Question about John Deere Garden
Why does my Z445 keep stalling?
My mower keeps stalling and will only keep running if the choke is pulled out. I also have to pull the choke every time in order to start it. It has a 25h. Kawasaki engine.
jrw4u
  • 62 Answers
SOURCE: Craftsman Riding mower won't stay running
Well this could be a couple of things first thing first is check the air filter and make sure its clean you can blow it with air or pore gas over it and clean it make sure you let it dry before reinserting
second im assuming this is the first time you have used it this year if so the gas you have in it hasnt been sitting in it all year has it like anything else gas gets old
third alot of times you can let it run for a while with the choke out then slowly pushing it in
fourth you could have water in the gas remove the tank and empty it remove the spark plug turn the engine 4 or 5 times only bumping it dont hold it down this will blow some of the water out then dry the spark plug off and replace it
if this doesnt help it could possibly be carburetor problems
Posted on Apr 29, 2009
  • 130 Answers
SOURCE: Intek engine runs poorly under load and when warm
if you have a ohv ajust valves and you might have to rebuild carb.
Posted on Jul 18, 2009
wireguy212
  • 1627 Answers
SOURCE: John Deere LA145 B&S 22Horsepower engine starting and running
You may simply need a new fuel cap,vacuum in the tank will rob your fuel and stall it engine,try taking off the fuel cap and see how it runs.If this does not help you may need a new fuel pump,which runs off of crank case pressure and should take over from the choke once the tractor has started.
Posted on Jan 19, 2010
  • 33 Answers
SOURCE: My craftsman mower with a 26 hp kohler dies when choke is in
carb dirty, jets partially plugged, float sticking. Not so uncommon problem and is caused by the fuel left in the carb over the winter gumming up (going bad). You can attempt to clean this on your own if you are somewhat mechanically inclined. Search small engine repair and it will give you a generic breakdown of the parts in a small engine carb. If not the, to have someone overhaul a small engine carb will run you about $120 including parts (at least around VA).
Posted on Apr 05, 2010
nova2nv
  • 197 Answers
SOURCE: JD L120 riding mower keeps dying on me
Loosen fuel cap 1 turn to see if it will stay running.Theres a tank breather hole/vent in the cap and when it becomes plugged no air can get into fuel tank when fuel is used,can also be a plugged fuel filter.
Posted on May 05, 2010
Kohler engine troubleshooting
If you can keep it running with the choke pulled out or partially pulled out I would check to see if there is a fuel filter on the machine and most likely you have a carb problem and it is gummed up and needs to be rebuilt.
Jul 04, 2014 | Poulan Garden
The motor sputters and almost stalls have to use choke to keep it running.
sounds like the flowt is sticking in the carb and it need a carb rebuild kit
Jul 18, 2013 | Garden
Stalls When engaging the blade clutch
Check that the blade brake is disengaging. Slip belt off blade spindles and check that they spin freely. Check underside of deck for clogged grass, ropes, wire, etc.
May 07, 2012 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
Engine surges won't run with out choke and then it stalls
If the engine surges and won't run without choke it is starving for fuel. Best place to start is the fuel filter. After the fuel filter, pull the fuel line off of the carburetor and place a container under the fuel line to catch the fuel. Crank the engine over and watch for the amount of fuel being pumped through the line. There should be a good stream of fuel with each pulse from the pump. Chances are the pump diaphragm is getting weak and it cannot keep enough fuel in the carb to run proper. Check those items and let me know if it helps, Daniel.
Sep 29, 2011 | John Deere 24HP VTwin Hydrostatic 48"...
I have a murray push mower 6-22271 briggs straton 4 hp. it start and then stalls . filter clean. choke fully closed when control is in full forwrd run/choke position. I pour gas in the throat and pull...
Your carburetor needs cleaned. It is dirty/has debris in it. If it has a bowl that is. If it has a diaphram (carburetor mounted on the fuel tank), replace the diaphram. They go bad.
I hope this helps get you going.
Jul 28, 2011 | Garden
Apr 21, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Have a craftsman model :917.273621, with a briggs & stratton 24 hpohv...familyy;ybsxs.7242vf. will cut good for 30 minutes, then sputter and stall. I disengage blades, and pull out choke to keep it...
try the coil. the coil will produce the spark for the spark plug seeing as there is no battery, try replacing it with another of the same power.
Jun 18, 2009 | Garden
Garden Logo
63 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
