the console, please do this and run through the set up to make sure that your firmware, is correct and updated!
Aug 21, 2011 | RCA RTB1100 Theater System
I need to find firmware update for model sc-bt228. it wont play new blu-ray dvds.
The only firmware update available for the sc-bt228 is here: http://www2.panasonic.com/consumer-electronics/support/Audio/Home-Theater/Home-Theater-Systems/Drivers-Downloads/model.SC-BT228.D#ts . It is dated 9/27/2010 and is a Viera Cast Update.
If you do not end up at the right tab, make sure to click the Drivers and Downloads Tab.
I hope this helps.
May 25, 2011 | Panasonic Home Theater System System
When i turn up the volume on my home theater it goes to maximum by itself, and does the same on minimum side!!
Turn unit off, then Press "Play/Pause", "Stop" and the "Power" button on the unit (not on remote) ALL AT THE SAME TIME. This should fix it. Also, download the firmware update (Google "firmware update for Panasonic SC-BT100 and follow the link to the Panasonic support site)....since I updated the firmware, mine hasn't done this again.
Feb 02, 2010 | Panasonic SC-BT100 Theater System
RCA 300W Bluray Theater Sys - RTB1016 Logo
76 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
