Question about AT&T ATT SB67128 Cordless Phone Repeater
What does the slow or fast red flashing light mean?
What does a red light and a flashing yeallow light mean on a honeywell gsm radio
RED FAULT ON - No contact with network.
OFF- Normal.
SLOW BLINK - Loss of communication with the panel (ECP fault).
FAST BLINK - No network contact AND loss of communication with the panel.
YELLOW MESSAGE ON - Message transmission pending.
QUICK PERIODIC BLINK - Normal
FAST BLINK - Message waiting for network ACK.
SLOW BLINK - In unison with green LED - Registration in progress.
Hope this helps, all of this was found in the manual :P
http://site.geoarm.com/pdfs/Honeywell/gsmvlp-install-guide.pdf
Jul 21, 2014 | Honeywell Ademco / GSMVLP-KT - GSM Radio...
Why does blue light keep flashing when my HMDX boom box is turned on
clip_image002.jpg if it is a slow flashing that means it is connected
if it is a fast flashing that means it is pairing
Jun 01, 2014 | Audio Players & Recorders
Philips 42pf9631d/37 6 slow red flashes and 3 fast
6-7 blinks means there is an issue with the power supply...
I found a replacement for my 42pf9631d/37
Part # Lj44-00117A
at TSM Inc. for $110.95 with free shipping...
http://www.tristatemodule.com/p-10120-lj44-00117a-samsung-tv-module-power-supply.aspx
Jan 28, 2010 | Philips 42PF9631D 42 in. Plasma Television
My glowbouy flashes green and red...what does this mean
According to the owners manual for these swimming pool lights, this is what each colored indicator means. Hope this helps.
Solid green
The battery pack is fully charged.
Slow flashing green
The battery pack is almost fully charged.
Slow flashing yellow
The battery pack is half charged.
Medium flashing yellow
The battery pack is less than half charged.
Fast flashing yellow
The battery pack has almost no charge.
Fast flashing red
A charging error has occurred and the light should be unplugged and then plugged back in. If the Fast Flashing Red persists after several attempts, the battery condition is questionable.
Also in the trouble shooting guide, it mentions this:
Problem: Red Indicator Light Is Flashing While Charging
Solution:
A red flashing indicator light when charging indicates a selftest
error condition. Unplug the product and plug it in again.
Try this several times; if the indicator light continues to flash
red, unplug the GlowBuoy and take it to an authorized service
depot.
Oct 22, 2009 | NRS CANTAR GLOW BUOY FLOATING POOL LIGHT...
When charging battery flashes red then stays on red.how long should it take to change to green?.its a dewault9130 18 volt
it doesn't change to green, the solid red light means it is fully charged, there should be a legend on the front of the charger to help you with this. If it flashes real fast the battery is malfunctioning and slow flashing is charging and again solid is fully charger.
Oct 03, 2009 | Dewalt 7.2-18.0 Volt One Hour Charger
The red light is blinking and it doesn't print.
There are actually some certain meaning on the red light and green light showing different information to user. The summaries are:
1) Green On, Red Off = Printer Ready.
2) Green Fast-Flashing, Red Fast-Flashing = Printer warm up.
3) Green Fast-Flashing, Red Off = Printer off-line.
4) Green Slow-Flashing, Red Off = Processing Data.
5) Green Off, Red On = Cover Opened, Toner Empty or Developer Unit / Drum unit missing.
6) Green Off, Red Fast-Flashing = Paper Jam or waiting for jam reset.
7) Green Off, Red Slow-Flashing = Paper Empty or Paper tray is not inserted.
8) Green Off, Red Off = Printer power is off.
9) Green Very-Slow-Flashing, Red Off = Printer in sleep mode.
10) Green (any condition above), Red Slow-Flashing = Toner low or paper empty.
So what is your printer condition? Better know what is going on your printer so can solve the problem.
Oct 02, 2009 | Kyocera FS-920 Laser Printer
Kyocera fS-920KX. Not printing
YBC (/\)
Jun 01, 2009 | Kyocera FS-920 Laser Printer
Kyocera Ecosys FS 920
YBC (/\)
Mar 24, 2009 | Kyocera FS-920 Laser Printer
Vdc and engine check lights both on
under dash connect together the 2 green multiplugs. The CEL light (Check Engine Light) will flash. Slow then fast. Count the slow flashes then the fast ones. I.E. code 21 will give 2 slow flashes then 1 fast = 21.
let me know the code and I will diagnose for you.
Dan
Dec 04, 2008 | 2002 Subaru Outback
AT&T ATT SB67128 Cordless Phone Repeater Logo
11 people viewed this question
Top AT&T Lands Phones Experts
Computer Repairing
Computer Repairing
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
