Question about Tefal ActiFry Deep Fryer
Ive blown the 250volt fuse in the actifry,can i replace,do u supply new..
2 Suggested Answers
SOURCE: TEFAL Actifry element in back has blown is it
the same thing happened to mine i think it is a bad fault mine was nearly new good luck
Posted on May 14, 2010
Spb karaoke machine blown fuse 250volt 2amp changed it checked plug in wall still no power what could it be pls
You may have blown a component of the power supply, which is what took out the fuse in the first place. Probably will need a trip to the repair shop.
Aug 19, 2016 | Music
I need a new plastic lid for tefal actifry serie 001 made in france
I have just looked for a paddle for my Actifry and both the above sites are very expensive i got mine from www.kgasupplies.co.uk and it was far cheaper
Kga Supplies Spare Parts Accessories For Home Appliance
Jun 02, 2012 | Tefal ActiFry Deep Fryer
Jensen jmc 670 wont power up
The power fuse is blown and you need to replace it. The fuse is 50T 3.15 A and 250Volt.
Oct 21, 2011 | Jensen Audiovox JMC-670 Audio Shelf System
What is the size of the JBL PSW-D110 fuse?
The fuse is a 250volt 1.25 amp slow blo.
First thing I would do is check C6 to see if it is bulge or blown - regardless replace it with a 10ufd 100volt Non-polarity capacitor. If the fuse blows again unplug the blue wires from the transformer and plug in unit to an outlet. If fuse does not blow then problem is on PC board. I have a service manual for this item. Probable causes on PC board are Filter Caps, Bridge rectifier (DBA), Amplifier module, or fragments of C6 even causing shorts on board if it had blown.
I have bought C6 from MCM Electronics for under .50 cents but you have to put shrink tube on one lead and bend it back along the body and solder both leads in the board.
Good luck
Jun 24, 2011 | JBL PSW-D110 Speaker
TEFAL Actifry element in back has blown is it replaceable
May 14, 2010 | Tefal ActiFry Deep Fryer
Had to change p/supply installed new 680w apower reinstalled powered up fine shut down moved to where pc would sit plugged in and nothing pulled apart again checked connects powered up fine shut down and...
you could open up the power supply and look for any fuses that may have blown, the ones ive seen are the glass type and are cheap to replace and easy to find at radio shack just take the blown fuse with you and replace with the exact amps. and make sure that everything is unplugged from the wall and be very cautious around the large cylinders inside the power supply aka "capacitors" they can hold a residual charge and WILL harm you
Jan 13, 2010 | EliteGroup GF7050VT-M Motherboard
How do I change the F1 fuse on the B&W Air Station?
  1. Take off the bottom(6 screws philips)look for a small glass fuse that is soldered in place.
  2. Cut this fuse out(cut as close to the fuse as possible)
  3. Replace fuse(1.25amp 250Volt) You can find on e-bay search by 1.25 amp) there is a fuse with the wire already attached on it....solder new fuse in place.
  4. If you dont want to wait to order the fust just solder wire into the fuse area(you will have no surge protection but it may worth the risk because the frequncy if this fuse blowing.
  5. It may look like the fuse is O.K. but trust me its blown.
  6. There are 2 compessor bellows keep in mind they don't both run at the same time One isfor AC the other for DC.
Dec 12, 2009 | Black & Decker ASI300 Air Station Inflator
Sharp XG-NV2U projector not firing up
there is a fuse in the block where the power cord plugs in. you have to disassembe the unit and remove the circuit boards to get to it as far as I can tell. the fuse is a 250volt 5amp ceramic fuse 20mm. I have the same problem and just found the blown fuse but I am still looking for the replacement fuse to buy.
jeff
Jan 08, 2009 | Sharp (BQC-XGNV2U//1) Projector Lamp for...
NO SOUND
leeanncook..
if you find the fuse blown, replace it mini fuse type 250volt 3ampre. and once you replace and it blown again. there have a problem of your audio I.C output. this are shorted..
and of course you buy it to an electronics store...
johnfil.....
Sep 08, 2008 | Audio Players & Recorders
Tefal ActiFry Deep Fryer Logo
116 people viewed this question
Top Tefal Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
paul
paul
Oscar Netto
Oscar Netto
Are you a Tefal Kitchen Appliances - Other Expert? Answer questions, earn points and help others
