Question about Grilling
Kenmore gas grill
Just bought a Kenmore duel fuel grill and have converted it over to natural gas. One of the steps says to remove control knobs insert precision screw driver into the valve stem and turn 90 degrees clock wise. The problem is I cant turn anything in either direction even if I try with pliers on the screw driver. Any idea what's going on ? Thanks steve
  • 68 Answers
Try to push in on the knob then turn it
Posted on Nov 02, 2017
  • 32 Answers
SOURCE: knob removal
yes. it slides on a off with a little pressure.
Posted on Apr 06, 2008
  • 43 Answers
SOURCE: CHANGING FROM PROPANE TO NATURAL GAS
check owners manual- its one or the other, IF no natural gas is writen in manual- its a propaine for life!! You will have to purchase a natural gas grill-
Posted on Jan 07, 2010
TheMobilian
  • 8220 Answers
SOURCE: Ducane grill knob is stuck. Replaced plastic knob
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Apr 16, 2010
heatman101
  • 43501 Answers
SOURCE: trying to convert a natural gas grill to propane ?
Probably some models are convertable and others not...you eed to egt a hold of Charmglow and find out if and what kit you will need...some stores like HD that sell them will have sharts and kits also..
heatman101
Posted on Apr 23, 2010
  • 494 Answers
SOURCE: Replacing hoses and regulator on gas grill
I work for a propane co. I get many customers that bring in their melted or leaking bbq grill hoses and regs. Bring the bad hose/reg to your local propane gas co and see if they can make a custom hose for you. You may have to buy a new regulator to use it with the new hose, but that's better than buying a new grill. Call around first and see which ones can do it. You'll eventually find someone that can fix you up.
Posted on May 16, 2010
Testimonial: "great suggestion - i'll give it a shot. Thank you!"
I Have A Jenn-Aie Model 720-0164 Natural Gas Grill. When I Grill, The Control Knobs Get So Hot Theyh Will Burn You. What Could Csuse This?
Can this grill be also used on propane? If so you might be running it too hot on natural gas, check to see if the control knobs have two different set of markings.
Sep 16, 2014 | Jenn-Air Outdoor Liquid Propane Lp...
Kenmore grill 146.23766310
Here is the owner's manual:
http://www.managemylife.com/mmh/lis_pdf/OWNM/1212186L.pdf
In it, it states, "Use grill, as purchased, only with LP (propane) gas and the regulator/valve assembly supplied"
Oct 30, 2013 | Grilling
Our Kenmore Gas Grill Elite (bought in 2007) has not worked in 3+ years. It ran out of its warranty and then the problems began. It was converted to natural gas and from one day it was really hard to...
Question, when you pull off the knob do you see a screw on the front of the valve? Since the grill was converted, there are times where manufacturers use gas specific valves and the screw is there as an adjustment. Let me know.
Mar 22, 2017 | Kenmore Grilling
I have a kenmore ellite bbq model 141.16691 propane - I want to convert to natural gas, there is no conversion kit to make it but the natural gas model 141.17691 is exactly the same - just natural gas. If...
Many manufacturers make grills in propane and natural gas, but are not convertible from one gas type to another. The reason being safety. Each grill model, whether it's Natural Gas or Propane is tested and approved for that one specific gas type and that alone. Converting it would put all the responsibility on you, if something was to go wrong.
I suspect in part, the reason you want to convert is so that you want have to refill the propane tank any longer. But, you may want to consider this against convenience. Propane Gas burns cleaner and hotter than Natural Gas in an outdoor environment. Which boils down to lower high end temperatures, longer preheating times and the expense of running an approved gas line to the grill for Natural Gas. Not to mention the cost conversion parts.
But, the decision is yours to make. Thanks for choosing FixYa.
Aug 06, 2011 | Kenmore Elite 644 sq. in. Cooking Area Gas...
I want to buy a grill buy my grill the gas comes from the floor. I could not find the same one.
I'm sure you can buy a converter kit for most grills to run either natural gas or propane
Aug 11, 2010 | Kenmore 632 sq. in. 16324
I received aa Amana AM26 lp Grill for a gift. Want to convert to natural gas. What part do I need?
The grill has to have the duel fuel label on it, if it is not duel fuel then it can not be converted to natural gas. I have searched and I have not found a conversion kit for it.
Jan 07, 2010 | Grilling
Sep 16, 2009 | Kenmore 632 sq. in. 16324
Need conversion kit for propane gas grill to natural gas.
you need a small drill to make the holes on the jets bigger. try calling your local Gas co. for info. or call 503-226-4211 and ask for the appliance center.
Jun 22, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore 32099 Cooktop burners regulation
remove the burners and adjust the air ration with the slide at the bottom of the burner tube
Jul 25, 2007 | Kenmore 30 in.32099 / 32094 / 32092 Gas...
Grilling Logo
359 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Are you a Grilling Expert? Answer questions, earn points and help others
